Question about Samsung TX-R2435 TV
THE PICTURE OF SAMSUNG KIT IS CUTTING FROM BOTTOM LINEARITY RELATING TO IC TDA9381PS/N2/3/0660
  • shahjeetsing May 12, 2009
    i urgently need the solution of that question.
2 Suggested Answers
gopakumarg43
  • 75320 Answers
SOURCE: sinck problem
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Aug 11, 2017
Sinck problem
Aug 11, 2017 | Samsung Televison & Video
Lg 21" flat tv using ic tda9381ps n3 /3/1959.The display is white with retrace lines &picture
Check all the voltages at its video output card [CRT base PCB] If all are found OK, check and replace the chroma IC. The most probable cause is defective IC itself. Check its heating effect. Will overheat within minutes after the set is switched ON.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Aug 29, 2016 | LG Televison & Video
TDA9381PS/N2/3I1041 alernate ic name...?
To my knowledge there is not an alternate circuit. Take a closer look, the number you gave is for a vertical defliction IC.
Nov 12, 2014 | Samsung 24.8 Cu. Ft. Side-by-Side...
TDA9381PS/N2/3/0660 BASED SAMSUNG TV INSTANT GOES OFF WHEN POWER ON RASTER CAME AND TV TURN OFF WHAT THE POSSIBLE PROBLEMS SHOULD I CHECK?
This fault is in protection circuit.First check the 125V.D.C at sm out voltage.then eprom I.C.(memory) & Set the parameter by opening service mode Stanby>Display>Menu>Mute>Power on if require.
Jan 12, 2012 | Car Audio & Video
LG vertical failiure vertical line at the bottom of the crt
replace the vertical driver ic and the proccesor ic
Nov 12, 2008 | Televison & Video
My samsung cr32z30 32" hdtv turns off automatically after running for about 30min to an hour. also the picture is curved on both sides when watching tv in 4:3 ratio. the curve is most prodominate at...
Linearity coil (there are several) shorted causing HV to increase and causing HVSD, no replacement parts available. Replace sweep module to fix.
Nov 10, 2008 | Samsung Televison & Video
Samsung projection 54"
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
Feb 12, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung TX-R2435 TV Logo
82 people viewed this question
Jerry Greenberg
Jerry Greenberg
