Question about Sony VPL-ES1 Multimedia Projector
The projected picture is "weak"
Hi, what could cause my projector to loose"power" it projects the picture by not very far maybe 4ft and not very bright . the lamp has 1000 hrs on it ., how do I know when it's time to replace the lamp, what are the signs that a bulb needs replacement?
thank you for any help.
Re: the projected picture is "weak"
I think some of the lamps only run to about 1000-1500 hours anyway, so it will be weak. I put a new one in thats only done about 200-300 and it still seems weak to me. I think this projector is just poor quality.
Posted on Sep 25, 2008
0 characters
3 Points
How do i eliminate the vertical green lines on the projected area?
Sadly the LCD/DLP wafer is failing, and the problem will progressively get worse. The DLP wafers can be replaced but it may cost as much as replacing the entire projector with an updated one. SORRY!
May 26, 2014 | Sanyo PLC SU20N Multimedia Projector
Projection not large enough
Make sure that the projector is far back enough and also make sure you are running the maximum resolution from your laptop driver.
Feb 21, 2013 | Sanyo PLC-XP200L Projector
Orange light blinking when turned on and doesn't project picture
First check your manual for trouble shooting the lights meaning. I think it is the bulb.
Jan 10, 2013 | Toshiba TDP T1 Multimedia Projector
Projects blurry picture onto screen even after adjusting the focus. It is an EIKI Diamond Projector LC-SD10.
Did you connect signal with native resolution 800*600
blurred picture can also be caused by extreme contamination of optical parts
Aug 22, 2011 | Eiki LC-SD10 Projector Multimedia...
My Power light Continuasly blinksand wont turn on?
Lots of times with projectors is when you pack them away for a long time the bulb may become loose or maybe you have a wiring issue. its highly possible that your bulb may have just come loose. this occurs alot when you move it around alot. If it suffered any physical damage like maybe someone decided to use it as a stress relief punching bag then maybe the carbon fiber in the bulb may have snapped or a wire may have come loose inside the projecter. Hope i cleared up some of your confusion, unfortunately i dont have any real solutions for you. sorry. ~~RJ~~
Sep 19, 2009 | Sharp Notevision XG-P20XU Multimedia...
Can not make picture bigger on my Sanyo PLC-SW20 projector
depending on the size of the surface you are projecting on, and what the zoom capacity of your lens is, you probably only have one choice available to you, and that is to move your projector farther away from what you are trying to project onto.....
hope this helps!
Jan 10, 2009 | Sanyo PLC-SW30 Multimedia Projector
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
Dell 2300 projects verticle stripes accross the projector screen.
this is due to improper power supply or a loose connection inside. the symptoms are of power supply unit inside projector. check out the current and amperes inside the projector on board. sometime the current stable but the ampears are down.also check the switching transistors & filters inside.......
Feb 12, 2008 | Dell 2300MP Multimedia Projector
PG-C30XU projecting criss-cross plaid image.
i suggest you do not have the projector too far away... 7ft away distance would be a Good resolution will also dimm don the square's image in the picture
Nov 08, 2007 | Sharp Notevision PG-C30XU Multimedia...
Sony VPL-ES1 Multimedia Projector Logo
303 people viewed this question
Top Sony Multimedia Projectors Experts
Jaime Hernandez
Are you a Sony Multimedia Projector Expert? Answer questions, earn points and help others
