1. Make sure your battery is fully charged.
2. Check connections from battery to starter relay.
3. Make sure you have voltage going to the start side (small wire) of the relay with the key in the "start" position.
4. If you don't have voltage going to the start side of the relay (small wire) with key in the start positon, then your starter switch is faulty (under dash usually mounted on top of steering column).
5. If you have voltage to the start side of the relay (small wire) with key in start position, and it don't click when trying to start your car, then the starter relay is bad.
6. If your starter relay clicks, but engine don't turn over, then the starter is faulty.
