Noisy left hand power output stage. Noisy transistor? No circuit diagram.
I have a Pioneer VSX-D503 surround receiver. It has a scratchy sound coming from the LH speaker only. The problem is in the power stage because it is unaffected by the vol control. Sounds exactly like a noisy transistor in the output stage, but I have no schematic & can't narrow it down any further. Can you help?
  • 27 Answers
If the speaker is not blown, there must be an output capacitor. If no output capacitor, and you have a blown transistor the speaker will blow from DC current. You can further check the transistors with a multimeter. A transistor looks like 2 diodes and you should be abobe to test with a mulimenter like a diode test.
Posted on May 12, 2009
VSX-4800 receiver. Why is there no left channel audio output?
It is likely that the left channel output stage has failed but there can be problems with that A + B speaker switching. A defective switch can cut output.
Nov 08, 2015 | Pioneer Audio Players & Recorders
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
I have a Pioneer VSX-305 receiver. I blew channel A speaker outputs by allowing speaker wires to touch while the output was on. Everything else works, including the B speaker outputs. There are only three...
There are independent relays for the speaker A and B switching.Best place to start would be from the relay. When you select A do you hear a click, if not relay is not switching. The circuit involved is a small transistor , a low value resistor ( could be the culprit ) and a shunt diode.
Aug 16, 2011 | Pioneer VSX-305 Receiver
My Pioneer Elite VSX-53TX volume quit in the middle of a video. the read out on the unit says - - muting - - and no, we did not push the mute button. do you have any idea how to get the volume back
hi,
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check the protect show or not . if not, then any of the speaker is damaged. If then also it shows protect you have to check the amplifiers hardware.
AV receivers shows protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong.
Normally AV receivers show this when any of the output amplifier get some problem. there are six amplifiers in this AV receiver. May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
You have to check the amplifier.
for that you need digital multimeter,soledring iron screwdrivers etc
open the amplifier , then power it on. connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). then connect the positive terminal to all the output transistors emitter pin one by one . the voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
after replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. put the bulb in a holder. now you have to wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim . if so check the display, is there is protect mode is on or not . if not and come back to normal operation ,then remove the power , remove the bulb insert fuse and check
connect the power and check.
If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components.
ok
Mar 23, 2011 | Pioneer VSX-53TX Receiver
Output stage scheme for pioneer vsx-d1 channel floating negative.
It should be a push pull. The fact that you have negative voltage almost certainly means push pull. One side will be constructed using NPN transistors ran off the positive DC rail and the other side will be constructed using PNP transistors ran off the negative rail. I don't know the age of your amp but I know pioneer now uses integrated amp modules instead of discrete transistors.
http://pdf1.alldatasheet.com/datasheet-pdf/view/82968/SANYO/STK412-020.html
example of integrated amp module (sorry for the chinese)
Feb 11, 2010 | Audio Players & Recorders
I have bad static from my Pioneer vsx 49 Elite
sorry no easy solution as it sounds like the output transistors blew out or the emmitter resistors. you will need a service manual and an multimeter to measure the resistors on or around the audio output transistors they are a low value resistor usually around 1 to 2 watts in size. Do not replace any bad , burnt or discolloered resistors around the audio output transistors as if tou do you might just cause more damage to the output transistorsor audio output stage including the audio driver stage of the amp!!!!!!
Larry Dillon
Aug 27, 2009 | Audio Players & Recorders
Pioneer VSX-D308 Receiver Problem
go through your mode channels to put it on surround sound
Jun 09, 2008 | Pioneer VSX-D308 Receiver
Pioneer VSX-D702s receiver - no sound - need help/circuit plan
The unit is in what is called "protect" mode. A problem was detected in the final output stage and that stage is turned off. The most common reason for this is failed output transistors. This is a simple repair for any repair shop and will cost about $10-$15 for parts plus the local labor charge. Expect that the output transistors plus a few supporting parts to be replaced. Most of the time, only one channel is badm, but due to the design of the protection circuit, both channels are turned off.
Dan
Apr 01, 2008 | Audio Players & Recorders
Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
Jan 23, 2008 | Audio Players & Recorders
Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Dec 20, 2007 | Pioneer VSX-816-K/S Receiver
440 people viewed this question
 Grubhead
Grubhead
