Question about Car Audio & Video
I am loosing power to the device once the truck is running. What color wire off the ignition harness is constant?
I have installed a parrot 9100 in car bluetooth. The problem I am having is that once the vehicle is running, the device turns off. Which color of wire on the ignition harness is a constant power? they seem to all be switched.
  • 165 Answers
In most of the times is te yellow the constant.
Posted on May 13, 2009
Mki 9100 parrot to fit in my 03 plate merc clk. do i need an extra cable?
They advise using a professional installer. And I found this
http://dbinstall.parrot.com/compatibility_pdf.php?model=1031&ck=12
For the CLK there is a special kit
http://www.ebay.com/itm/MKI9100-CT10MC02-Mercedes-CLK-Class-Parrot-Bluetooth-Handsfree-Car-Kit-/141233049285
and mentions a lead
Kit Consists of the following:
  • MKI9100 Parrot Bluetooth Handsfree
  • CT10MC02 Parrot Wiring Harness Adaptor Lead
Parrot MKi9100 https://parrotcontact.parrot.com/.../MKi9100_User-guide_UK.pdf · PDF file Parrot MKi9100 - 4User guide Installation WARNING: We advise our customers to have the Parrot MKi9100 fitted by a professional. Before you begin
Dec 30, 2015 | Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1980 - 1982 Honda Civic...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1980
1981
1982
STEREO WIRING COLOR CHART:
Constant Power: White/Blue
Switched Power: Yellow/Red
Ground: To Chassis Metal
Illumination: N/A
Dimmer: N/A
Antenna: Drivers Side Pillar
Left Front (+): Red/Green
Left Front (-): Brown
Right Front (+): Blue/Green
Right Front (-): Gray
Left Rear (+): Red/Yellow
Left Rear (-): Brown
Right Rear (+): Blue/Yellow
Right Rear (-): Gray/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1388
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
I installed an mki9200 into a 2007 ford expedition but it seems to not get any power at all I am using a plug and play harness i don't know why it's not getting power
Not all vehicles have a ignition supply at the radio as they use the canbus system to turn things off and on. You will need a multi meter to check if there is power on the correct wires and you my need to pick up the ignition from the fuse box. Parrot web site has details of the accredited engineers in your area.
Jan 01, 2012 | Parrot SA Parrot MKi9200 Advanced Color...
2002 kia spectra color code ignition switch diagram pdf
PART COLOR LOCATION 12 VOLT CONSTANT WHITE/BLACK (+) and WHITE (+) IGNITION SWITCH HARNESS STARTER RED (+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 YELLOW (+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 BLUE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 GREEN (+) IGNITION SWITCH HARNESS
Dec 27, 2011 | 2002 Kia Spectra
When wiring 3200ls it wont powere down when the ignition is turned off
The ignition wire is not correct, what car are you wiring to? If your car is French, citroen or peugeot they have a timer on the ignition supply.
Dec 04, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
I want to bypass my ignition switch on 1993 suzuki sidekick i need wire colors
Here are the ignition switch wire and colors.
Constant 12V+ White/Green Ignition Switch Harness Starter Black/Red Ignition Switch Harness Ignition Black/Blue Ignition Switch Harness Accessory Yellow/Black Ignition Switch Harness
Aug 27, 2011 | 1995 Suzuki Sidekick
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 29, 2009 | 1994 Toyota Pickup
Parrot to GMC Sierra setup.
here,
When I did this truck I had to go to the amp under the center console. Good luck
#510564: 2007 GMC SIERRA C1500 2DR TRUCK
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery ORANGE (+) RADIO HARNESS
Accesory (CLASS 2 DATA) (+) RADIO HARNESS
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/WHITE (-) RADIO HARNESS
Illumination GRAY (+) RADIO HARNESS
Dimmer BROWN (+) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Amp Location UNDER CENTER CONSOLE
Steering Cntrls OPTIONAL
THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
Speed Cntrl OPTIONAL
Radio Security YES
Jan 08, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
3200 LS installed in '07 Chev Sub-Parrot Won't Power Off
try switching the red and orange wires. one is constant and one is switched. you can try by just reversing them at the inline fuses. hope this helps.
Dec 27, 2008 | Parrot 3200 Ls Color Handsfree Bluetooth...
What color is what on the clip coming out of the bak of the deck.(power,ground, left/right front spkrs, etc?
Good Day,
Good Day,
Red is ignition
Yellow is constant hot (you can wire red and yellow together if you don't have a constant however the radio will loose settings each time the boat is turned off)
Black is ground
Gray wires are front right
White wires are front left
Green wires are rear right
Purple wires are rear left
Blue is power Ant
Orange is ilumm
Hope this helps
Jul 07, 2008 | Sony CDX-CA850X CD Player
Car Audio & Video Logo
163 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
