Need to clean filter
I just need to know how to clean the filter
  • Anonymous May 13, 2009
    my washing machine lives washing powder on clothes after the cycle finish
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Oppen it up and check the hose exiting the pump. Vitally
Posted on May 12, 2009
Reset air filter
Page 58 of the user manual says that after cleaning the filter when the power is turned on, you will be given the opportunity to reply "Yes" to the question "Did you clean the filter". I suggest you go through the motions of cleaning the filter again, removing the necessary parts. Then replace the parts, turn the power on, and watch carefully for the message "Did you clean the filter".
Jan 06, 2014 | Panasonic PT-40LC12 40" Rear Projection...
On gmc line trimmer how do I know if the fuel filter needs cleaning ? or replacement ?
Hi cekind...
Use compressed air to blow out the filter, if that cannot be accomplished then replace the filter.
Please take time to rate me
Thanks,
Bud
Feb 21, 2013 | Garden
I don"t know what model
If the filter looks like metal mesh, you can clean it in a tub of soapy water. If it looks like cotton, you'll need to get a new one. You can pick one up at Home Depot et al. Either bring in the old one or get the measurements of it to give to the salespeople.
Aug 22, 2011 | Heating & Cooling
I have a Vicks V3100 and dont know how to put it together or if I even have a filter. I do not know what the filter looks like
There is a Wicking Filter that is also the same media that creates the humidity. This filter looks like rolled up paper media(like for a swamp cooler). This filter installs at the back of the unit with the water resevoir removed. The water then is absorbed by this media and as the air passes through it humidity is released into the air. The Wicking Filter will need to be replaced when the performance of the unit decreases and the material becomes hard from mineral deposits. There is also a Protec Cleaning Cartridge that looks like a small plastic ball with a stem on it. Inside this cartridge are softening agents that remove hard minerals and extend the life of the Wicking Filter. The Cleaning Cartridge is just simply placed inside the water resevoir. To prolong the life of the Wicking Filter and unit make sure to use clean and cool water. Distilled water will work the best if available. The harder the water you use the more the unit will need cleaning due to hard water. When the unit becomes clogged with diposits you will need to run a solution of vinegar and water through the unit to clean it. If you use distilled or filtered water(reverse osmosis) then the unit will rarely need cleaning.
May 14, 2010 | Vicks V3100 1.2 Gallon Humidifier
Need to know procedure to clean Kenmore Series 80 filter
unbolt the agitator filters should be underneath let me know how you went
Nov 11, 2009 | Kenmore 24902 Top Load Washer
"Check Filter" light is on
Take out the filter and pour water on the oposite side that is the dirt,if the water is not enough use degreaser and also clean thefront cover where the filter goes.
Apr 04, 2009 | Maytag M6Q10F2A Air Conditioner
Cant find filter on my hotpoint Ultima
Good luck. All modern washers that I know dont have the filter you need. If a clean out is needed you will have to clean out the pump.
Jan 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Cleaning the filter
Here is the link for your manual:
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
How to clean your filter:
The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
They say the frequency that you will have to clean your filter depends on yoru quality of water. The harder the water you have the more you will have to clean it.
Good Luck.
Mar 12, 2008 | Hunter 33202 Humidifier
Washing Machines Logo
290 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
