Remove fuser, remove top door, remove top cover, remove rear cover,remover left side panel,remove dc controller cover, now remove itb belt and toners,then you will see two screws holding the pickup assy in place at the front, remove screws and lift pickup assy up and forward, thenyou will see the connection to the dc controller, remove and lift out, any problems, post back i will try to help.
Make sure the printer is plugged into a functioning wall outlet supplying the proper voltage (110V or 220V).
If you are using a surge protector, extension cable, or power strip, plug the printer directly into the wall outlet.
Press the power button to turn on the printer.
If the issue persists, unplug the printer and wait 15 minutes.
After 15 minutes, plug the printer back in and press the power button.
If the issue persists, try a different power cord (if available).
check in back siode ther eis 1 plate for IC .
pull it after open screw .
then u see there RAM.
Refix it after clean dust from it and its slot.
If problem still arise then u have to change RAM.
52.x PRINTER ERROR alternates with
To continue turn off then on
Possible printer control panel error messages52.0 PRINTER ERROR52.1 PRINTER ERROR52.2 PRINTER ERRORDescription
A temporary printing error occurred. The x
can equal one of the following:
0 = Scanner error
1 = Scanner startup error
2 = Scanner rotation error
This error can also indicate a problem with the shutter tab on the print cartridge.
Action
Turn the printer power off, and then turn on the printer power.
If the message persists, check the print cartridge for damage.
You either have a bad toner cartridge or a failed scanner assembly. Here's a free copy of the HP 2300 Service Manual to help you isolate it down. Check the troubleshooting section and it will give you a number of checks. The manual may mention a High Voltage Power Supply (HVPS) section on the DC Controller board but that would be highly unlikely. We have been servicing these since they were introduced and have never installed a DC Controller.
this problem persist NVRAM resetting To perform an NVRAM initialization, complete the following steps: 1 Turn off the printer. 2 Press and hold (DOWN arrow), and turn on the printer. 3 When all three status lights are lit, release (DOWN arrow) and press (UP arrow). 4 Press PAUSE/RESUME. The first item of a menu appears. 5 Use (UP arrow) or (DOWN arrow) to scroll to NVRAM INIT, and press (SELECT).
