Question about Panasonic Computers & Internet
Panasonic KX-P2124 It was working fine then someone loaded paper by hand and since then it will not load paper I have reinstalled the printer I have reset it to factory settings. Every thing seems to work it just will not load paper
    President:
  • 1,197 Answers
Ams are often caused by a small piece of paper lodged beneath the rollers or beneath the tractor feed. While you can easily remove the rollers on most printers, it’s often easier to go fishing with an unbent paper clip or similar extraction tool.
You will often see this problem after the printer has "eaten" a piece of paper. A large chunk of paper gets trapped under the rollers and then gets bunched up by the printer’s motion, preventing other sheets from passing through the printer. The problem can also occur if, when printing labels, a label separates from the backing and sticks to the rollers.
Mystery jams can also occur when the tractor feed edges separate from the page while printing. Sometimes this can be a fluke, but other times it may point to a mechanical problem. Try taking the paper out of the printer and hitting the form feed button a few times. Watch the printer’s tractor feeds to make sure they are moving and are in synch with each other. Some printers use belts to move the tractor feeds and, over time, these belts wear, break, or become misaligned.
if there is anyproblem with ur traction or ribbon... u wud need a replacement of parts.... u can find them at e-bay for very less cost...
thank you have a nice day
Posted on May 12, 2009
I need drivers Panasonic KX-FLB758 for windows 7 please... thank I´m from Argentina
KX-FLB758 was apparently a clone of KX-FLB756 and KX-FLB751 model. Drivers available on the following page should work fine:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Multifunction-Fax/Drivers-Downloads/model.KX-FLB756.D#ts
Aug 19, 2010 | Panasonic KX-FLB756 Plain Paper Laser Fax
Panasonic fax kx-fp153
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Driver needed for panasonic kxp1124i printer
I found this at the bottom of the page at this Panasonic Website: http://panasonic.net/pcc/products/printer/windows_compliance/windows_xp_sp2.html
Ron
  • Regarding the following printers, Printer Drivers are included in Windows XP CD-ROM as standard
Category Model Monochrome Laser Printer KX-P4410, KX-P4420, KX-P4430, KX-P4440, KX-P4450, KX-P4410i, KX-P4451, KX-P4455, KX-P5400, KX-P5410, KX-P6500(PCL) Dot Matrix Printer KX-P1081, KX-P1121, KX-P1123, KX-P1124, KX-P1124i, KX-P1150, KX-P1170, KX-P1180, KX-P1624, KX-P1695, KX-P2023, KX-P2123, KX-P2124, KX-P2130, KX-P2180, KX-P2624, KX-P3123, KX-P3624
Mar 16, 2009 | Panasonic Office Equipment & Supplies
Panasonic KX-P2123 color printer
I unplugged it! For now I've given up printing anything!
Thanks, Glenna
Jun 25, 2008 | Panasonic Office Equipment & Supplies
Printer WILL NOT LOAD or ADVANCE PAPER
I have the same problem with my epson CX3810. Paper won't load or advance. Any solutions???
Feb 13, 2008 | Panasonic KX-P2023 24-Pin Impact Printer
Panasonic printer kx p3196
Your Paper Sensor Might have Problem, but Try Completely uninstalling and Reinstalling your Printer.
Nov 04, 2007 | Panasonic KX-P3196 Matrix Printer
Panasonic KX-P7100 and XP
ignore warning, it just means that the software has not ungone microseft testing, will still work fine if correct driver for printer
Oct 26, 2007 | Panasonic KX-P7100 Laser Printer
I NEED TO GET A DISK SO I CAN ADD TO MY COMPUTER. PANASONIC KX-P2023
If your looking for the printer driver, it should already be in the computer. Windows 2000, XP and Vista all come with the KX-P2023 driver pre-loaded. If you can't find it, you can use just about any of the KX-P2000 series drivers that are pre-loaded wqith Windows.
Oct 15, 2007 | Panasonic KX-P2023 24-Pin Impact Printer
Tear off
First, if you have your manual, look it at for possible solution. Does this printer have a "load" or "top of form" function? There may be a "programmable" setting which will back the paper back down to the correct spot. The college where I'm employed used to have several Panasonic dot matrix printers, but almost all are now long gone.
Sep 18, 2007 | Panasonic KX-P1150 Matrix Printer
Computers & Internet Logo
46 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
