Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
A loud puff sound on ignition
Is this the sound all new monitors make when they ignite? Our old Monitor stove never made the loud 'poof' 'puff' noise as our NEW 2400 model does.
    Problem Solver:
  • 4 Answers
You need to have the gas valve adjusted properly.
Posted on May 12, 2009
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
Turn on gas oven; it lights, big poof/pop comes; then continues to light and heat properly. How do I stop it from popping? The pop is scary!! GE Spectra Gas Stove/Oven
The reason it "POOFS" is because the igniter is slightly weak and some gas enters before it gets lit,this will continue and get worse. To resolve it the igniter would need to be replaced and then as soon as the gas enters it would light it right away without collecting before it lit.
GENE
Oct 10, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My stove is making strange clicking noises. please help.
It sounds like the ignition knob is stuck in the "ignitor" position. Try taking it off, clean it and adjust it. If that doesn't work, it will have to be replaced with a new one. If yu leave it alone, it will probably wear itself out. Just make sure that the gas valves on the stove are in the off position so that they don't accidentally light on their own. Good luck
Jul 13, 2010 | Cooktops
Sears Kenmore Gas oven lights and relights
sounds like dirty nozzle,or not enough air to make combustion, the poof sound is when it builds up with extra gas after flame quits,and re-lights there is a bit of excess gas around igniter.
clean nozzle.altho there is lots of safety percautions built in to stove,MAKE SURE LOTS OF FRESH AIR, AND STOVE AND GAS OFF,when cleaning nozzle.
[could be air intake problem to]
Dec 19, 2009 | Kitchen Ranges
When i start my oven in mt propane stove goes puff
disassemble and **** orifices and clean , spiders etc plug up all the time , propane is nothing you want poofing when igniting!
Aug 23, 2009 | Tappan MGF500PBW Gas Kitchen Range
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
POWERED ON MONITOR, FLASHES ON, THEN GOES BLACK, MAKES NOISE
This is general LCD monitor advice. I don't know your specific model. Your problem, however, is very common on many different monitors.
In 90% of cases, the problem is one or more failed electrolytic capacitors on the power supply board. They are a simple matter to replace, but require desoldering the old ones and soldering in new ones, as well as general electrical/electronic safety practices.
If what I've just said already makes sense to you, then you're probably qualified - go ahead and replace them. If I'm talking greek, then go find an electronics nerd - some goofy looking guy wielding a soldering gun should do.
Oct 31, 2008 | Dell E196FP 19" LCD Monitor
Oven makes poofing sound when in use
hi. thanks for the question .Yes the igniter is at fault here. replace it. thanks the appliance doc
Oct 02, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven makes a poof noise when turning it on.
HI thanks for your question. the poof you hear is the gas sorta igniting because of a failing bake igniter. i would replace it thanks if you need help don't hesitate. thanks.
Aug 08, 2008 | GE Profile JGSP48 Gas Kitchen Range
Toyostove Laser 56 (F type) making loud humming noise
the toyostove is basically a glorified monitor heater.  its components are a combustion blower, an air circulator fan, a flame pot, a flat wick or burner mat, a solenoid pump, an ignition element, double  walled intake, exhaust pipe.   the combustion blower is a glorified vacuum cleaner motor. it sucks in cool air and channels it to the combustion chamber along the sides (round cylinder) kero enters on the burner mat where it ignites. the solenoid pump keeps adding kero until the flame detector spots or heats up. air flow to the pot is regulated by a damper in the combustion air blower line. if the "O" ring in the damper is missing or hardened it will not regulate the air flow which is necessary for combustion.  replace this "O" ring should take care of your problem.
Oct 17, 2007 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
353 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
