Question about Buffalo Technology Computers & Internet
External HD isnt recognized by ps3
I have an external hard drive from buffalo named BUFFALO HD-PCFU3 I converted it into fat32 but my ps3 still doesnt recognize it I have other usb devices which are converted into fat32 and my ps3 recognizes them only my buffalo 1Tb usb port isnt recognized I have all the right folders, but my ps3 just doesnt do anything I know how to let it work since I have done it to other devices only my HD doesnt work What should I do
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 196 Answers
Hmm, go to Start, Control Panel, Administrative Tools, Disk Management. Then look or scroll down right hand panel to find your disk. If it is there you could RIGHT click on it and assign a new drive letter such as Q or R.
If it's not there your external disk could be faulty, the power supply transformer or power cable could be faulty or it could be the USB cable.
If all looks OK you probably need to contact a disk recovery specialist such as DATA365.
Comment: NTFS is a much more stable file system and is much easier to recover after errors. FAT32 is not commonly used now.
Posted on Dec 10, 2013
SOURCE:
SOURCE: computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Posted on Aug 01, 2008
  • 192 Answers
SOURCE: ps3 and 1tb hard disk
This one may only have one possible solution.
You probably have heard that the PS3 will support up to a terabyte hard drive. That is true for most of them.
However, depending on the version of PS3, you may have to see if it is possible to flash the BIOS of the PS3. I talked to a Sony representative about the hard drive and it will support a 1 terabyte hard drive.
Contact sony to see if it is possible to flash the PS3 BIOS so it will recognize the drive.
Posted on Jul 27, 2009
SOURCE: Computer not accessing Buffalo HD
my Buffalo external hard disc can be detected by laptop, but my access is denied. When i click on the hard disc icon, it popped out a message box prompting me to reformat my hard disc. Is there any other way to retrieve my files before reformat or
is there any other way to recover my files after reformat?
Is there any other way to troubleshoot my hard disc other than reformatting it?
Please help me, I am desperate to recover all my files because they are too important/precious to lose it.
Posted on Jan 31, 2010
lock123
  • 6831 Answers
SOURCE: Buffalo 1TB drivestation beeping and not recognized
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
yavacotech
  • 374 Answers
SOURCE: i accidentally kicked my 1tb buffalo external hard
First try a different usb cable. The cable or the cable connectors may have been damaged as a result of the fall.
If that doesn't work and you are certain that your PC does not recognize the drive, then It appears to me that the fall damaged the delicate mechanical devices inside the drive and you will have to replace it.
Hard drives cannot withstand rough handling. If a hard drive is only dropped about 1 or 2 feet and it lands on a soft surface such as a carpet it MAY survive the fall. But if one falls from a higher elevation, (say 6 feet) onto a hard surfaced floor, it's almost a sure bet that the drive's internal mechanisms are permanently damaged.
To find out for sure, take it to a PC technician and have it tested. It should only cost you a few dollars.
If you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Regards,
Yavacotech
Posted on Dec 09, 2010
I have had my current Buffalo MiniStation Plus HD-PNTU3 for almost about a year now without an issue or problem but recently it refuses to open on another computer while it works fine on my own. I am
The device probably can with a Buffalo utility/driver disk. The other computer will need these drivers to recognize the device. If you lost the driver disk, you can download them here: http://www.buffalotech.com/support-and-downloads
May 31, 2013 | Buffalo Technology Buffalo MiniStation...
How to change transcend external harddisc fat32 to NTSC
HI you mean NTFS if YES, then there is step for xp or win 7
1. click Start, click Run, type cmd, and then press ENTER.
2.In the command prompt window, type: convert drive_letter: /fs:ntfs
Regards,
Chandrakanth
Oct 07, 2012 | Buffalo Technology 250GB USB SATA 2.0 HD...
My external hard drive (buffalo HD-PE320U2) is not working. when I plug it on the computer it says "windows does not recognize it" or it has malfunction. what will I do with it?please help I...
First uninstall the software,make sure the external hard drive is not connected to the PC and use your install disk to reinstall the software.You might all so try system restore.Thank you for choosing FixYa.com.
May 18, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
My buffalo combo 4 2 TB wont show up on my xbox 360. I already have it formated FAT32
The Xbox 360 can only recognize drives up to 16GB as noted on their website, I myself have tried a 32GB flash drive to test the limitations and it was not recognized. At this time it seems as though microsoft is limiting their external storage to 16GB.
http://support.xbox.com/en-us/Pages/xbox-360/how-to/usb-flash-drive.aspx
Apr 02, 2011 | Buffalo Technology Buffalo DriveStation...
My PS3 doesn't recognise the linkstation???
Welcome to Fixya. if your External drive is not detected by your Ps3 console you need to format it and select Fat32 File system. Ps3 will not recognize external harddrive using NTFS Format make sure you format the drive using Windows XP or Windows 7. Windows Vista dont have Fat32 but Exfat File format. After you format the drive to Fat32 make sure you create a folder like Music, Photo, Video and other forlders so that it will be detected by your console.
Thanks for using Fixya.
Feb 26, 2011 | Buffalo Technology Buffalo LinkStation...
May 11, 2009 | Buffalo Technology (USA), INC. - 500GB...
Time for physical format ???
Did you fit the drive into the Buffalo drive case? If so, take it out and put it in your computer tower/case and format it from there. Then put it back into your Buffalo case.
Go to the Buffalo sight and see if your Drivestation needs a firmware update - there may have been bugs in the one you purchased.
Mar 14, 2009 | Buffalo Technology 1TB DriveStation...
Computers & Internet Logo
114 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Norman Worley
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
