Feedback issues during live band performances
Feedback issues during live performances... Main volume at about 3 or 4 and mic volumes at 1 to 3. Bass, treble and mid levels are all about in the middle and no compression is added. Can you help me figure this out?
  • jeremyreddoo May 16, 2009
    We use pretty decent mics... all over $100. My brother's a guitar player and his probably gives us the biggest howl. He has an NV Cobalt mic ($70 or something like that). He said he's going to get an SM58 and be done with it. We played a show last night w/ all of our settings about the same as usual w/no feedback. The only difference from past shows were that our moniters were about a foot further away from our mics. I wonder if that's all it takes...
  • Samuel Charles Spriggs May 11, 2010
    I play lead guitar in a band and also sing. We battle this problem often. Do you use stage monitors? What type PA system do you have? Can you briefly describe how you setup? Where are mics, speakers, monitors, etc.?
    President:
  • 1,489 Answers
We use 57's & 58's and still get the problem if the setup isn't right. Biggest feedback problem, some time ago, was caused by micing the lead guitar amp -- we eliminated that mic and ran direct out from the lead guitar amp to the mixer. (We were even getting feedback caused by the lead guitar pickups getting too close to a speaker or mic).
Another adjustment we made was to lean the stage monitors forward (instead of pointing them directly at the voaclists) so their dirvers were not on the same axis as the microphones.
We also tweak high end EQ on the mixer and tweak the reverb send.
Don't know which change had the most effect, but we haven't had the feedback problem lately.
Charlie
Posted on May 16, 2009
  • Samuel Charles Spriggs May 17, 2009
    If the gig you played last night was a different venue for you, then it may be the venue acoustics which made the difference. More natural venue reverb means more chance of feedback loops.
    And, as you did, moving the monitors further from mics should reduce probability of feedback as well.
    You might experiment with your brother's guitar with pickup volume and treble to max -- move the guitar around to different locations on the set and see if things start to howl.
    Charlie
  • 27 Answers
This is clearly a microphone problem. You need to review your mics and use a suitable type. Ensure the speakers are not aimed at the mics too.
Posted on May 12, 2009
  • Peter Cass May 17, 2009
    The SM58 mics or similar should eliminate the mic issue. You may need an equaliser to get rid of any peaks in the foldback or room.
    Some speakers with horn tweeters are very directional so a small movement in the speaker can help.
    Maybe sing closer to the mics- the sm58 is designed for being very close to the singer.
I get ALOT of feed back, why? I can't use it like that. I've talk with the a Tech and he said I needed to stand further away from the amp, which I am.
This sounds like your gain is too high. Adjust it down. Every mic has different gain settings so you can't just blanket this with the other one works fine. Is this wired or wireless?
Dec 24, 2014 | Shure SM58 Professional Microphone
Feedback 3-4 mtres from speakers
Feedback is caused by having the volume up too high or being too close to the speakers. Turn mic down a bit, feedback goes away.
Better speakers and mic will help.
Sep 11, 2014 | AKG WMS 40 Mini Vocal Set Handheld...
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
How to connect a vocal processor to a peavey6 mixer
Set the voice input level on the voicelive2 by following this guide from the live 2 manual... Step 4: Set Mic Level This step informs VoiceLive 2 how loud you plan to sing with your particular mic. We'll use VoiceLive 2's automatic MIC GAIN feature to quickly set the optimum level. 1. Press and hold the REVERB footswitch 2. If you need to activate phantom power for your condenser mic, adjust the onscreen PHANTOM parameter which will restart the level test 2. Sing for five seconds with peaks that are as loud as you plan to sing 3. Follow the prompts in the display to finalize mic level setting, cancel or redo the procedure During performance, if you see the CLIP indicator light in the HOME screen, you can return to the automatic
MIC GAIN feature to adjust the input level.
When input level is set on the voice live ;
on the mixer set
the gain control to 12 o'clock position and
individual channel volume level to 7 ....raise the master volume
slider to hear mic input at desired level and without feedback
Jan 15, 2012 | Peavey PV6 Mixer
Hi im using the carlsbro gd 4000 in a 3 piece rock and roll band we are using an oldmike shure c606 and we cant get any volume out of the mike and its distorting the vocals we dont know whether the p.a.s...
Proper placement of mics versus the speakers of a PAS is important to avoid feedback. Your speakers need to be toward the audience from where the mic is. If the mic can "hear" the speakers you will likely have feedback. The mic should work even though it is a consumer grade mic.
WORD OF CAUTION: There are a LOT of fake SM58 microphones being sold... even on Ebay... SOME are fairly high quality and others are not.
Mar 31, 2011 | Music
On my Berhinger pmp 5000 powered mixer the mic trim pots seem very touchy.There is almost nothing on them until they are almost at maximum at which point you get feedback issues.How can I check to see if...
When using the trim with mics such as SM58's, etc. the trims often wind up at about 3 o'clock in normal use. You set the trims by pressing the PFL buttons down and setting the level using the led display histogram so that at maximum level of talking/singing the display never goes clear up to clipping.
IF you have feedback, then you have issues of mic location and speaker location. The critical point of feedback is far too critical to set with the trim controls.
Your main speakers should be toward the audience from the mics, not so the mics can "hear" the main speakers.
Monitor speakers are ALWAYS a problem with feedback... performers want more monitor, but depending on the acoustics of a stage, reflection from the back can get into the mics or the mics may not be directional enough... SIngers that choose to hold the mic and wave it around are a soundman's nightmare! They let the mic point toward a monitor and away goes the feedback.
The PMP5000 has a lot of power.
While your at it, PLEASE read my tip on FIXYA about PMP mixers regarding the hazard of using Speakon to 1/4 inch speaker cables... ESSENTIALLY never allow the barrel of channel "A" output 1/4 inch to be grounded as it, instead of the tip of the jack is the HOT lead !!!! This isn't in the user manual... I fix these things and discovered this hazard from the schematics.
Nov 23, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Micophone problem
Microphone might be in mute mode or the volume of the microphone is very low. I assume that you have inserted the jack of the Microphone in the correct port colored pink.
In Windows XP :-
Step 1. Click Start -> Control Panel -> Sounds and Audio Devices
this will open a window
Step 2. Click on the Volume tab and under Device Volume click on
Advanced tab will open the Master Volume window
Step 3. Search for the Mic Volume, if it is not there click Options ->
Properties and then check the box beside Mic Volume under
the volume controls then click OK now it will show in the
Master Volume
window.
Step 4. Then check the volume of the Mic Volume is full and there is
no check mark beside Mute.
If this doesn't solve the issue give me a feedback about the problem with much more details and the operating system you are using.
Jul 07, 2010 | Intel D845GVSR Motherboard
Everything seems to be working, but the audio has a lot of noise when playing back? Robert
1) Make sure your webcam mic is set as default
Vista
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
2) During the recording you may be picking up feedback from your speakers - try using a set of headphones
Jun 22, 2010 | Microsoft LifeCam VX-3000 Web Camera
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
I have an acer laptop and i have an echoe in my sound... im not sure what the problem is. there is an internal mic i believe. help please! lol
Try right clicking on yout Volume Icon in the system tray (where your clock is). Click on Open Volume Control.
Make sure you have some audio playing, then just go through each channel and mute each one, 1 by 1 until the echo has gone.
If that don't work, then again, right click on Volume Icon in Tray, click on Adjust Audio Properties, then under speaker settings, select advance, then choose Desktop Stereo Speakers, under the Speaker Setup Options.
One of those should work. If it is your Mic causing the Echo, then you would get loads of feedback if you whack up the volume. If you don't get the feedback, then it's more then likely the Speaker Setup or some Sound FX is enabled through your Sound Card Software.
Dec 02, 2008 | Acer 90.00012.30B Computer Speakers
121 people viewed this question
 Grubhead
Grubhead
