Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Water leaks When I place the water container on the unit, it begins to leak. I could really use some help.
  • ists057 Nov 26, 2007
    I have water leaking from the clean water tank while I am using the cleaner. Is there a gasket that I need to replace?
I removed the clean water tank to refill it and all the cleaning solution poured out onto the floor. Turns out a plastic pin with a spring and a rubber washer also fell out onto the floor leaving a hole in the bottom of the tank. Calls to Hoover and local repair center all ended the same with the need to order a new clean water tank for about $45 and two weeks for delivery. Went to my local True Value Hardware store and within a few minutes we found a workaround using two 7/16"x 1/4"x3/32" #780 Ring from Danco Inc. Pulled off the proprietary Hoover O Ring that had obviously failed and put two of these O Rings on in its place and so far it is working perfectly. Total cost $1.35. Would be nice if Hoover cared to take better care of their customers by offering this almost free and quick solution to the problem.
Posted on Jun 09, 2009
    President:
  • 1,673 Answers
Check to make sure the seal and plunger are ok, if they look ok, most likely there is a crack in the tank, lot of times the opening under the seal will break away. Replace the tank.
Posted on Jan 06, 2008
How do I stop the cleaning solution from leaking water everywhere.
Clear all filters and make sure the water container is fitted properly
Jan 09, 2018 | Vacuums
Water tank leaks water out
Hello! Storing the solution in the water tank can cause the tank to leak. The solution tank is replaceable. Follow the link below to place an order for a replacement solution tank. Hope this helps!
Search Results
Jul 29, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover f7458-900 leaking when placing tank on
Hello! Test the clean water tank to see if it is leaking. Fill the clean water tank with water on both sides. Hold the tank up and observe if water leaks from the valves underneath the tank. If either of the valves are leaking the clean water tank will need to be replaced. To order a replacement tank follow this link > Search Results. If the tank is not leaking, but the cleaner leaks when the tank is placed on it, this may indicate an internal issue with your pump. We would recommend taking the cleaner to a Hoover authorized service center. Follow the link to locate the nearest service center to you. > Service Center Locator Hope this helps!
Jul 26, 2014 | Hoover F7458900 Max Extract All Terrain...
Water leaks from the plastic container into the well where the container sits
Locate where the leaks came and then apply epoxy to seal off the hole leaks. When it is done, test the unit in operation and observe if still leaks. If it gone then no more leaks, if it is still there leaks apply again epoxy. Not too much or not too little, just enough to fill the leak hole.
Thanks for asking.
Jul 09, 2011 | Vacuums
Sprayer is not working, but leaks water
I think you have two problems. The leaking is old seals on either the containers, or on the other end (the machine). Try replacing them. There are various part websites for these.
The problem with the spraying could be the belt that turns the pump. Check it. If it's there its probably not it. The next thing could be the little plastic tubes that go to all the componets inside the machine tend to accumulate buildup. Make sure they are all flowing free. Next try the heating element (its inside the handle area) take it apart and clean it. If all those things are checked and it still doesnt work, it might be what was wrong with mine. The all on one container that holds fresh water and dirty water has a leak. I found mine would spray correctly if i had the lid off the container, and as soon as i would put the lid back on it would stop spraying. I found out that The suction going through the container to **** the dirty water in was also putting a suction on the clean water bladder which caused the water to stop flowing out of the clean water bladder. I ended up getting an all new container with bladder because i could not get anything to seal right due to its age and warpage of the plastic. So to determine if yours is the same issue. Just take the lid off the container and then try to spray water. It may take 10 seconds to get all the tubes primed again because the suction will actually **** all the water back up to the container. If you dont want to replace the container, just spray a few passes with the lid off, then put the lid back on to **** the water back up. Hope this helps. I might not write clearly for everyone to understand, but i hope it helps someone.
Mar 01, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Dirty water is not going into the tank, it's leaking out the bott
Check the little door at the back of the unit where the hose attachment plugs in. It has to be shut really tightly and it takes a quick fist smack on it to get mine to "click" and be shut. If that isn't sealed it could leak both clean and dirty water to the floor.
Also, take the dump tank off, check the filter (near the top where the dump tank connects on the machine side) is clear. Also make sure the rubber seal around the filter isn't loose or cracked. Then put the dump tank back on making sure the bottom is seated well first and then CLICK the top into place when you push it to the upright/in place position.
If you are using the hose attachment, make sure it is clicked into place tightly. I have to put one hand on the front of the machine to push toward the back while pushing the other hand on the hose to get it to click tightly in place. If it's not really snapped in there, it will leak.
Apr 19, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Leaking
Could be that the despensing tank has melted and deformed at the connection point. This is what happened to me when I put in really hot tap water. The heat allowed the connection (where the water/soap outlet is) to deform when using it. Now when I fill the tank and place it in the machine the water just leaks out all over the place with no control.
If you look at the bottom of your tank, where the water comes out, you may be able to see that the plastic is mis-shaped or deformed slightly. It probably doesn't take much for the seal to be broken.
TEA
Sep 22, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Clean Water Tank Leaks
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=612034
Posted by Liviaa on May 21, 2008
The clean water tanks leaks. What's causing the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 21, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Does not pick up water
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=529140
Posted by Dreams642 on Apr 20, 2008
I have had my Hoover Floormate for years. It has always worked great but the last few times I used it the amount of water left is tremendous and the container for dirty water was not full at all. I looked at it and the hose going up from the bottom thru the handle is broken how do I fix this.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Apr 20, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Steam Vac Dual Rinse Model F7205-910
MOST COMMON PROBLEM IS THE ATTACHEMENT VALVE IS BROKEN WHERE YOU CONNECT FOR WATER ON SIDE OF MACHINE. THESE MODELS USE AN ELECRONIC SOLONOID TO ACTIVATE WATER TO NOZZLE IF IT IS COMING OUT THERE SOLONOID MAY BE BAD
Mar 27, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
425 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
