Question about Kenmore 98702 Stacked Washer/Dryer
Maytag dryer make very loud 'tumbling', thumping noise but the drum isn't turning. We just replaced the belt and all the wheels and pully's 'appear' to be in good shape. Help.
  • 62 Answers
If you just replaced all that then maybe you dont have the drum put back in there correctly. alternately sometimes the fins on the inside of the drum are not tight and shift and make noise as the drum turns. You tighten those on the outside of the drum. Make sure you put the belt on right.The blower wheel may have worked itself loose. Make sure the belt is on right and the drum was not put back in backwards. Check that, if the other doesnt work. Last but not least I have seen on some Maytag brands the seam on the drum was not welded right and it popped opened/no longer seamed togerther...check that as well.
Posted on May 12, 2009
  • Pataricia Nolte
    Pataricia Nolte May 12, 2009
    Also sometimes coins work thier way into the tumbling fins...just like you can tighten them you can loosen them and get the coin or water might be in there out.
    Problem Solver:
  • 16 Answers
Ck drum rollers first thing to go ,
plus that noise can be coming from motor blower maytag is good for this
Posted on May 13, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
It is the large radial seal at drum and body that is bad , has to be replaced , It is cheaper to buy a used working one or a brand new one. Vitally
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Bosch WTA 3510 uc/13 FD 8203 compact dryer is very loud. Motor is okay. Just changed the main pully. Belts are okay. Still is a loud rumble when operating. Any ideas? Rear bearing appears to be ok
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Oct 09, 2014 | Dryers
Whirlpool tumble dryer making a loud noise
the dryers drum that spins around is driven by a belt . A belt tensioner is attached to provide a secure fit when turning. The tensioner has a idler pully which has a bearing in it. When worn the bearing squeaks or wears out causing this noise you have. Sears sells the belt and idler pulley as a set to retify this situation you have. Instructions come with these kits
May 11, 2012 | Dryers
The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
Apr 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer very loud. Louder than normal rumbling noise underneath. Still dries clothes okay, yet will wake a person out of a dead sleep now.
Pull off the back or shell of the dryer. It is most likely the idler wheels or pully that the drum of the dryer rotates on as it spins. The drum has a belt that goes around it and a motor turns the belt. One of the wheels bearings may have gone bad.
Good luck...
PLEASE CLICK ON SOME THUMBS UP FOR THE ADVICE!!!
Apr 23, 2010 | Maytag MDG6000 Dryer
Maytag dryer (LDE5914ACE) loud slipping/thumping sound
yes, it's called a blower wheel... it is what blows the air into the dryer to blow out the humidity through the vent... it has a D fitting and as you use it, the D rounds out and the 'squirrel cage' stops spinning and begins to slip... if you continue to use the dryer without replacing this, you could burn up your dryer motor... it will just over heat....
Mar 19, 2010 | Maytag Dryers
Belt/Drum Noise
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 15, 2009 | Asko T761 Electric Dryer
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag (#LDE9304ACE) sounds like a popcorn machine
has the blower wheel rounded out in the center motor shaft area .give that a check.it has fin's and about 10'' to 12'' in diamitter.other wise check rollers and glides.if dryer drum was oblong that would create a noise as it tumbled.you are welcome to email if needing more help. God bless ,tom
Jan 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
323 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
