Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Refrigerator freezes up
Kenmore side-by-side refrigerator.  Freezer freezes up with ice buildup along back wall; refrigerator does not cool.
  • 5 more comments
  • viktory Dec 14, 2007
    My fridge freezes the food in the fridge .
  • Drumstick1 Jun 16, 2008
    The freezer will freeze up on the coils in the freezer side and stop the air flow from coming up to the fan to blow into the other side. I have to melt the ice from the coils then it will work again. what is the problem with the coils freezing up. Does the freezer have a cycle it goes into to thaw this ice from the coils and is not doing it.
  • Anonymous Jun 17, 2008
    I have a kenmore M#106-953017081
    coils freezing up
    I turn the defrost timer manule to defrost. defrost heater does not come on
    i short the test term. defrost heater will come on
    should i chance the defrost timer??
    Thanks TG
  • ag436 Jun 19, 2008
    Kenmore fridge all the food. I had turn down the fresh food to 0 and change the temperature on fresh meat to Warm. What is wrong with the refrigerator?
    Please advise.
    Thanks,
    Amanda
  • dave wilke Dec 07, 2008
    I have a Kenmore model 363.59577994 side by side ref/freezer. The coils on the freezer side keepin icing up so nothing cools properly. I have had this issue before many years ago and had to replace the defrost timer on that unit but it was a much, much older unit. I pulled out the heater assemply and the thermostat since the hearer unit was all black and there was black powder like something had burnt underneath of it. When I looked at the heater, one end slid out so the coil inside is broken.
    I am ordering a replacement unit now, but my question is should I replace the defrost timer just in case it is bad also? it isn't very expensive and I may as well do it since I'll have everything pulled apart. The problem is I saw what the unit looks like on the wensite to order it, but where is it located on the ref/freezer? I cannot find anything that resembles the picture?
  • Anonymous Mar 30, 2009
    freezer coil freezes up to a block of ice
  • Anonymous Mar 13, 2014
    Refrigerator cool, freezer not freezing
    Genius:
  • 1,122 Answers
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Posted on Jun 17, 2008
    Problem Solver:
  • 18 Answers
Replace the seal around the doors it sounds like the seals are not quite doin there job.
Posted on Oct 14, 2007
  • 44 Answers
The cold air in your refrigerator compartment comes from the freezer compartment. If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost system problem.
When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail how to dx and fix: Refrigerator Defrost Parts .
Posted on Oct 08, 2014
Turn off
take all food out.
open door of freezer.
let all ice melt away.
remove cover over evaporator coil.
turn on.
should hear fan running.
if it doesn't, hot wire it with 110 v.
if fan no works with hotwire, replace fan.
if fan works with hot wire, find evaporator thermostat about 1 inch big
clipped on coil of evaporator.  short out ( put wire connecting its two wires ) .
if fan runs now, replace evaporator thermostat about $ 15
Posted on Oct 23, 2007
    New Friend:
Ice building up in the vegetable compartment.
Posted on Jul 24, 2013
SOURCE:
Ge side by side refrigerator GSS25XSRDSS freezer not freezing
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 04, 2012 | Refrigerators
My Kenmore model 106.54546400 the refrigerator side is not getting cold
Do you see any ice buildup on the rear freezer wall? Is the freezer cold or is it just cool?
Oct 04, 2011 | Kenmore Side by Side Refrigerator
Ice buildup Model 795-78402-802 Kenmore SN:
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 29, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
GE GSH22KGMB side by side refrigerator freezes up and doesn't make ice and forms ice on the back wall of freezer and veggie drawer freezes.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not cooling at top - ice melted -not cooling on top of refrigerator - bottom of refrigerator is frozen
Check the back wall of the freezer for a ice buildup.(failure to defrost)
Check the freezer fan motor. Is it running?
Feb 12, 2010 | Jenn-Air JCD2295HES Side by Side...
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Kenmore regrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
    Mike
Aug 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JSTA SS side by side fridge not cooling/freezing
In most cases it is the Defrost timer circuit. One of three things the Defrost time (most likely) it allows the cooling for a 6 to 10 hour period and the defrosting for 10 to 30 minutes to remove ice buildup, ICE BUILDUP is the main problem as it restrict air flow, the cooling air circulation through the system. You see cool air only comes in the freezer side and passes through vents (pass ways) to the refrigerator side. Ice buildup in the freezer side inhibits cooling air to the refrigerator side. You think the freezer is working, but it is only cooler because there is ice in there that you can't see. The Terminator (a LIMIT switch) opens the defrost circuit if the defrost heater gets too hot (second likely) the next is the Heater which heats for those 10 to 30 minutes to melt the ice buildup (least likely) no matter the Unit you have they all have this circuit... Hope this helps, I'm Tango
Jul 26, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Frigidaire refrigerator
  • possible causes:
Jul 06, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Right side of refrigerator not cooling; frezzer working great
Ice build up on back wall could be defrost thermostat or faulty defrost heater
Mar 21, 2008 | GE GSS20IEM Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
11,269 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Paul Carew
Lawrence Oravetz
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
