Question about Asrock K7S41GX Motherboard
Extreme low audio and m.b. beeps when volume control moved
Using asrock k7s41gx m.b with a sound blaster live card and the output sound is very low almost nil. every time i try to use the sound icon in bottom right corner it beeps. beep is from motherboard. input (line in) seems to record fine.
4 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: bios beep
Looks like a problem with the RAM modules. Try reseating /swapping them, or change them altogether.
Hope that helps, and oh yes, dont forget the fixya rating!
Posted on May 08, 2008
leethedeuce
  • 4472 Answers
SOURCE: asrock motherboard k7s41gx still beeping
How dirty are the ram slots you might try blowing them out with computer air? The only next step is to assume the motherboard is bad and replace that.
Good luck,
Lee
Posted on Jun 14, 2008
  • 68 Answers
SOURCE: No Sound
I would uninstall the current sound card drivers first ensure that the sound if onboard is enabled in bios and then reinstall drivers etc if that doesnt work from the driver cd, download new drivers from the manufacturers website onto a flash drive and unpack them to a folder in my docs and either run the .exe file or the update driver wizard in device manager.
good luck
if this answers your query please rate my answer accordingly
regards
Posted on Sep 14, 2009
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
I install intex soundcard driver on my windows xp 200 it worked and when i removed the hardware the pc can detect my volume but cant hear any sounds
Simple dear. Go to control panel\sound & audio devices\audio tab
Now select ur default output device from dropdown button.
Will work, don't u worry!
Feb 05, 2010 | Creative Labs Sound Blaster Live! 5.1...
Is there a free download fro an audio output
If you are refering to the Sound Blaster Live card you can download the software here:
http://support.creative.com/Products/ProductDetails.aspx?catID=1&subCatID=206&prodID=4857&prodName=Sound Blaster Live!&subCatName=Live!&CatName=Sound+Blaster
Be sure to pick the correct operating system.
Oct 24, 2009 | Creative Labs Sound Blaster Live! 5.1...
I just installed a used Asrock K7S41GX board which is working just fine exept I have no sound through my external speakers. The internal speaker on the the board beeps on startup but nothing after that. Do...
If you hear just one short beep on the onboard speaker it means that everything is fine. You should download the drivers for the onboard sound from Asrock website.
May 18, 2009 | Asrock K7S41GX Motherboard
Creative sound blaster live 24 bit soundcard external usb
Explanaition:
This delay you are experiencing is called latency. All equipment or signal processing unit introduces some latency even if extremely low.
Computer tends to be a lot worse than outboard gear.
Solution:
Look for Asio4All, this little driver will help you improve your audio input latency. And remember, the smaller the buffer size the lower latency you get.
http://www.asio4all.com/
Jan 23, 2009 | Creative Labs Sound Blaster Live! 24-bit...
How to connect 5.1 speakers to a notebook
yes it will :) if it has 6 female ports (the normal 3 + 3 extra) it will work just fine :)
Jan 07, 2009 | Creative Labs Sound Blaster Live! 24-bit...
Sound output prblem
Hello
First go to your startup>accesories>volume control properties ...Check if mute is on..Uncheck it.
and then play..
If the problem is not this..then you have to reinstall you sound driver..from your driver cd...if u dont have your driver cd..mail me your model no. i will give you the link for driver..
with regards
fixya member
abgog
Nov 07, 2008 | Creative Labs Sound Blaster Live! 5.1...
Low volume
hi, have you tried new drivers? how are the connections,cables?and check all the volume controls-look in control panel-sound devices.ect. hope this helps.i see you posted this a while ago.
Oct 31, 2008 | Creative Labs Sound Blaster Live 5.1...
Speakers not working
do i need a disk to dwnload these to work on my computer
Aug 09, 2008 | Boston Acoustics BA735 Computer Speakers
Sound card installed, still no sound
Set your default audio device in Control Panel - Sound. Also try disabling the onboard audio on your laptop in the bios menu. Make sure you have the correct drivers for your operating system. - Try to include as much information as possible in your posts to help diagnose the problem.
Mar 08, 2008 | Creative Labs Sound Blaster Live! 5.1...
Asrock K7S41GX Motherboard Logo
64 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
