Question about Logitech Audio Players & Recorders
Logitech pure fi 2 not charging
Logitech Pure-Fi 2 Anywhere Portable Speakers for Apple iPod got it for mothers day. will not charge from the mains? seems this is common.
proton77
  • 1183 Answers
SOURCE: Logitech Pure-Fi Elite Speaker System
Two things,
1. You get static charged , from your surrounding ,ie the couch or bed you are sitting in or the the chair you are one before you go and disconnect the ipod.
2. The Logitech is not properly grounded. Check for missing rubber pads below. Also check the earthing at the wallsocket where it is connected
Thanks
proton
Posted on Aug 03, 2008
SOURCE: malfunctioning connection on ipod ''logitech pure-fi anywhere2''
phoned logitech today who have offered to replace the docking station free of charge as it was under warrenty.Will probably stick with them as a company
thanks for your offer of assistance will bear you in mind for a more complicated problem
Posted on Feb 09, 2010
SOURCE: Change Clock - Logitech Pure-Fi Elite
Here are the instructions from the User's Guide for the Logitech Pure-Fi Elite Audiostation/iPOD Dock:
To activate the large clock display while the Audiostation is on:
1. Tap "select" several times - until the large clock display appears.
To set the current time:
1. Turn Audiostation on. (OK I'm good so far)
2. Tap "select" several times - until the large clock display appears. (If you have previously set the time and are "changing " the time, this is the default display, so just skip this part)
3. Press and hold "select" until "clock setting" appears. (It takes 3 seconds and my unit displayed the "12 or 24? " screen instead of "clock setting". )
4. Use the Up/Dn arrows to change the time. Use "select" to accept the changes.
Here's the Quick & Dirty:
I assume you use it as a clock so the time is already displayed. Turn the unit on.
Press and Hold "select" until "set time" appears.
Press "select" again to next screen, (12 or 24 hr?)
Press "select" again for the hour, and soforth.
Use the Up/Dn arrows to adjust the units.
Posted on Feb 18, 2010
award462
  • 395 Answers
SOURCE: Need Logitech Pure-Fi Elite users manual
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
SOURCE: How to open the pure-fi anywhere 2 (Logitech)so th...
I just got my Pure-Fi Anywhere (must be "1," because it doesn't say "2" on the box.) apart to both replace the battery (Ebay, $12-$15), and tighten the screw on the swivel leg.
1) Don't use a screwdriver or anything steel - you'll bugar up the plastic if you do. I used the plastic "prying tools" that came with the battery replacement kit for my iPod. I...
2) Wedged in pretty hard behind the faceplate that encircles all four speakers. This faceplate is about .080" thin. Once I saw that I could force these plastic tools in there, I carefully slid them around and loosened the whole plate. This plate is stuck on with, I guess, some kind of glue - but it remains sticky. I haven't reassembled anything yet, but I think it will go back on and stick again (careful where you set it).
3) Removing this thin plate reveals a bunch of screws. You only need to remove the eight black (larger) screws (ignore the six silver (smaller, flathead) screws - they don't need to come out).
4) Now for more prying (you got those eight larger screws out, right??) - I used the same plastic "prying tools." The best spot for this turned out to be: a) on the top; b) the side OPPOSITE of all the control buttons (power, volume, shuffle, etc.) -- halfway between the middle (iPod cradle) and the end (the opening is about 1/2" back from the front of the speakers. I forced the plastic tool in there, then twisted it and the two pieces seperated (with some effort)(you did remove those screws, right?). I worked the plastic prying tool around CAREFULLY, and eventually had complete success in seperating these two pieces. The wires from the battery are the only thing now connecting the two pieces together.
If you went this far, you don't need me to tell you about the battery or how to tighten the feet. But I DO want to express my irritation at the "expert" at the Logitech forum site: He told a questioner that "you don't want to open up the speakers, it will reduce the acoustics if you do..." Again, if you've gone this far, you can see that nothing done here could have anymore adverse affect on the acoustics than opening your car's trunk would affect the car speakers in the back.
Posted on Sep 12, 2010
Logitech portable ipod deck
if the ipod itself is fine then there is a problem either in the connections or in the speakers.
Jul 12, 2008 | Logitech Pure-Fi Anywhere Portable...
Logitech pure-fi Anywhere 2 Remote Control not working. Tried a new battery & still not working? any suggestions?
I received my anywhere one week ago, the remote didn't work, reracking several times didn't help, I replaced the battery with minus to plus vv. and then put it in again properly, working flawlessly since. Logitech won't advise this method but it's worth trying.
May 21, 2010 | Logitech 984-000057 Pure-Fi Anywhere 2...
Malfunctioning connection on ipod ''logitech pure-fi anywhere2''
Feb 08, 2010 | Logitech 984-000006 Pure-Fi Anywhere...
The remote just doesn't work
I had a similar problem, my speakers are only a month old, and the other day, all the buttons on the remote just stopped working except for the volume and power buttons.
I just pressed the reset button on the bottom of the speakers and it seems to of done the job, so maybe you could try that :)?
Hope this helps..
Jan 23, 2010 | Logitech Pure-Fi Anywhere Portable...
Unit cuts off after 1-2 minutes of playback; does not recharge ip
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/7207/session/L2F2LzEvc2lkL2VvbmE0eGdr
Nov 17, 2009 | Logitech Pure-Fi Anywhere Portable...
Does the logitech pure fi express take the new ipod nanos
Hi Jod,
The Logitech pure fi express only support Ipod/Iphone up to 3Generation, please note that Iphone 3GS is not currently supported.
Thanks and have a nice day
J -
Oct 26, 2009 | Logitech Pure-Fi Express Portable Speaker...
Logitech Pure-Fi Anywhere Portable Speakers for Apple iPod . It keeps shutting off after a few minutes. It's plugged into a wall outlet.
Many have reported the same issue, reset the pure-fi with the reset switch (on bottom) while it is turned on, then put your iphone/ipod at 75+ % of volume before/while playing.
Feb 21, 2009 | Logitech Pure-Fi Anywhere Portable...
How do I get off Military time?
Sorry if this posts twice...
To reset your Pure-Fi Anytime, do the following:
Press and hold the Source and Preset 2 buttons (shown below) on the top of your Pure-Fi Anytime for 5-10 seconds.
NOTE: The reset procedure will restore the Pure-Fi Anytime to factory defaults and all presets will be cleared.
Jan 21, 2009 | Logitech Pure-Fi Anywhere Portable...
518 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
