Question about Dell Compact Disc Reader CDR-1900 CD-ROM Drive
My cd-rw is not present in my comuter or window exploler
By uninstalling cd-rw from devise manager and reinstalling it don't fix the problem. I tried to remove the cd-rw power cord and mother-board cord. And attached the both power and mother board plug but still my computer have a problem to intall it properly.
    Champion:
  • 208 Answers
Its likely a filter upper and lower to be exact. in english? a cd buning app added a driver that is broken now. filtercheck in cdr-zone.com forums fixed it for me many times. reinstall/repair burning app that doesn't work after removing filters.
Posted on Nov 03, 2007
The program no installed ( windows)
if you mean that the dvd is not installed
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
Jun 08, 2011 | NEC ND 1100 (50022667) DVD+RW Burner
Says dv/d8 devise is not contected
make sure that the cd/dvd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
Apr 17, 2011 | Sony (DDU1613) (ddu1613black) Internal DVD...
Can't recognise DVD RW
Hi all,
Boy, have I been having a problem. I've tried two different dvd burners, an external TDK DVD+/- RW drive and now an internal NEC dual layer DVD+/-RW drive. I have a Dell Dimension 4500 that came with a Dell branded Windows XP Pro. Have you ever tried getting support from Dell? What a freaking bad joke that is.
Microsoft says there is known problem with XP viewing a DVD+/-RW disc the same way it views a CD+/-RW disc. Problem is a CD RW uses 32 bit packets and a DVD RW uses 16 bit packets. As a result, without the fix, my computer can't recognize there is a DVD RW disk in the drive when trying to burn to it. It recognized DVD +R and DVD-R discs just fine, and I am able to burn to those with no problem.
What I want to do is image my hard drive and burn the image to DVD. That I can't do, because it always comes up with "no disk" or some variation thereof anytime I try to write to an RW disc. Any suggestions? Has anyone else had this problem?
Feb 28, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
I have a sony dvd rw dru-810a and i am having a problem with it..
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
if these fail to fix the problem
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
don
Feb 22, 2011 | Sony DRU-810A DVD RW Dual Layer Burner
Burner keeps telling me it has burned the cds to 100%, but nothing is being copied to the blank dvds
hope this helps
don
Feb 16, 2011 | Acard Technology (CD1TO7T) CD-RW Burner
Will not write dvds; under XP Pro, SP 3.
make sure that the dvd rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this dvd rw then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
if this does not fix the problem might be a registry problem
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 06, 2011 | LG GH22LP20 DVD±RW Burner
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) Laptop Levono y530, device dvd rw optiarc AD-7580s I tried to uninstall & reinstall it, but...
Give this a whirl:
CD-Rom stops working. After checking device manager you find an exclamation mark on the drive. It doesn't mean the drive is dead. It could be an upperfilter or lowerfilter registry issue that is keeping you from accessing the cd drive.
This fix worked for my client:
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Also, try this fix from microsoft.
CD-ROM access is missing and messages cite error code 31, code 32, code 19, code 39, or code 41.
Try this before replacing the drive and remember that you may have to reinstall some burning software.
Oct 16, 2009 | Lenovo IdeaPad Y530-5243U
Sound system not working, and its not the speakers
Do you have the correct drivers installed?Go to support.dell.com.Input your machine type choose the correct driver and download it.Once you have completed the download,uninstall the present drivers.Click on the file you downloaded follow the instructions this will install the drivers.
Good luck
Oct 14, 2009 | Dell Dimension 3000® Pentium® 4...
My cd rom is not reading i think it is missing a driver
The yellow triangle is signifying that there is a problem with the drive. Usually it is a driver that has gotten corrupted. Try uninstalling the drive in your device manager then reboot. See if Windows reinstalls the drive automatically. 99% of the time this will fix the problem. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 04, 2009 | Acer (4432A-002) CD-RW Burner
Computers & Internet Logo
52 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
