Question about Sharp R-1500 Microwave Oven
Doesn't heat anything anymore...
Hi! I read your post and saw some advice that seem related but wanted to verify with you before I do anything.  I did not hear a pop but that doesn't mean it didn't happen.  Our family usually never leave the kitchen when anything is being cooked unless someone is there for safety reasons. The night before the microwave worked fine. The next day I tried to heat a cup of water and nothing was heated.  Fan, control unit, interior & exterior light, keypad all worked.  So I suspect the magnetron isn't working.  However could it be just a component on a board that may have gone out instead of the magnetron?  I know my way around electronics and upgraded the keypad and display when that went out a few years ago.  I'm not sure what electronics are involved when replacing the magnetron but when a board level component goes out is this something that can be troubleshoot and repaired or do you just replace at board level and not deal with components?
  • Waveoptix Oct 16, 2007
    Thanks, that sounds like a logical approach and will keep you advised of that progress.
    Champion:
  • 225 Answers
Check highvoltage section and diodes and finally replace magnetron...
Posted on Oct 14, 2007
Smh9187w vent fan popping noise
There are no bulletins covering a recurring issue with the exhaust fan on this model, so I would suspect the failing motor, an obstruction in the blades, a loose blade assembly, or a damaged wire arcing to the frame.
It will take some visual inspection with the oven removed from the wall (see your installation instructions) and the cover removed.
The service manuals for the variants are here:
http://www.microwavedisplay.com/smh7185_smh9187w_xaa_sm.pdf
http://www.microwavedisplay.com/smh7185_smh9187w_xac_v1.pdf
http://www.microwavedisplay.com/smh7185_smh9187w_xac_v2.pdf
http://www.microwavedisplay.com/smh9187b_smh9187w_smh9187b_xaa_sm.pdf
You can order Samsung parts from the Pros here or from Encompass here.
Dec 11, 2012 | Samsung SMH9187 Microwave Oven
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
The door won't pop open, you hear the click and you have to manually ply the door open
Since no model number was posted, I have to give a general answer.
It's likely that one of the door opening parts (most likely the door open button or lever) is broken.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
We're
Sep 26, 2011 | Viking VMOC205SS Microwave Oven
Everything works, sounds normal, but it will not heat anything.
Owners of a GE WES model might want to look at this blog post.
Hopefully its still under warranty.
If so, GE Customer Service is here.
If not, I'd replace the oven.
Jan 08, 2010 | Jenn-Air JMV8000 Microwave Oven
Cant pop popping corn
G'Day!
Unfortunately, what you're describing is a repairissue. You won't be able to address the problem with troubleshooting.There is a part inside the microwave that needs to be replaced. If you'reunder warranty, this will cost you nothing.
I hope I've provided you useful assistance and that this informationallows you to make an informed decision as to how to proceed fromhere. Please be sure to vote on my response. I hope I've earned agood rating from you today.
Please post a comment if you needadditional assistance so that I can help you further.
Jul 12, 2009 | Siemens Microwave Ovens
GE Spacemaker microwave, runs only 2 seconds, then stops
The problem you describe on your JVM1650SH02 is a failing "noisy" magnetron which is emitting electrical interference that disrupts your microprocessor.
At my Web site, I have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
You will find a technical sheet hidden behind the grille or behind the controls. It's handy for locating parts and troubleshooting.
You can find an exploded view and parts list by entering your full model number from the tag here, and you can also order parts there.
On your model, you may need to remove the oven from the wall. The installation instructions here will be helpful.
Pro tip: In many GE models, dropping the floor plate that holds the high voltage transformer is necessary to get the magnetron in and out.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 04, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Advantium 120 makes low buzzing sound all the time
this is the transformer that is doing it and it may end up failing soon , and should be replaced before any other dammage is done,
Nov 06, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Stops after 4 seconds
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
The clicking is common with inverter-related failure.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Oct 21, 2008 | Microwave Ovens
Sharp R-1500 Microwave Oven Logo
132 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
