Gateway 4535GZ Notebook Logo
Anonymous Posted on May 12, 2009
The intel proset wireless connection dissapeared
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 12, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
537
Points
Do this when your system icon go missing.
(volume, network, clock & power)
CLEARING THE TRAY ICON HISTORY
> run 'regedit.exe'
> goto key 'HKEY_CURRENT_USER\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion \TrayNotify'
> delete keys 'IconStreams' & 'PastIconsStream'
> start task manager, go to processes and kill explorer.exe
> go to applications in the task manager, hit new task and type 'explorer.exe'
> explorer will now reboot and woohey, your icons should return.
Lenovo n3000 O769ATU wireless driver
Model 769 have the intel 3945abg chip inside, if you visit the Intel download site you can fetch the latest proset wireless package.
A reinstall solves most Wireless issues.
http://www.intel.com/support/wireless/wtech/proset-ws/sb/CS-034041.htm
Alternatively you can download a much older version from the Lenovo site.
While trying to add another computer to my wireless connection, it asks for a Device Ownership Password but it will only allow numerical digits (8). Help?
Using Intel ProSet Wireless, right? Use Windows utility and it will be fine. I still have not resolved this with ProSet.
Intel Proset wireless connection and Windows wireless connection are fighting for rights to connections. How do I use just the Windows Wireless connection? I need to disable the Intel Proset wireless...
If the Intel ProSet application has an icon on the bottom-right of your "system-tray" (the system-tray has the START button on the left and the clock on the right), then right-mouse-click on that icon, and choose 'exit' or 'close'.
I have an inspiron E1505 and i am trying to connect to my network to get rid of viruses. I am trying to connect using Intel ProSet/Wireless, but I am still not able to connect. Any suggestions?
Hi
Need to know when you try to search the network in the intel proset , does it find the network name or not . ie. does it see your wireless connection.
Alternatively you can use the following link for troubleshooting
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=RC1084719&docid=361597&l=en&s=k12
Thanks
Proton
1helpful
How do I turn the radio on the wireless card
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Hope this helps !
2helpful
Intel Proset wireless just drops connection
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Iam connected to the wireless network but cant access internet
right click my computer
then properties
hardware and then devices
scroll down till you find your network
click it and then update
after updating restart
let me know if that helped
Unable to connect to internet
has it worked previously? if so system restore if availiable
1helpful
2answers
Can't connect to Intel pro set wireless
Did you enable the wireless adapter.
Press FN + F2 on the keyboard to turn on the optional wireless Ethernet radio
2helpful
Wireless adapter radio
Windows* XP
  3. Click Hardware.
  8. Click OK.
Windows Vista*
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
