Question about Apple Power Mac G5 Desktop
Blinking white lite won't really power up monitor says no signal and the fans start slowly then gradually increase. we had taken the side off to clean out the dust and dog hair and when we put it back together this happened
  • 700 Answers
Clean your memory card. its edge connector with soft eraser both side. Do this after you power off the unit and unplug to wall socket. Take out the memory and do the cleaning.
Posted on May 12, 2009
I am trying to power a bathroom fan and lite combonation from a GFCI that is located in the next room. I've taken power from the load side of the receptical , why won't it work ? Is it because all...
If you have a GFCI recepticle with 8 holes in the back. hook your fan to the two holes on the "line" side. If you don't have four holes to use tail, join the line wires, with a tail to hook to the line side of the recepticle. This way you have a direct power to the fan and protected circuit to the recepticles.. Make sure your connections are good. If using the "holes" make sure you tighten with a screw driver and not just a screw gun.
Jun 22, 2011 | Oregon Scientific Home
BLACK SCREEN AND POWER BUTTON WILL ONLY BLINK OFF AND ON
This sounds like the signal coming from the computer may be out of sync. Do you see anything on the screen while the computer is starting up, showing the POST text (testing memory, etc.)? If so, try connecting another monitor and set the resolution to something low.
Then, reconnect the monitor in question and set your preferred resolution. If this doesn't work, slowly increase the resolution until you reach an acceptable one.
I hope this helps.
Dec 20, 2010 | Dell Computers & Internet
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
Power lite started blinking, i unplugged and waited a bit and plugged back in. Now no lite at all, nothing. Is it dead?
check the cable or replace it if you do that and start blinking clean the memory module by pencil eraser
Jan 02, 2010 | LG L194WT 19" LCD Monitor
Slow flashing blue power lite. Monitor shows no
First when you power up the computer press F8 key then enter in enable vga mode.
If you are able to enter then go to start menu->control panel->display property ->settings.
Change screen resolution to 1024*768 then apply and ok.
But if you are not able to see safe mode and other menu.
Then open cpu cabinet .
Refix RAM memory.
Pull cmos cell from motherboard for 10 minutes.
Reattach all connection harddrive.
Open processor fan and processor remove dust from all parts.
Make sure motherboard is not ground with cabinet.
Remove PCI cards if any.
After all above still same then change RAM then try.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Gateway DX4640-UBC01A PC Desktop
Light blinking problem in LG 775N ( White ) 17'' CRT monitor
any shortage in secondry side of monitor ..
plz check shoting.
Feb 25, 2009 | Computers & Internet
Problem with right turn signal of 2005 Jeep Liberty Renegade
the problem is to do with the earthing or ground ,clean the area where the bolts attach a wire to the body work of the car losen bolt and retighten if this does not work run a new earth/ground wire
Jan 20, 2009 | 2005 Jeep Liberty
Apple Power Mac G5 Desktop Logo
133 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
