Cannot fax or copy message is check scanning area
Good morning, My fax continues to show a message check scanning area does not copy or fax receive/send
  • Nike Merritt May 11, 2010
    what model machine?
  • 385 Answers
Take out the cover that covers your recieving paper and look in there!U will c a smallish black handle with a green sticker on,pull it down gentle and push it up untill it clips into place!Good Luck!
Posted on Apr 08, 2010
Good morning,am trying to fix a hp officejet pro l7780.It can't scan,copy or send fax.Could someone assist me please?
Does the fax/scanner light come on at all? If not, then that's the problem, because that's the only part that likely needs to warm up.
Sep 11, 2014 | HP Officejet Pro L7780 All-In-One InkJet...
My printer stopped working in the middle of printing stuff.
You can dial 1800-582-2826 or 1-(800)-474-6836 and get instant support.
Jun 08, 2014 | Lexmark Pro715 Wireless All-in-One Inkjet...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Brother FAX-8070P memory shows full and does not send all pages at one time?
This message means the memory capacity of the unit has been exceeded. The amount of memory used depends on the amount or type of data on the documents being faxed or copied.
  1. If you get an "Out of Memory" message while scanning the first page of a fax, press Stop/Exit to cancel scanning.
  2. If you get an "Out of Memory" message while scanning a subsequent page, you can either press Fax Start to transmit the pages that were scanned so far or press Stop/Exit to cancel the operation.
When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify Fax Storage is set to Off by doing the following:
  1. Press the Menu/Set key.
  2. Press the arrow key until FAX appears on the LCD. Then, press Menu/Set.
  3. Press the arrow key until REMOTE FAX OPT appears and then press Menu/Set.
  4. Pressthe arrow key until FAX STORAGE and then press Menu/Set.
  5. Check the setting. The display will read ON or OFF. If the setting is ON, press the arrow key until the display reads OFF.
  6. Press Menu/Set.
  7. If you have faxes stored in the memory, you will receive a message that reads Erase all fax? 1. Yes 2. No. If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Note
    If you would like to reprint the saved faxes, press 2 (No), press Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
  2. Press the arrow key until FAX appears on the LCD and press Menu/Set.
  4. Press the arrow key until PRINT FAX or PRINT DOCUMENT appears and press Menu/Set.
  5. Press Fax Start.
  6. After printing is finished, press Stop/Exit.
Jun 06, 2011 | Brother FAX-8070P Plain Paper Laser
When I receive a fax, it prints out perfectly. When I make a copy or scan to fax/email, the page has multiple black lines running down the length of the page. I have recently replaced the drum and the...
As the fax receives and prints incoming faxes ok then the print engine is working ok. the fact that the problem arises when copying or scanning indicates the problem is with the scanner or software that controls the scanner.
First clean both scanner glasses and the white area (white reference) under the doc feeder. When you are happy all is clean, follow the following instructions:
Press menu, * 2864 within 3 seconds. the display will show "Maintenance"
now press 55. The scanner will initialise and go back to "Maintenance"
now press 99 and the machine will go back to the default screen showing date and time.
Now do a copy. if you still have the lines or its all black then you will need a new contact image sensor. If all is well then that was a good cheap repair.
May 26, 2011 | Brother MFC-7340 All-In-One Laser Printer
My LaserJet 3055 All-in-one can print, fax and copy, but can not scan, when run the scanning software, the scan pub can move but when scanning data send to pc, the display of printer show "cannot...
"Power off" printer > Press & hold 'ENTER' > 'Power on'. Continue to hold 'ENTER' key only till "Program storage intt." (or similar nsg.) appears.
Wait & Let the unit boot to "Ready" message in the screen. Reload PC with device driver. Try to scan. If error persists Formatter PCB may need replacement.
Jan 25, 2011 | HP LaserJet 3055 All-In-One Printer
LSU Error keeps showing
LSU stands for Laser Scanner Unit. Depending on the model this should come up only if the services used required scanning such as copy, fax sending, scanning.
nevertheless if this is a continuous message you might need to check the connectors within the scanner which I advise an field call.
Apr 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Cannot clear memory--NEED FOR WORK ASAP!!!!!!!!!!!
Out of Memory message
If the memory becomes full while you are making copies, the LCD
message will guide you through the next step.
If the Out of Memory message appears, press Stop/Exit to
cancel or Black Start or Color Start to copy the scanned pages.
You will need to clear some jobs from the memory before you can
continue.
To gain extra memory, you can turn off Fax Storage.
—OR—
Print the faxes that are in the memory.
When you get an Out of Memory message, you may be able
to make copies if you first print incoming faxes in the memory to
restore the memory to 100%.
Apr 07, 2009 | Brother MFC 420CN All-In-One InkJet...
Unable to initialize
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine
To clear paper jams:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_003.html?reg=us&c=us&lang=en&prod=mfc420cn_us
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 29, 2008 | Brother MFC 420CN All-In-One InkJet...
Cannot copy or fax - Canon i-sensys L140
CHECK THE ADF
IT IS JAMMED OR NEEDS TO BE REPLACED!
CHEK AGAIN ..EVEN THE TINNEST PIECE OF PAPER CAN JAM IT.
Jun 09, 2008 | Office Equipment & Supplies
735 people viewed this question
jasbo
jasbo
