Question about Microsoft Windows XP Professional
What is *.ini files ? how can i create it ? what is the use of it ?
    Sergeant:
  • 138 Answers
.INI files are plain-text files that contain configuration information. These files are used by Windows and Windows-based applications to save information about your preferences and operating environment. "INI" stands for initialization.
Format of .INI Files.INI files contain one or more sections. Each section begins with a section name, which is followed by zero or more entries. An entry associates a keyname with a value. The general format is:
[section]
keyname=value
Comments can also be included in the file by prefacing the comment with a semicolon (;).
Windows and Windows for Workgroups use several standard .INI files for storing configuration information. These files are WIN.INI, SYSTEM.INI, PROTOCOL.INI, PROGMAN.INI, CONTROL.INI, WINFILE.INI, MSMAIL.INI, SHARED.INI, and SCHDPLUS.INI. Windows-based programs may also add sections and entries to WIN.INI, and they may add .INI files in the Windows directory.
Editing .INI FilesBecause .INI files use only plain text, they can be edited using any text editor or word processor. .INI Master also has a built-in text editor for making corrections in the .INI files you are diagnosing.
To create a custom Setup.ini file:
  1. Start the Setup INI Customization Wizard.
  2. Type the path to your Office XP administrative installation point, and then click Next. The wizard searches the specified network share for a Setup.ini file.
  3. From the administrative installation point, select an INI file on which to base your custom INI file. Or, click Browse to go to a different location and select a file. Click Next.
  4. Under Logging, select a logging mode, and then type a name for the log file or template. Click Default to use the logging mode that is specified in the INI file. Click Verbose to use all logging options. Note that verbose logging creates very large log files.
  5. Under Display, select a default display setting, and then click Next. The wizard searches the administrative installation point for additional packages (MSI files) that you can chain to the Office installation.
  6. Select the check boxes next to the packages that you want to include in your custom INI file, add packages or programs (EXE files) that are stored in another location, and then click Next.
  7. Use the arrow keys to determine the order in which you want Setup.exe to install the chained packages. The System Files Update package is always installed first (if required), followed by the Office XP package. You can change the order in which subsequent chained packages are installed.
  8. Select each package, specify the options that you want for that package, and then click Next. For each package, you can specify an MST file and a unique display setting, as well as additional property values.
  9. To add additional property-value pairs to your custom INI file, select a package, click Advanced Properties, type the properties and values that you want, and then click Next. The wizard displays a summary of the changes to save in the custom INI file.
  10. Click Save As, and then type a name and path for your INI file. The wizard supplies a sample Setup command line that specifies your custom INI file with the /settings option.
  11. Click Finish to quit the wizard.
Posted on May 12, 2009
  • Microsoft Master
  • 508 Answers
The INI file format is a de facto standard for configuration files. INI files are simple text files with a basic structure. They are commonly associated with Microsoft Windows, but are also used on other platforms. The use of the "INI file" has been deprecated in Windows and corresponding data should be placed in the registry. The name "INI file" comes from the filename extension usually used, ".INI", that stands for "initialization". Sometimes, files using the INI file format will use a different extension, such as ".CFG", ".conf", or ".TXT".
For more go here: http://my.execpc.com/~iniman/what_is.html
  • 4,889 Answers
*.INI files are windows initialization/configuration files. I strongly advice you not to attempt to modify them or you will run into serious errors. The can be viewed/modified in notepad. To create a an INI file, create a text file and change the extension to INI.
Sai.
When I try to open a cookbook I get a dialog box saying Unable to create view: 'cbks'-'open'
I started receiving this same message today also. In addition, when I do a search by ingredient in the Search feature and try to open up the recipe I get the same message with the words 'Rcpe' - 'open' instead of the 'Cbks' - 'open'
Aug 06, 2013 | ValuSoft MasterCook 11
How do I get or make an .ini file for my downloaded .iso file that did not come with one.
An ini file is just a plaintext file with the extension .ini instead of .txt. You can create one in notepad and save it wherever you need it.
Oct 16, 2012 | Computers & Internet
My computer won't boot. The fan works, there are lights indicating power, however it just onnt boot.
your boot.ini file is being missing or deleted you can just reinstall new os os help you to create new boot.ini file
May 04, 2010 | IBM ThinkPad R51 1830 (1830AHU) PC...
How to create a flashdrive baground
First of all put the iamge file ( eg. test.jpg) in the root of the Flash drive. Then create a text file there and rename it to desktop.ini to the root of the Flsh drive.. Make sure it's not a .txt file.
Then open the desktop.ini file in notepad and enter following content.
Code:
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11D0-A­3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
>>.try it. :)
Feb 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Ntldr is missing press ctrl alt del to restart cant install o/s
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged: Ntldr
Ntdetect.com
Boot.ini To resolve this issue, verify that the BIOS on your computer is current, and then use one or more of the following methods, as appropriate to your situation, to repair the Windows 2000 startup environment.
Verify That the BIOS on the Computer Is Current loadTOCNode(3, 'summary'); Make sure that the latest revision for BIOS is installed on the computer. Contact the computer manufacturer to inquire about how to obtain, and then install the latest BIOS update that is available for the computer.
Method 1: Use a Boot Disk to Start the Computer loadTOCNode(3, 'summary');
  1. Create a Windows 2000 boot disk that contains the following files: Ntldr
    Ntdetect.com
    Boot.ini
    Ntbootdd.sys For more information about how to create a boot disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows 101668 (http://support.microsoft.com/kb/101668/ ) How to use a Windows boot disk to prevent boot failure
  2. Modify the Boot.ini file to point to the correct hard disk controller and to the correct volume for your Windows installation. For more information about how to create a boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 311578 (http://support.microsoft.com/kb/311578/ ) How to edit the Boot.ini file in Windows 2000
  3. Insert the boot disk into the computer's floppy disk drive, and then restart the computer.
  4. Copy the Ntldr file, the Ntdetect.com file, and the Boot.ini file from the boot disk to the system partition of the local hard disk.
Method 2: Use the Recovery Console loadTOCNode(3, 'summary');
  1. Use the Windows 2000 Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.iniA list similar to the following list appears: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect If you receive the following message, the Boot.ini file may be missing or damaged: The system cannot find the file or directory specified.
  9. If the Boot.ini file is missing or damaged, create a new one. To do so, follow these steps:
    1. Use a text editor, such as Notepad or Edit.com, to create a boot loader file similar to the following boot loader file: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect For more information, click the following article number to view the article in the Microsoft Knowledge Base: 102873 (http://support.microsoft.com/kb/102873/ ) Boot.ini and ARC path naming conventions and usage 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows
    2. Save the file to a floppy disk as Boot.ini.
      NOTE: If you used Notepad to create the file, make sure that the .txt extension is not appended to the Boot.ini file name.
    3. Type the following command at the Recovery Console command prompt to copy the Boot.ini file from the floppy disk to the computer: copy a:\Boot.ini c:\
  10. Type exit, and then press ENTER. The computer restarts.
Jul 07, 2009 | Compaq Evo D500 PC Desktop
I get the following error message trying to load Nancy Drew Danger on Deception Island... Incorrect path to ini file
You create a new folder, name it something like "deception" and save it. Then insert the disk and begin install, when it asks you where you'd like to install it, click browse, and install it in the folder you created previously. It won't work if you just install it in the recomended folder...
Apr 28, 2009 | Computers & Internet
Createfile failed on INI file
Hi. I had the same problem, and i fixed it by creating a APShell.ini file wich was missing in MyFlashDisk\Shell directory.
In APShell file :
Version=1.0.2.43
Language=23
[Navigation]
Path1=\SDMMC\ROUTE66\R66n8.exe
Path2=\SDMMC\N8\Navigate8UI.exe
Path3=\SDMMC\ROUTE66\R66Navigate8.exe
Caption1=Navigate
Caption2=N8
Caption3=Navigate
ClassName1=
ClassName2=Explore
ClassName3=
Reset=
reset device and it should work.
Mar 30, 2009 | Route 66 MINI Handheld GPS Receiver
In my pc there is an problem of NTLDR missing . why this ill occure?
    Ntdetect.com
    Boot.ini
    copy drive:\i386\ntdetect.com c:\ If you are prompted to overwrite the file, type y, and then press ENTER.
  8. Type the following command, and then press ENTER: type c:\Boot.ini A list similar to the following list appears: [boot loader]
    timeout=30
    [operating systems]
    If you receive the following message, the Boot.ini file may be missing or damaged:The system cannot find the file or directory specified.
    1. Use a text editor, such as Notepad or Edit.com, to create a boot loader file similar to the following boot loader file:[boot loader]
      timeout=30
      [operating systems]
Dec 05, 2008 | Computers & Internet
Error on windows load
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
This is what the boot.ini file should look like. Use U'r recovery disk to create or edit the ini file as above. U cannot use DOS 6.22 to create this file if U'r system is formated in NTFS.
If U don't have a recovery disk, make one from someone else's XP computer (DOS 7.xx).
May 10, 2008 | Dell Dimension 4600 PC Desktop
Microsoft Windows XP Professional Logo
313 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
