Ozito 1100w hammer drill has a switch at the front to switch from drill to hammer. When in hammer mode and being used the switch rotates back to drill mode.
There is a spring loaded detent that keep the switch from moving. It is either dirty or needs replacing. The whole front of the unit needs to be opened to access it.
Is this your unit?
Parts:
Website: www.ozito.com.au
Email: [email protected]
I hope this helps. Please give feedback.
J
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
SOURCE: pbh 2200 re hammer action drill
hi
try to figure out how the switch operation mode works and put back together right.
bye savumihai71
SOURCE: hilti drill want hammer.
Not positive but I think that it works on air. Is there a cylinder with a piston in it. The orings could be blown?
Im not positive. Just tryn to help
SOURCE: on/off swich for hammer drill
Try www.searspartsdirect.com. Make sure you have the exact model of the drill.
SOURCE: I HAVE A MODEL DW004
Hi!!
The hammerdrill function is set by the selector switch, the switch itself may look fine from the outside, but, if it is not switching functions, you should open the hammerdrill and check the switching mechanism, even if you don't have an idea of how it works, after a visual inspection to the switching mechanism, common sense will tell you what's wrong, it is actually pretty simple.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
