Question about Royal EZ-Vue Calculator
Need manual for royal 770 hd ez vur
Ribbon will not advance but mechanism is working
4 Suggested Answers
  • 125 Answers
SOURCE: The keys on the left side of my circa 1933 Royal
Hi:
The most likely problem is there is dirt inside the ribbon basket. This is the area where the type bar (this is the bar with the actual letter on it) ends. They all fit into a semi circle area. If you can find something very narrow and thin with a hook on it you can use it to clean out the areas where each type bar goes. Then try to lightly lube the entire basket right where the type bars pivot with something light like sewing machine or 3 in 1 0il. As far as the ribbon reverse goes it might be as simple as making sure that the ribbon is being fed through the ribbon reverse forks which are usually located left of each ribbon spool.
Good luck
Andrew
Posted on Jun 28, 2009
squipps
  • 204 Answers
SOURCE: the ribbon wont advance
The ribbon drive on this model are gear driven..a .may be off, a loose set screw on one of the gears..the ribbon may be the wrong one or it has a ribbon reverse lever on the side of the machine, this should be free of binds.
Hope this helps........
Squipps
Posted on Oct 08, 2009
unaasp192
  • 29 Answers
SOURCE: Ribbon will not advance
mark the ribbon where it turns, where there is a pin of the typewriter passing through the ribbon,mark it with a white marker.
and type something, if it doesnt turn, you know the machine has a problem.
or try everytime pressing on the ribbon, if it works you know the ribbon is coming up, check if the correction ribbon is placed good.behind the correctable ribbon.
unaasp192
Posted on Apr 12, 2010
My Royal Alpha 2001 ribbon stays stuck in high position a lot. How do I fix it?
It looks like it is not threaded correctly ribbon needs to be behind then in front of the carrier.
Aug 23, 2015 | Royal Office Equipment & Supplies
My vintage Royal manual ribbon cartridge does not advance when typing., stuck in same position.
Usually lubriction, there are small pawls or teeth that move gears and pegs that fit into the ribbon. make sure you have the correct ribbon.
Oct 07, 2014 | Royal Office Equipment & Supplies
Royal adding machine 770 HD EZVue paper cutter
Here is a link to find the authorized service centers - contact the one closest to you:
http://www.royalsupplies.com/service-centers.html
Apr 09, 2014 | Royal Genuine Used 770hd Printing...
unaasp192
Feb 17, 2010 | Royal Office Equipment & Supplies
The ribbon wont advance
Squipps
Oct 07, 2009 | Royal Office Equipment & Supplies
Adding machine problems
Block yBob - did you ever get an answer to your problem. I'm getting ready to install an ink cartridge into the same machine.
Aug 20, 2008 | Office Equipment & Supplies
Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Apr 09, 2008 | Office Equipment & Supplies
Focusing the 770
Tom, It's best to do the zoom first, then focus (if you are using the autofocus).
Sep 11, 2005 | Sony Cyber-Shot DSC-D770 Digital Camera
Royal EZ-Vue Calculator Logo
202 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
