Question about Motorola Lands Phones
Memory card is not opening in my pc
As above
  • 813 Answers
Check if it is password protected in the phone?
Posted on May 12, 2009
How to recover memory card password for nokia c5-03
Solution 1:
1. Go to file manager on your mobile
2. In Settings choose system folders,
3. In the System folder, find a file called mmcstore
4. Send the file to your PC using IR/Bluetooth
5. Open the file in Notepad
6. The password you need for your memory card is located within that file
Solution 2:
1. Download and Install FExplorer
2. Insert your card into your phone, without accessing it through the phone
3. Run FExplorer and Open the path C:system
4. Find the file called mmcstore, and rename it mmcstore.txt
5. Copy that file (mmcstore.txt) to your PC and open it in Notepad
6. Your password will be located within that file.
Solution 3:
1. Download and Instal X-Plore
2. Now open the X-Plore and press Zero(0) then check you have marked the
"Show the System Files".
3. After you done the above step now go to the file:
C:/Sys/Data/Mmcstore
4. If you found the above path then press the option "3" to set the Hex-Viewer.
5. Now look the third column you can see the code like ! TMSD02G (c ??"? x???3?3?3?3?3)
Now see the characters between '?' because it is your password 33333.
6. You mayn't able to access the path file:
if you don't set the password for the memory card.
May 12, 2012 | Nokia 3110 Cell Phones
My memory card pass word forgot. please tell me how it was used regular course? which removed by any software recommend me.
Hi
Please follow the mention below step and unlock your memory card.
Download the FExplore clickhere
  1. Open any file manager softwares like Select, FExplorer.
  2. Search phone memory only)search for the file MMCSTORE in phonememory usingselect software's inbuilt search,or search manually in folders either C:/SYSTEM/DATA orC:/SYSTEM/ Search by giving the search item as mmcstore.* or mmcstore.dat (bettermanually locate)(Seleq represents phone memory as c drive and mmc as E drive)
  3. when you find it, send it to your PC by using send option in select on PC, open the file with Notepad, or any word processor.
  4. There goes your password.Ignore spaces and any unidentificable unknown(non english) charecters.
  5. You can only recover the password of the MMC card set onyour phone. If the password for the card was set on another phone you would have to applythe above procedure on the phone which originally set the MMC password.
If my solution make you happy and solve your problem so give me the four thumb.
Sep 02, 2011 | PNY 2GB microSD Memory Card
Phone Nokia 2700 Classic remove password micro sd 1Gb memory Card
Hi ,
Follow the following steps to remove the password check in
memory card
  • To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, click here to download.
  • After finished downloading, install it to your mobile phone.
  • Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
  • Run FExplorer and open the following location C:\system.
  • From the location C:\System, you will see a file named as mmcstore. Rename this file asmmcstore.txt.
  • Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
  • When you finished the above steps, you will find the password of that file.
  • With this password u can open ur Memory card
It has worked for the following user . pls click here to view
For any quires write back to me .If yo are satisfied with my answer please vote for me(4ups) . thanks in advance
Nov 27, 2010 | Nokia 2730 Cell Phone
WHERE DO I INSERT A MEMORY CARD ON THE PC
9 in1 media card reader was an option on Dell Demension 3100. If you have this reader installed, it would be in the slot right above the front head phone jack with 4 thin slot opening to insert different type of memory cards. If you don't have this you need to by a external usb reader - as low as $1.00 from ebay for basic SD card reader.
Oct 12, 2010 | Dell Dimension 3100 PC Desktop
What are the slots on the front panel used for?
Those are card reader slots.
Various types of memory cards can be used.
A memory card, (Or can be stated as Flash Memory Card), takes the place of the old Floppy Disks, for one.
It is digital. There is no disk inside, just hardware electronic components.
Due to the size of trying to explain every type of memory card that is available, and the memory card itself, I would like to give you this link,
http://en.wikipedia.org/wiki/Memory_card
Here it explains the basic format of a memory card.
You can click on the titles of the memory card/s, (in blue), to get a deeper explanation, of that particular memory card.
The specifications for your eMachines ET1810 Desktop PC, state that you have the following card reader slots for,
1.Compact Flash (Type I and II)
2.CF Microdrive
3.MultiMedia Card (MMC)
4.MMCmobile
5.MMCmicro
6.Reduced-Size MultiMedia Card (RS-MMC)
7.Secure Digital Card (SD)
8.miniSD Card
9.xD-Picture Card
10.Memory Stick
11.Memory Stick PRO
12.Memory Stick PRO Duo
13.Memory Stick Micro (M2)
Look above each slot for an abbreviation.
For example on my computer,
I have one card reader slot that is approximately 1 inch wide.
It looks like a T that is stretched out.
It has SD/MMC/SM/MS/MS-PRO, above it.
This means that the card reader slot will support, (Use),
[In order as printed above],
1.SD Card - Secure Digital Card
2.MultiMedia Card.
3.Smart Media card
4.Memory Stick
5.Memory Stick Pro
I have one more card reader slot. It has CF-Microdrive above it. A wider slot than the above, and looks like a upside down stretched out T.
This means of course that it uses, (Supports), a Compact Flash Microdrive card
I've tried to explain the various card reader slots, on your computer's front panel, without being too technical, or being offensive in nature.
If you want, I can explain as technical as you wish, or simplify my solution more.
This is the Specifications page for your eMachines ET1810,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810sp2.shtml
Scroll down, and look to the right of the heading - Card Reader.
These are the cards your computer supports, (Uses)
Looking at the main support page for your eMachines, it looks as though you have four card reader slots.
Three grouped together on the left side, and two in the middle.
The two slots to the far right are USB ports, with probably a headphone jack port, and a microphone port to the right of them.
This page gives a little more detail, as to what your card reader slots support,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810fv.shtml
Dec 24, 2009 | eMachines ET1810-01 PC Desktop
Can't open my nokia memory card on PC, I am not getting removable
install nokia pc suite. it will help you to open memory card with ease access.
Sep 26, 2009 | Computers & Internet
Im trying to put pictures from my camera's memory card back onto my camera's memory card from my pc.
If your computer has a card reader, insert the memory card. Close any window that opens.
Open My Pictures (or whatever folder the pics are in.) You can do an entire folder or individual pictures by right clicking on the picture(s) or folder you want to print, move your mouse down to Send To >.
A list will open. All you need to do is select the memory card from the list. The file(s) will be copied to the card.
If you do not have a card reader, you would be wise to purchase a flash drive. 4GB drives are very cheap these days. The instructions above would apply to the flash drive as well.
If you need additional help, please use the Comment button to reply.
Thanks for using Fixya.
May 20, 2009 | Canon Cameras
Emachine t2862 fan keep turning on and slows down my computer not sure if its the video card but thats when it usually happens
A fan turning on IS protecting something from OVERHEATING, more than likely the pc needs to be cleaned on the inside (blown out) especially the fans..
If the fan is coming on while the computer is being used, it's trying to cool down a hot component.
a fan should not strain the system,
this can be caused by adding a high end video card and not updating the power supply to needed voltages.... but from the factory, the power supply should be more than enough to run the system and fans without getting overused. sooooo........
1. pull the side off your computer
2. listen to the fans as they run
3. inspect them physically for dirt and freeness
4. check the powersupply, videocard, cpu and case fans..
Apr 01, 2009 | Computers & Internet
Momary card no open
I think it's because of a kind of virus. Click right on your memory card (while you plugged it to pc) and select "Open".
OR
While it plugged to your pc, Go to memory card from Address Bar in your my computer.
I think by this 2 way you could enter to your memory card but totally, you need to scan your memory card to terminate the virus.
Of course remember that maybe your memory card damaged and you won't be able to open it by thoese above ways.
Good luck
Feb 11, 2009 | Roxio Easy Media Creator 7
Memory Card
Dear
First u should know:---
1. All Nokia Phone save the memory card password in its phone memory.
2. Card Password is saved in Memory*.dat file on phone memory.
Now the process to know ur password
1. if u have file explorer in ur phone, search the above file and transfer it to PC
2. or U can use MobiMB Mobile Media Browser to get this file
3. In pc u open that file with Notepad. U see ur password.
Most easy trick to remove card password:--
In Market A card password removing device is available at 200 Rs. It is operate by 9 volt battery or USB.
It is also a card reader. U can remove password from all types of memory card from this device.
I think it is a good device for all also have value of money.
Oct 20, 2008 | Nokia 3110 Cellular Phone
Lands Phones Logo
24 people viewed this question
Top Motorola Lands Phones Experts
David Payne
David Payne
Are you a Motorola Lands Phone Expert? Answer questions, earn points and help others
