Back to:
Tags:
Projection Televisions
Generic problem for all Projection Televisions
Tv repair (by 18 users)
posted by muffy_36 on Oct 13, 2007
i have a big screen tv from RCA when i push the power button nothing happens what could be the problem
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
17 Other Users Have The Same Problem
Comment by ppkymhb, posted on Nov 17, 2008
i have the same problem. My model is a panasonic pt-61sx60.
Comment by deivn_h86, posted on Nov 15, 2008
i have a 62" rca projection model#r61wh76 chasis#itc222a
i just hooked up an x-box 360 played it for a while and turned it off, went to turn on the tv the next morning and it wouldnt come on, the light comes on like it is trying to turn on but nothing happens, and the light turns off after adount 10 seconds what should i do
Comment by clingen766, posted on Nov 12, 2008
the model is: 50ML8105D/17
serial #: AP2B0527000265
it was made in July of 2005
I have the same poblem, what's up?
Comment by lfatland, posted on Nov 09, 2008
I have the same problem , no response when turning on. Model PS52690 sn 545600148 , chasis no: PTK 188AB
Thanks
Solution #1
posted on Oct 13, 2007
Not Rated (0)
Terryfic
Rank:Guru Guru
Rating: 88%, 1468 votes
Please provide service number and chassis # from back of
set,then I can help.T.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on tv repair:
I don't want to Accept this solution
Can you Help with these Projection Televisions problems?
kv.chk.kh.
the power want stay on
red shadow in background
Hi I use my Compaq Ipaq MP3800 projector to watch movies...
i get a red/blue/green static at the top of my plasma tv.....
17 Other Users Have The Same Problem - Continued
Comment by jmullins00, posted on Nov 04, 2008
I have same problem. TV was fine and then suddenly it turned off shortly after turning on and has not been able to turn back on.
Comment by Theelopeone, posted on Oct 19, 2008
i push the power button nothing happens tried different outlets an everything even reset button
Comment by cityview, posted on Oct 10, 2008
I have an RCA p56830bl big screen tv. When I plug it in the wall and push the power button, nothing happens. I checked the fuse and voltage going into the TV and they are both fine. Any iteas?
Comment by mack-2007, posted on Sep 26, 2008
No power on rca P46732BA. first the power button stopped working and now not turn with remote. Remote and outlet ok. I thought next to check are fuses. Is it safe to open the back and how many fuses to check.
thanks for any info or help
regards
mack
Comment by csm_266, posted on Jul 24, 2008
RCA Projection tv, model number:P46729BA. Unplugged and rolled across the room, plugged back in and now it won't turn on. Tried with remote and buttons on the tv. The outlet is fine everything else has power. Please Help!!!
Comment by Shell737, posted on May 14, 2008
Sorry I forgot to tell you the tv model...RCA P46729BA, chassis PTK169PCA. The on switch isn't working. what now?
I hit the on button and nothing happens. I checked the power plugs and all are working for the other components sitting on top of the TV such as a tuner and DVD player. Could it be a power switch problem or perhaps a fuse of some kind?
Comment by kreilly, posted on Feb 24, 2008
I just received a RCA P46730WK (chassis PTK169PCA) for free. I have been repeatedly assured that it was in perfect working condition before I picked it up. It was lacking a power cable, so I ordered one (and a new remote just in case). The set will not turn on with either remote (new or old) or the power button on the front. The clear glass fuse inside the back panel near the power input appears fine - wire is intact, no fog on the glass.
The set hasn't been powered up for weeks... do these sets need to "charge" prior to power up? Could something have been shaken loose during the move? We were very careful moving it and it was tightly secured in the truck for the trip.
Can I test the power-up by just plugging it into the wall, or should it run through the cable box with all cables connected?
Comment by mike38, posted on Jan 05, 2008
none
Comment by babarca123, posted on Jan 01, 2008
I have RCA 52 ' tv and it just went pop pop last night , now if I push the power button the speakers click couple times but the screen stay black nothing happen, I can hear some kind other click sound like a protection mode.
any help is appreciated
Comment by bigbone, posted on Dec 24, 2007
Shut Tv off rolled across room, then tv would not power up.
Comment by berardi, posted on Nov 16, 2007
Loading problems.
Repair Service
Find Projection TV Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
