Brivis central heating fan will not switch off runs continuous
I have brivis climate system wombat about 5 years old, the central heating fan will not switch off runs continuous, what would cause this problem.
  • 1 more comment
  • yellowtail3 May 13, 2009
    Thank you for your response, where is the limit switch and what does it look like, thanks.
  • yellowtail3 May 20, 2009
    Brivis wombat 2P 20 climate system, internal ceiling central heating, the fan will not switch off, problem solved replace circuit board on the right hand side, approx cost $130 for the board.
  • Anonymous Mar 23, 2014
    blowing cold air
Brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
Posted on Jul 14, 2009
Posted on Jun 05, 2009
Hi guys
I have a Brivis wombat 120 and the fan wont turn off.
I replace the control unit but still wont turn off
hope you offer me some assistance
Posted on Jun 07, 2013
  • 148 Answers
Fan limit switch
Posted on May 12, 2009
Can we turn the heat off 2-3 rooms with this brivis wombat 92 gas heating system - heating just the parts of the house we choose.
You could freeze water pipes if bathrooms are connected to those rooms - on a cold winter day (depending where you are). All gas appliances should have a shutoff valve. Shutting that off may screw up the main controller - it won't get the proper signal that the flame started ok.
Aug 24, 2014 | Heating & Cooling
Brivis wombat 2P 20
love to know how you went , i have a similar problem with the same unit.....
May 29, 2013 | Heating & Cooling
Brivis gas heater - Wombat 20 - fan doesnt seem to be operating at full speed
Take fan apart - easy. Clean with WD40 and then oil with 3and1
Works on all fans.
Jul 15, 2011 | Heating & Cooling
No indicators working found fuse box which fuse?
When you are talking about "indicators" we could assuming that your are refer about signal lights. This work with "flashers" devices.
For 1996 Audi A4 2.8L SFI 6cyl the Flasher is located in front seating area, driver side, under dash, behind dash lower panel, mounted above driver side of steering column.
About generic fuses, open the driver side door. Remove panel on left side of dash. Fuse box is behind panel:
Fuse # / Description / Amps
1 / Heated washer jets / 5
2 / Turn signals flasher unit / 10
3 / Headlight washer, illumination of glove compartment, engine compartment, climate control, automatic transmission, instrument cluster / 5
4 / License plate light / 5
5 / Instrument cluster, seat heating, test connection for cruise control, bulb monitor for auto-check control, Automatic transmission display, switch lighting, mirror switches and actuators, airbag warning light, outside temperature indicator, Climate control / 10
6 / Central locking system / 5
7 / Anti-lock brake system / 10
8 / Vacant
9 / Mirror heating / 10
10 / Vacant
11 / Cruise control (automatic transmission) / 5
12 / On board diagnostic system / 10
13 / Brake lights / 10
14 / Interior lights, reading lights, anti-theft alarm system, vanity mirror / 10
15 / Instrument cluster, power windows, climate control, automatic transmission / 10
16 / Anti-lock brake system, Anti-Slip-Regulation / 5
17 / Heated door locks / 10
18 / High beam right / 10
19 / High beam left / 10
20 / Low beam right / 15
21 / Low beam left / 15
22 / Tail and side marker right / 5
23 / Tail and side marker left / 5
24 / Wiper and washer system / 25
25 / Blower for heating, climate control / 30
26 / Rear window defogger, mirror heating / 30
27 / Rear window wiper / 15
28 / Fuel pump / 15
29 / Engine timing / 20
30 / Sun roof / 20
31 / Tail lights, cruise control, automatic transmission / 15
32 / Engine timing / 20
33 / Cigarette lighter / 15
34 / Engine timing / 15
35 / Trailer receptacle / 30
36 / Fog lights / 15
37 / Radio / 20
38 / Luggage compartment light, central locking system / 15
39 / Emergency flasher / 15
40 / Horn / 25
41 / Anti-lock brake system / 25
42 / Vacant
43 / Vacant
44 / Seat heating / 30
Hope this helps (remember to rate and comme this free answeer).
Jun 16, 2011 | 1996 Audi A4
My brivis wombat 120 igniter won't work so I can't light the pilot
I have a brivis wombat 120. When room temperature is lower than required temperature, it starts to fire up and sends heating air. Now, it does start firing. If I increase the temperature testing, you can hear ant click sound from heater, but no firing. Can anyone help
Mar 26, 2011 | Heating & Cooling
Hi We have just arrived back in Wellington from overseas. Our house has a gas central heating system - the unit is Brivis Buffalo 20. What we would like to know is how cost effective the Brivis Buffalo 20...
Hi, if you are planning to change this system out, please stay with a gas fired central system as compared to a heat pump, they are much more cost effective. Heat-pumps have so many problems as there are more parts on them to go wrong. The compressor and condenser fan motor run year around as with a heat-pump they use what is called a reversing valve that changes the flow of freon making the indoor coil the outdoor coil and the same with the outdoor coil becomes the indoor coil in the winter season. I can recommend excellent gas fired units compared to the Brivis unit you have that is much more cost effective, such as the Bryant, Carrier, Goodman. I would go with a Bryant and talk to a dealer. Stay away from a heat-pump no matter what they tell you as I have worked on them for many years and if you have gas available, stay with gas. You will heat your home much faster and save on electricity as this heat -pump units need heat strips for back up heat as they can't keep up the temperature with out them. I hope I have been of help to you on this, and you will be kind when rating me as I know you will. Please contact a Bryant dealer as you will not regret it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Sep 05, 2010 | Heating & Cooling
Brivis Upflow/Downflow fan on continuously, no heat
depending on the year of the unit
if its between 1992-1999 it would be caused by the either the pilot not staying alight, or a faulty gas valve not opening,
These models start the fan on a time delay not tempreture so you will only get cold air circulating and when the thermostat is off the fan will stop.
(All models) if the fan is running regardless of the thermostat position an over heat sensor is faulty.
May 17, 2010 | Heating & Cooling
Air blowing out - Pilot on but no heat.
Possibly overheating or previously overheated, these units are also prone to control box issues usually a buzzing noise at the unit it present if this is the case.
Apr 28, 2010 | Heating & Cooling
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Heating & Cooling Logo
3,815 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
