Question about Panasonic NN-P794SF Microwave Oven
Panasonic NN P794SF turntable does not work. Turns freely, no resistance.
  • olmergod May 13, 2009
    It turned out that the plastic piece that actually turns the turntable (plate) has a hairline crack in it. when you look at the part it seems fine, but when you add any weight to the plate, it opens up and allows the motor shaft to spin free inside it. Anyone know what that part is called? It is the part that the plate sits on and engages with.
  • 151 Answers
Probably its open circuit or the power to it has been interrupted on the inside. Needs an inspection to be sure.
Posted on May 13, 2009
Panasonic NN-SN960S turntable turns on when door is open
This can be caused by a defective door latch or possibly a control board fault.
Aug 28, 2016 | Panasonic Microwave Ovens
What wattage is genious prestidge NN-SD787ST
Max power consumption: 1460 Watts
Rated cooking power: 1250 Watts
Manual link.
Panasonic NNSD787 Operating Instructions
Page screenshot:
Apr 17, 2013 | Panasonic NN-P794SF Microwave Oven
Model NN E 548W The Microwave does not switch on.The Fuse on plug is OK.What solution?
THis type of microwave, invertor, is particularly awkward to work on if not trained by Panasonic.
I reccomend an authorised Panasonic repair agent take a look at it.
Jan 12, 2011 | Panasonic NN-P794SF Microwave Oven
Panasonic NN-P794SFR microwave unit that spins not rotating
there is a switch to turn it on or off. the turntable is replaceable
Feb 07, 2010 | Panasonic NN-P794SF Microwave Oven
My panasonic NN-T945SF starts, runs for a few seconds and then shuts off. And I smell rubber burning.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Sep 07, 2009 | Panasonic NN-P794SF Microwave Oven
Panasonic otr microwave model nn-s245bf, ventilating all the time, cannot use as microwave. thanks
I have the same problem. The control board (central processor) has caught fire. It's noticeable when you take the control panel off.
We need a new control board. I'm currently looking for how to get one. It appears to be a common problem.
Jun 16, 2009 | Panasonic NN-P794SF Microwave Oven
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
TURNTABLE DOESN'T TURN.
Does the rest of the oven's functions work? Does the front panel controls work? Does it heat up the food? If yes, this indicates that you might have a problem with the motor that turns the turntable.
If you try to turn the turntable manually (gently), does it turn freely or is there resistance? If it turns freely, the mechanical mechanism between the turntable and motor may be broken and the motor may be ok.
The oven's microprocessor also controlls the motor. There could be a problem there.
You'll need to have it looked at by a service center. Although its not that difficult to determine which of the reasons I mentioned above is the cause, it can be however, dangerous to operate a microwave oven with the cover off and with high voltage circuits exposed.
Please let me know if I can be of further assistance to you.
- Jim
Feb 17, 2008 | Panasonic NN-P794SF Microwave Oven
Panasonic NN-P794SF Microwave Oven Logo
206 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
