Question about HP Pavilion a1610n PC Desktop
My tower wont turn off and monitor says no input signal and keyboard doesnt work
Monitor says no input signal and keyboard doesnt work
    Scholar:
  • 87 Answers
Do you have two video outputs on your PC ie. one on the motherboard adn a separately installed card maybe? If you do you need to set the BIOS so that it uses the AGP/PCIE video card and not the 'onboard'. Try the onbopard vodeo card first to see if you get a signal there.
If you do NOT have two video outputs, and you can not see a signal then you may have a prblem wiht your monitor itself. Is this a known working monitor to start with?
Posted on Jun 05, 2009
    Problem Solver:
  • 7 Answers
Are you using a usb monitor? Does the motherboard support ps2 keyboard? If so, try a ps2 and see if you can get into bios. If you can see nothing on the screen at startup, try a different monitor. If you can get into bios, check the video settings. You can also try to start in safe mode - it may be a driver issue
Posted on May 12, 2009
Tower turns on but screen says no signal?
Check to be sure your monitor connection needles are seated properly. Is mouse wireless or connected to back of tower?
Jan 02, 2014 | Acer Aspire X3200 PC Desktop
No signal input ton montitor
Try a different monitor. If that works, your monitor has gone bad.
Mar 03, 2013 | HP Pavilion Computers & Internet
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
MY HP TOWER TURNS ON AND THE FAN RUNS, BUT DOES NOT SEND A SIGNAL TO THE KEYBOARD OR MONITOR. BOTH THE KEYBOARD AND MONITOR HAVE POWER AND ARE PLUGGED INTO THE TOWER. ON OFF BUTTON IS ILLUMINATED ON THE...
If the keyboard and is USB, you can try another USB port. For the monitor not getting display, I would try either a different monitor or a video card. Otherwise, the motherboard could be the problem.
Oct 02, 2010 | Computers & Internet
It says no input signal
Try a different monitor, to see if the video-card on the computer is the problem.
Jul 22, 2010 | Star Logic 17" LCD Monitor
Monitor says no input when pluged into tower
u much check the cable from your monitors to PC plug tight because when get loose your monitors cannot receive signal from pc
Jan 19, 2010 | HP w1907 LCD Monitor
Okay im having a probblem with my lcd monitor and when i press the button on the tower to turn everything on and then press the on button on the lcd monitor it says minitor is going to sleeep and ive tried...
Sounds like the monitor is not getting a signal from the tower.
Do you have another monitor/LCD screen that you plug into your tower? That will tell you if the LCD is the issue or the tower.
If it is the tower that is at fault, then you need to try and figure out if your video is separate from your motherboard. Hopefully it is separate, that way you can get that replaced. If not, then it means that your video card is integrated onto your motherboard which is much expensive to get fixed.
Hope this helps.
Dec 08, 2009 | HP W2007 LCD Monitor
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Cpu says no input vga signal, then goes to sleep
The no input VGA signal just means that the monitor is not receiving anything from the graphic card on the tower. Is the card a digital (DVI) output card? You'll know by the connector, it's white and slightly wider than a standard VGA connector. If so, perhaps the monitor is set to the wrong input?
If that isn't the case, and the computer is using an on-board or built-in graphics controller, you could try resetting the system's CMOS settings by setting the clear-settings jumper on the system board, or simply remove the plug and CMOS battery for a few minutes. Check the computer's documentation on the exact steps to do this.
Hope this helps!
May 19, 2009 | HP GX613AA Pavilion A6300F Desktop PC
No input signal!
Try disconnecting your keyboard and switching the computer on again and see if the monitor comes on properly. If it does you have your problem. Then power down and connect keyboard back up. If it doesnt work then you may have to change the keyboard.
Mar 14, 2008 | Computers & Internet
HP Pavilion a1610n PC Desktop Logo
1,160 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
