Fuel pump has loose connections creating an on/off situation, or it has came loose from its mount and is basiclly flopping around in there. Im going to also mention that it will do this when you have 2 gallon or less fuel in your tank.
The combination Fuel Filter/Fuel Pressure Regulator is located on the fuel pump module. The fuel pump module is located on top of fuel tank.
The filter/regulator may be removed without removing fuel pump module although fuel tank must be removed.
REMOVAL
Remove fuel tank. Refer to Fuel Tank Removal/Installation.
Clean area around filter/regulator.
Disconnect fuel line at filter/regulator. Refer to Quick-Connect Fittings for procedures.
Remove retainer clamp from top of filter/regulator. Clamp snaps to tabs on pump module. Discard old clamp.
Pry filter/regulator from top of pump module with 2 screwdrivers. Unit is snapped into module
Discard gasket below filter/regulator.
Before discarding filter/regulator assembly, inspect assembly to verify that O-rings are intact. If the smallest of the two O-rings can not be found on bottom of filter/regulator, it may be necessary to remove it from the fuel inlet passage in fuel pump module.
INSTALLATION
Clean recessed area in pump module where filter/regulator is to be installed.
Obtain new filter/regulator (two new O-rings should already be installed)
Apply a small amount of clean engine oil to O-rings. Do not install O-rings separately into fuel pump module. They will be damaged when installing filter/regulator.
Install new gasket to top of fuel pump module.
Press new filter/regulator into top of pump module until it snaps into position (a positive click must be heard or felt).
The arrow molded into top of fuel pump module should be pointed towards front of vehicle (12 O'clock position).
Rotate filter/regulator until fuel supply tube (fitting) is pointed towards front of vehicle (12 O'clock position).
Install new retainer clamp (clamp snaps over top of filter/regulator and locks to flanges on pump module).
Connect fuel line at filter/regulator. Refer to Quick-Connect Fittings for procedures.
Install fuel tank. Refer to Fuel Tank Removal/Installation.
WARNING: THE FUEL SYSTEM IS UNDER CONSTANT FUEL PRESSURE EVEN WITH THE ENGINE OFF. THIS PRESSURE MUST BE RELEASED BEFORE SERVICING FUEL TANK .
Two different procedures may be used to drain fuel tank (lowering tank or using DRB scan tool).
The quickest draining procedure involves lowering the fuel tank.
As an alternative procedure, the electric fuel pump may be activated allowing tank to be drained at fuel rail connection. Refer to DRB scan tool for fuel pump activation procedures. Before disconnecting fuel line at fuel rail, release fuel pressure. Refer to the Fuel System Pressure Release Procedure for procedures. Attach end of special test hose tool number 6541, 6539, 6631 or 6923 at fuel rail disconnection (tool number will depend on model and/or engine application). Position opposite end of this hose tool to an approved gasoline draining station. Activate fuel pump and drain tank until empty.
If electric fuel pump is not operating, tank must be lowered for fuel draining. Refer to following procedures.
FUEL TANK REMOVAL
Disconnect negative battery cable at battery.
Release fuel system pressure. Refer to the Fuel System Pressure Release.
Raise and support vehicle.
If Equipped: Remove fuel tank skid plate.
Remove 4 fuel hose shield mounting bolts and remove fuel hose shield from body.
Remove fuel tank fill hose and vent hose clamps at fuel tank filler tube. Remove both hoses at fuel filler tube.
Remove exhaust tailpipe heat shield mounting bolts and remove shield. CAUTION: To protect fuel tank from exhaust heat, this shield must reinstalled after tank installation.
Place a hydraulic jack to bottom of fuel tank. WARNING: PLACE A SHOP TOWEL AROUND FUEL LINES TO CATCH ANY EXCESS FUEL .
Disconnect fuel supply line from fuel extension line near front of fuel tank. Refer to Fuel Tubes/Lines/Hoses and Clamps. Also refer to Quick-Connect Fittings for procedures.
Disconnect EVAP canister vent line near front of tank.
Disconnect fuel pump module electrical connector (pigtail harness) near front of tank. Harness connector is clipped to body.
Remove two fuel tank strap nuts. Position both tank support straps away from tank.
Carefully lower right side of tank while feeding both fuel hoses through access hole in body. Fuel Tank Full And Not Drained Using DRB Scan Tool: To prevent fuel loss through hoses, keep left side of tank higher than right side while lowering. Do not allow hose openings to drop lower than top of tank.
Continue lowering tank until clear of vehicle. Place tank on floor with left side (hose side) higher than right side
Drain tank by removing fuel fill hose at tank. Fuel fill hose is largest of 2 hoses. Insert the drain hose (from an approved gasoline draining station) into hose opening. Drain tank until empty.
If fuel pump module removal is necessary, refer to Fuel Pump Module Removal/installation for procedures.
INSTALLATION
If fuel pump module is being installed, refer to Fuel Pump Module Removal/installation for procedures.
Install fuel fill/vent hoses to tank fittings. To prevent hose from kinking, rotate each hose until index mark on hose is aligned to index tang on fuel tank.
Install hose clamps to hoses. Position clamps between index marks on each hose.
Position fuel tank to hydraulic jack.
Raise tank into position while guiding fuel fill and vent hoses into and through access hole in body.
Continue raising tank until positioned to body.
Attach two fuel tank mounting straps and mounting nuts. Tighten nuts to 10 Nm (90 in. lbs.) torque. Do not over tighten nuts.
Install both fuel hoses to fuel fill tube. Tighten both retaining clamps.
Position fuel hose shield to body. Install and tighten 4 mounting bolts.
Connect fuel pump module pigtail harness electrical connector near front of tank.
Connect fuel pump module supply line near front of tank. Refer to Quick-Connect Fittings for procedures.
Fuel filters are cheap and simple to change, so try that first. If that is not your problem it may be your catalytic converter. Before having that replaced, check your fuel return line. You should be able to blow thru the line with your mouth. If you can't, or it's really hard to do. . . then you have blockage. The blockage could be flooding your engine with fuel. Checking the fuel pressure with a gauge from an auto parts store may help you out. If the pressure is really high, then that may be your problem.
It is possibly the O2 sensor. I had some issues with early 90's 4.0 liters where the O2 sensor would stick rich under heavy acceleration and would cause it to lean out and bog down. It felt like a rochester four barrel flat spot on an old chevy. I hope this helps.
If you are driving on the highway in 4wd drive the poise may be from the tyres trying to slip and equalise the drive line torque that is building up . Rule of thumb for all 4 wd vehicles is to restrict 4wd to loose surfaces (gravel-snow-ice -grass- mud --any surface that allows the tyres to slip) to relieve the torque wind up.
Since it is used, there are many possible answers to this one. The tires may not be fully pressured, you may need to change the air filter, new oil, as well as it may need a complete tune-up. New spark plugs, wires, fluids, etc. I would start with the cheap things first like filters, fluids and tires. Then check on the plugs. Also, the average of 25 is from the manufacturer and most of the times it's usually highway speeds.
It depends on the speed you were going, if you were going less than about 20 miles, (older models it was 17, but I am not sure ofr the compass), also it depends of the angle of impact. Once it is beyond a fairly direct hit, an air bag can do more damage than not haveing it deploy.
