Question about McCulloch 2000W Inverter Digital Generator # FDD210
Digital yk20001 Generator.
Want to change oil, but not sure which to use.Cannot locate our Manual
Found the Manual......THankyou.
Posted on May 12, 2009
  • Alkaye Jul 12, 2011
    we had bad storm and have no power..I need to get the invertewr working and need manual...anyone have a pdf copy?
Generator will not idle
Check that the choke isn't stuck...should be a small curved pin you slowly pull in and out. Check your manual for its location. If its stuck in one position that could be your problem. If you can't find your manual, do an online search; usually you can download one.
Apr 22, 2014 | Coleman Powermate Powermate 5000W...
How to change oil in pramac gsw 50kw towable generator?
If you have a Yanmar engine...
There is a hose that is connected to the oil pan in place of the drain plug directly under the oil filter that will have an end cap. This hose is used to drain the oil into a waste container.
Download the service manual located at the address below and follow the instructions in the manual.
http://www.martindiesel.com/Documents/New%20TNV%20DIRECT%20Service.pdf
Hope this helps.
Aug 21, 2013 | Pramac Electrical Supplies
I changed the oil four times and its still milky
If your oil is milky you are getting moisture in the crankcase. Does this unit set outside? make sure your crankcase vent is clear.
Oct 29, 2012 | Ridgid Generator. 5700 Watt Yamaha 301cc...
Oil capacity powermate 5000
With the model number of your generator, you can to the address below and download the manual for your generator. Many of the manuals do not have specific information about the engine or oil capacity.
http://www.powermate.com/productmanuals.php?cat_id=3
For specific information about the engine, look for the model number of the engine itself and go the mfg. website for loads of info. The brand and model of engine is usually located on the fan cover or stamped on the engine block. If, however you would like generic information about the engine, make sure that the oil level is correct (if dipstick, full mark, if oil plug, full to almost spilling out ) and dump the oil into container then measure. Some brands of engine recommend non-detergent others use auto type of oil. When necessary, any good quality oil is better than nothing. Good luck
Sep 12, 2011 | Coleman Powermate Powermate 5000W...
What tipe of oil makita generator g1100 takes
Great generator, i use 15/40 Quaker State it seems to work well for my uses, i have same one, but is 2000. check your manual if your really concerned, the whole thing, is keep oil fuel, and changed often. Hope this helps mike
Jun 13, 2011 | Makita G1100 1100W Generator
Within a few seconds of starting my newish Honda EU65is generator the overload alarm light goes on and the error message E-21 displays as the generator turns itself off. I have recently changed the oil...
I own the same model for 3years. Last month exactly same thing happened . In my case i send it to dealer they diagnosed ecu malfunction which need to be replaced.as im in karachi(Pakistan). It took them almost a month to import it from japan
Jan 04, 2011 | Kitchen Ranges
I have a Coleman Powermate PM0435001 5000W with a Subaru EX30D 10HP OHV/OHC gasoline engine. I want to change the oil and cant find a drain plug. Did I overlook it or does it not have a drain plug? If not...
You probably overlooked the drain plug, it is usually located on the mounting base of the engine. BUT, there have been some engines (old cheap ones) that the oil was drained by tipping the engine and draining out the oil fill. I am almost positive yours is not one of these.
Your manual is here, but that is only an "insert". It does look like the drain plug is located on the base of the engine. Find the spark plug, and the drain plug is almost directly underneath it at the very bottom of the engine.
More information is available from Subaru's website, including owners manual and especially a service and parts manuals. Your drain plug is item #13 on page 2 of the owners manual located here:
http://www.robinamerica.com/pmanuals.aspx?pid=80
Jun 06, 2010 | Coleman Powermate Powermate 5000W...
I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
May 08, 2009 | Electrical Supplies
Oil change
There are two 14mm bolts on both sides (lower) of the motor. Unscrew one or both and drain the oil....Replace with sae 30 or 10w30 oil and should take almost a quart. (Put the bolts back in and tork slightly.) Check oil level.
Jan 11, 2009 | Pramac Storm 5000 Watt Generator
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
McCulloch  2000W Inverter Digital Generator # FDD210 Logo
279 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
