Question about Maytag MEW6630C Stainless Steel Electric Double Oven
F7 Code stuck on
Followed instructions and replaced the Electronic clock assembly. Now the we can read the numbers (before you could hardly read them).
Flipped the power back on and are still getting the F7 Code.
  • Tim ONeil May 18, 2009
    We have a Maytag Double Oven, Model: MEW663 OCAS and I did try take it all apart and let it sit for 30 minutes. We will try and replace the touchpad, it is easy. Thanks,
  • Pataricia Nolte
    Pataricia Nolte May 11, 2010
    What brand modle is it.
  • 62 Answers
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button
Posted on May 12, 2009
  • Pataricia Nolte
    Pataricia Nolte May 12, 2009
    Did you replace the touch pad as well? Thankfully they are not as much as the erc. Sometimes you can reset you erc by unplugging it for at least 30 min if not more and then plugging it back in.
F7 error code
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Ovens
The oven is randomly beeping and the display is reading f7
F7 error code is displayed when the clock assembly/electronic oven control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Apr 10, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
Fault Code "F7"
Kevin
Mar 07, 2011 | Maytag CWE5800A Electric Double Oven
F7 CODE
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
F9 Program w/ door circuit Check wiring
Mar 21, 2010 | GE Built-In 24" Double Electric Wall Oven
Error f7 oven wont turn off
Hello there:
The f-7 error code carries several different possiabities
here are several possiable reasons and the things to check
1. F5 or F6 or F7 EOC (Electronic Oven Control) failure Replace EOC(Electronic Oven Control)
2.
F7 Shorted touch panel Replace glass panel
3.
Replace clock assembly (also called the ERC)
Please test each of these carefully ok and if you disconnect the board you may want toclean the contacts really good and then try to reconnect the wires and make sure that they are properly connected ok
Best regards Michael
Jan 12, 2010 | Ovens
I am getting an F2, then an F5 followed by sometimes an f7 error code and inconstant temps.
the f 2 code is ( oven too hot ) the f 5 ( watchdog circuits disagree / and f7 ( function key shorted or stuck button .. / the clock ( erc ) may have a warped face . ..I would first replace the tempt sensor in oven . if you still have problem repl clock. and problem over .. thank mm ..
Dec 02, 2009 | Maytag CWE5800A Electric Double Oven
I got an F7 error code and now the display is blanked out. JTP20 series wall oven
F7 Stuck Button
1. Function pad button stuck or
2. Bad clock. Try to free stuck button or
3. Replace Electronic Range Control (ERC).
Nov 25, 2009 | GE JTP20 Electric Single Oven
F7 Code on my GE Profile Oven
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
Double GE wall oven - F7 code
from repairclinic.com:
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
F7 fault code on the Jenn-air W30400W
The F7 error code on your oven indicates the touch pad has failed. To repair it you will need to replace the touch pad which is listed as a control panel w/keypad in the parts diagram.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that hold the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touchpad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
Hope this helps .
Mar 04, 2009 | Ovens
Maytag MEW6630C Stainless Steel Electric Double Oven Logo
386 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
