Remove write protection
I have 8 GB flash drive, i am not able to remove the write protection from it! plz help
  • 77 Answers
Here is the Solution.
- Start > Run > type ‘regedit’ (without the speachmarks) > Enter
- Single-click on ‘My Computer’ > File > Export > save it to the Desktop (Always best to have a backup!!)
- Go to the following:
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDeviceP olicies
*There seems to be some spaces here in 'StorageDevicePolicies' in the text above, there shouldn't be, OK*
- Double click on the string ‘WriteProtect’ and change the ‘Value Data’ box to ‘0’
- Then: File > Export > save somewhere useful as something like ‘StorageDevicePolicies001.reg’
- You also need to do this for the strings in any folders called ‘ControlSet***’ (* = any Digit, i.e. 001, 002) – for example: Everything is the same, just change ‘CurrentControlSet’ to ‘ControlSet***’
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\StorageDevicePolic ies
- Save these to the same place as before as ‘StorageDevicePolicies00*’
The saves are in case it reverts at a later date, just double click (saying ‘yes’ to importing these to the registry) on all of the files and it will all work again!
Posted on May 12, 2009
Here is the Solution. - Start > Run > type ?regedit? (without the speachmarks) > Enter - Single-click on ?My Computer? > File > Export > save it to the Desktop (Always best to have a backup!!) - Go to the following: My Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDeviceP olicies *There seems to be some spaces here in 'StorageDevicePolicies' in the text above, there shouldn't be, OK* - Double click on the string ?WriteProtect? and change the ?Value Data? box to ?0? - Then: File > Export > save somewhere useful as something like ?StorageDevicePolicies001.reg? - You also need to do this for the strings in any folders called ?ControlSet***? (* = any Digit, i.e. 001, 002) ? for example: Everything is the same, just change ?CurrentControlSet? to ?ControlSet***? My Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\StorageDevicePolic ies *There seems to be some spaces here in 'StorageDevicePolicies' in the text above, there shouldn't be, OK* - Save these to the same place as before as ?StorageDevicePolicies00*? The saves are in case it reverts at a later date, just double click (saying ?yes? to importing these to the registry) on all of the files and it will all work again!
Posted on Jun 04, 2009
How to remove write protected usb
One utility is given by HP free of cost, just go to HP website and download that utility to correct write protect error from flash drive
Aug 24, 2012 | SanDisk Cruzer Blade - USB flash drive - 8...
I have usb flashdisk 8 GB, but I can't format because of write protected
Go into the properties tag on the Flash drive and unset the Write Protected box.
Apr 09, 2012 | Computers & Internet
Flash drive write protected
go to my computer ,then double click on the flash drive icon and then it will ask you to format your flash drive . it will take a while depending on your flash drive for eg if you are using 16 GB it will take long ,but if you have 8 GB flash drive it won't take long .hope it works for you guys .
Jan 29, 2012 | NexxTech Computers & Internet
How do I password protect this damn thing?
create a folder in the 8 gb usb
((you can do this by right clicking in the drive select new folder also name it)) drive place all of the files or data you want protected in the folder then right click on the folder select properties you will see a sharing tab select that then tick in the make this folder private
in xp
hope this helps
Jul 06, 2011 | SanDisk 8GB Ultra Backup USB 2.0 Flash...
I can't to format my 8 G flash(message:write protect) i used the Repair_v2.9.1.1.exe ,but it message that the usb flash not found. plz help me
Any time you see "write protect" it usually means there is a small switch on the device which prevents deleting data accidentally, even by writing over it.
Look for a small sliding switch and flip it to opposite position. That should fix it.
Dec 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My flash drive kingston 8 gb is write protected. how can i open my flash drive?
Hi.
Try these steps.
Carefully switch the write protect tab to Write enabled when inserting the flash in the usb "PC".
try using it. This happens mostly when you are inserting the usb, the tab is pushed to Protected mode without noticing.
If that doesnt work, i suggest you buy a new flash from different brand and less GB.
Good Luck
Nov 15, 2010 | Computers & Internet
How to remove write protected in my 8 gb transcend
hi........please check that if there is switch in your pendrive..if present turn it other side..if not than follow this steps... 1. download a software from here http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
2.now fromat your pendrive by this software and than scan it for virus ...
hope this will solve your problem
May 25, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have 8 gb trancend pen drive and it is showing
This can be simply removed by changing the position of the write protect lock on the pen drive body. Please refer the figure.
Please come back and rate my solution if turns to be helpful for you or also if you need more clarification. Thnx :)
Apr 07, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
4 gb pen drive give write protected error
Save the contents in the pen drive (this process will delete all the files in ur pen drive) and then download this http://www.apacer.com/en/support/downloads/Repair_v2.9.1.8A.zip,unzip it n run.....click "Format". Make sure u have connected only the pen drive u wanna recover to computer,this tool is very blind n it doesnt allow u to choose which removable drive to format..it formats the first removable disk (seems so). Gud luckmoz-screenshot.png
Feb 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Computers & Internet Logo
237 people viewed this question
David Payne
David Payne
