Don t know email or password
Typically when a mobile device is locked, it wants the original e-mail account name and password it was setup with. You shouldn't need internet connectivity to unlock the phone. If you can log into your account at https://mail.google.com/ that's good, but it doesn't guarantee it's the same account the device is using or the original password used.
In some cases, if the device can receive a call, you can access the menu during the call and disable the screen lock.
If you don't remember the username and the account was properly setup at creation time, you can recover the name using "I forgot my username" here: http://support.google.com/mail/bin/answer.py?hl=en&answer=46346 And here's a trick to recover an account name on an Android device: https://productforums.google.com/d/topic/gmail/ydNElvUjJVU/discussion
If you have the username, the following will help with the process to recover the account by resetting the password: http://gmailaccountrecovery.blogspot.com/
BUT... A recovered account or changed password won't have the original password which is what the device needs to be unlocked. In that case the device will probably need to have a factory reset done (read the owner's manual for instructions) and then setup again with an e-mail account (be sure to write the information down this time). If it's setup with the recovered e-mail account, any purchased apps and synced data should be restored. If a new account needs to be created, all previous information will be lost.
An article on this topic: http://einartysen.se/unlock-android-phone-after-too-many-pattern-attempts/
SOURCE: Samsung SCH-U740 Master Reset
Let me elaborate. On your phone press the:
1. Menu--scroll to Tools & Settings---press OK
2. Look for Security, press OK
3. Enter the last 4 digits of your phone #, or whatever you set the lock code to.
4. There should be an option to delete contacts. Becareful not to press the Reset Default option, for it will erase everything (ringtones, pix, filx, screensavers, etc..)
**If the Security option is not seen in the Tools and Settings, then choose Call Settings or Phone Settings. It should be in one of these.
SOURCE: i need factory reset for samsung propel
Remove the SIM card and turn on the phone.
Enter *2767*3855# or *2767*2878#
Hopefully, one will work.
Regards,
Waqar.
Note: All data will be lost in this MASTER RESET.
SOURCE: how do i unlock my samsung sch-r350 mobile phone
look on the internet for samsung format codes
