Assuming battery fully charged hook test lite between good groud and small starter terminal have somebody to crank if lits chek power and ground to starter and replace starter if no lit go to starter relay terminal 30 and 87 use a piece off wire and momentarily bridge them if starter bumps the engine check terminals 85 86 one is power when cranking the other is ground if starter bumps and test lit hooked to 85 86 lits replace relay if no lite keep tracing ckt to ignition switch
SOURCE: 03 silverado turn the key to start but starter will not engage
Interesting problem, on the starter is a "trigger" wire that originates from the ignition (may run to the power distribution center). When the truck is started 12 volts runs down that wire and activates the solinoid on the starter. Put a 12 volt test light on the trigger wire by the starter, have someone hit the key to start, test light should come on, if not chase wire back and look for a break in the wire or replace trigger wire.
SOURCE: starter starts...engine dosn't crank...starter dosn't stop.
Hi
An unusual one here !
Suspect the problem lies in the starter solenoid.
But most strange a for constant live feed with ignition off.
May possibly be more a relay problem ?
Good Luck
John.
P.S. Don´t forget to give me a rating please !
SOURCE: TRUCK STARTS BEFORE TURNING KEY COMPLETELY. AS
some of the older models did I do not know if the newer ones do or not my 2000 does not no does my nwifes 1999 model
SOURCE: ignition on but starter won't engage. Had new key
sounds like you need to relace the starter
Hi James Brault, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
