Question about Cerwin Vega Stroker Pro 12 Car Speaker
NO BAS OUT OF MY NEW STOKER SUB
OK I PUT A WIRE GOING FROM POSITIVE TO POSITE NEGATIVE TO NEGATIVE FROM POST TO POST AND OUT TO MY HIFONICS BRUTUS 1600 MONOBLOCK AMP AND IM NOT ABLE TO GET THE BASS AT ALL
I have a hifonics brutus 1606d 1600 watt amp it gets power green light is on lit up across the top but i cant get any sound
Your amplifier may have experienced circuit failure other than a dead short that still allows power to be applied
Dec 05, 2016 | Hifonics Car Audio & Video
"Hi I'm planning to install aftermarket stereo system on 2004 Nissan Maxima 3.5 SL ..Kenwood KDCX997 eXcelon ..Hifonics ZRX600.4 Car Amplifier for kicker 6.5 ..Hifonics BRX160.2 Brutus  for 2 8" inch...
If you have enough room on the outside edge of your battery's post to fit the ring terminal from your new fuse holder, and an additional 7mm nut, then just do that. If there's no way for it to fit, you can purchase an aftermarket battery terminal that has a separate post for mounting aftermarket accessories to. That would be the second option since it would require more money and effort. Below is a link for a few different battery terminals that should be able to use for your car. I haven't looked under the hood of 2004 Maxima since probably 2003 or 2004, but I hope this helps.
2004 nissan maxima battery terminals Google Search
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jun 24, 2017 | Car Audio & Video
Brutus elite hifonics BRE1600.1D. Not as powerfull now.
Make sure of voltage going in to Brutus.
Mar 23, 2014 | Car Audio & Video
I have 2 Pioneer TS-W3002D4 12 In and a Hifonics Brutus BRZ1200.1D D-Class Mono Block what's the best wiring
you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
Mar 24, 2013 | Car Audio & Video
Amp not working
sounds like the amp is going into protection mode. maybe a sub is shorted (blown). Or, the only other possibility is the mosfet transistors on the inside of the amp are blown.
Feb 01, 2010 | Hifonics Brutus BX 1205D Car Audio...
How to connect HIFONICS BXI 2607 D watt at 1 ohm....
That's dependent on your subwoofers. You will need 2 dual 4 ohm subs wired in Parallel, a single dual 2 ohm subwoofer wired in parallel, a single dual .5 ohm wired in series. Or something similar.
http://www.bcae1.com/spkrmlti.htm
Nov 20, 2009 | Hifonics BXi 2006D Mono Block Amplifier...
Hifonics bxi 1606d
you could just take some out of some other electronics because all they do is reproduce sound so there is litteraly no power going through
Jul 04, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Illuminating the sub
i would assume hooking it to the remote and ground of the amp
Apr 24, 2009 | Hifonics Brutus BX12D4 Car Subwoofer
Car Audio & Video Logo
77 people viewed this question
Top Cerwin Vega Car Audio & Video Experts
Frank de Armas
Level 1 Expert
Chris Larocque
Colin Stickland
Colin Stickland
Are you a Cerwin Vega Car Audio and Video Expert? Answer questions, earn points and help others
