Question about Health & Beauty
Seems to charge normally but loses charge overnight
My Philips HQ7240 shaver worked perfectly until 3 days ago. Since then, it still takes the normal 8 hours to charge, but it loses its charge overnight.
  • terryking May 18, 2009
    That is correct.
  • Samuel Charles Spriggs May 11, 2010
    I understand that the shaver will charge and operate normally, but will not hold the charge -- is that correct?
    President:
  • 1,489 Answers
The battery needs replacing -- see below.
http://www.dealtime.co.uk/xPO-Philips-HQ8870
Charlie
Posted on May 18, 2009
Freezer losing temperature
Hi Julie. I'm Roger. It sounds like the operating thermostat is not working When not in the fast freeze mode. Can you here a click sound from the thermostat when turning the temperature up and down short of fast freeze? We normally charge them to operate at -10 to -20 degrees. The inside temperature will normally only reach a temperature around 18 degrees warmer. The operating thermostat should allow you to regulate its temperature any where from that capability up to where you want it. See if your thermostat makes a clicking sound when adjusted. The warning light comes on because it knows the box temperature is higher than it is set for and is warning you of that. If it uses a printed circuit (PC) board, the click will dot be very loud. listen closely. Let us know how this turns out for you. We have very good refrigeration techs. here. Someone else here may have an idea too.
Jan 23, 2014 | AEG Freezers
I installed 3 new heads but the shaver just is not shaving off my 5 day old beard... It's battery seems fine as the motor seems to be running at normal speed. Confused Carl
Your Norelco shaver is not designed for cutting 5 days of growth. Your shaver is designed for cutting one, maybe two days of growth only. Use the trimmer on the back to cut the whiskers to a shorter stubble. Then the hairs will more effectively poke through the holes and slots in the combs allowing the blades to shave them as designed.
May 08, 2011 | Norelco SmartTouch 9160XL Electric Shaver
I just ordered new batteries for my Norelco 985RX and am pretty confident I will have no trouble soldering them into place. However, I was wondering if there are any special instructions to make certain...
After correctly installing our batteries and reassembling the shaver, it will not turn on until it has been plugged in. You should then charge the batteries for 4 hours. Then use the shaver until it completely runs out of power and stops. You can then use the shaver as normal. It may take 2-3 charge cycles to maximize the battery 'chargeability'
Jan 10, 2011 | Norelco Health & Beauty
R-9190 Electric Shaver: The razor is used 20 seconds a day and used to go ...
The problem is almost certainly the batteries. You can access the batteries by removing the screws on the back and taking off the back cover. You will find batteries at shaveroutlet.com. You will need two batteries. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
May 05, 2010 | Remington R-9190 Electric Shaver
Need recharging lead for a Philips shaver
You willfind a replacement at shaveroutlet.com. See link below. Note that this is an American version and you will need a simple adapter to fit your wall outlet. Adapters are also available at shaveroutlet.com
http://shaveroutlet.com/norelco-philips-shaver-wall-charger-transformer-cord-p-270.html
May 04, 2010 | Health & Beauty
I HAD PURCHASED A HQ8140 SHAVER 1 YEAR 9 MONTHS
This problem can be caused by a malfunctioning printed circuit board inside the shaver. This usually can be fixed by fully discharging the battery then fully charging it or disconnecting the battery then reconnecting it (if possible, most shavers has their batteries soldered-in).
Jan 09, 2010 | Philips Health & Beauty
No sound
try to check if the mic and the speaker works. or check the configuration properly..
assign the right ip configuration and the connection.
Pm me if problem persists.
I hope this will help you out.. :)
thanks
Aug 08, 2009 | Philips VOIP8411B/37 IP Phone
Doesn't hold a charge or cut very well anymore
Heads for your model are no longer available. Shaver will not hold a charge because batteries need replaced. Batteries can be replaced but soldering is required. If you have cleaned it well and it does not cut, I suggest getting a new shaver.
A full line of Philips Norelco shaver can be found at shaveroutlet.com
ShaverOutlet com ShaverOutlet com Rotary Shavers Men Shavers Manufacturer...
May 22, 2017 | Norelco Advantage 5615 X Electric Shaver
Phone line gets glitched and phone gives one very short ring with error message on readout.
phones not working people are trying to call they tell me there getting a busy signal and cant get through me. I have three motorola E51 cordless phones and they are showing parallel set on the lcd screen how can i get my phones back working
Nov 18, 2008 | Motorola Mobility E51 MD7151-3 Trio...
Health & Beauty Logo
230 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
