Question about Hotpoint RGB745 Gas Kitchen Range
How to locate and remove oven ignitor
Do not hear clicker to ignite gas or smell gas when press electronic oven button
  • 473 Answers
Will need to remove the panel at the bottom, inside of the oven.  Some have another panel under that, yours may not, to remove.  The ignitor is under that in the back middle.  Should be screws that mount the ignitor to the burner.  You may be able to remove the bottom drawer and unplug the ignitor underneath the oven and remove the ignitor.  If not you can cut the wires on the old ignitor and splice in the new one using ceramic wire nuts.  Let me know if this helps.
Posted on Oct 14, 2007
I have a GE Hotpoint stove/range model num 317B6641P001 that the oven will not ignite nor will the igniter turn on.
It sounds like the ignitor is will not or should not smell gas if ignitor is bad...gas valve is not supposed to open until the sensor by the ignitor has reached a certain temp. It's a safety feature. If you replace the ignitor, it should work like normal.
Jan 31, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
When you turn the knob you dont smell gas, don't here the click of the igniter, but would like to light the oven manually. Can you help me please.
you can't manually light the oven with a match anymore,you have an electronic ignition in the oven or an ignitor part number 5303935066 and it's around 60 have to remove the racks,remove the floor of the oven and then remove the cover and you'll see the ignitor in the back screwed to the tube usually with two 5/16 inch screws. set the oven to bake on 350,if the ignitor glows but doesn't light in 40 seconds it's bad,if it doesn't light at all you can unplug the ignitor and check it with a meter for continuity but most likely you have a bad ignitor.wet a paper towel and wet the two screws,they will come out easier,you can't use wd or anything like that because it will smell when you turn the oven on so use water, if you can see where the disconnect is to unplug the ignitor unplug it or when you get the screws out cut the two wires close to the ignitor,the new ignitor comes with ceramic wire nuts so you can connect the two wires you just cut to the new ignitor,the wires on the new ignitor will be long,you can screw the new ignitor on,leave around 6 inches of wire on the new ignitor so the wire connectors will be away from the tube and not up near the floor and if you have the ignitor screwed on you can see how long to make the wires,cut the wires and strip the ends on the old and new wires and wire nut them together.then turn it on to bake,when the ignitor starts to glow it sholud lite the flame in less than 40 seconds.hope this helps you more thing don't touch the piece of the ignitor that's inside the metal bracket,they break very easy.good luck and have a great holiday.
Nov 20, 2011 | Tappan TGF320 Gas Kitchen Range
Ignitor glows but burner doen't ignite. Don't hear any gas flow or smell any gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Jul 26, 2011 | Ovens
My gas oven quit working. I hear it click and I smell gas but it never ignites. I hope it is something simple like a thermal couple. Does it have a thermal couple?
if it clicks,AND u smell may have a faulty burner.the ignitor IS what opens the gas valve...determined by the amount of wattage the ignitor/thermocouple is pulling...some ignitors get weak and need replaced anyway after 6 or 7 years.
Mar 03, 2010 | Ovens
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Oven's ignitor is bright, I smell gas, but it won't lite.
    if ignitor is brt orange to white its hot enough to ignite gas,either the flame sensor is giving wrong signal to control board and not opening gas valve or signals the gas valve to shut off gas before ignition,also your flame sensor could be faulty or control board is bad
    Jul 26, 2009 | Kitchen Ranges
    Tappan TGFS26C, Oven igniter not even
    Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
    I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
    Hope this helps.
    Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
    GE Oven does not light - no gas smell and no electronic ignition clicking sound
    Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
    Jul 21, 2008 | Kitchen Ranges
    If you smell gas, then check the ignitor circut first. A spark ignitor usually has a grey or orange wire, leading from the ignitor to the input circut. Try testing the terminal where the ignitor is powered, when the unit should be calling for ignition. If there is ample voltage to the ignitor, but it will not spark, shut off the power and the gas to the appliance and remove the pilot assembly. The ignitor will either unclamp or unscrew from it, and can now be replaced. Check to see if it is properly spaced (which it should be if undisturbed), or if any deposits are on it. Sometimes they can be properly spaced or cleaned to work once again.
    - Ian Miller
    Apr 11, 2008 | Vulcan Convection Oven - VC44EC-208-1
    It probably needs an oven igniter. Remove oven racks. Remove oven floor. Usually 2 screws towards back. Remove flame spreader if it has one. You can see long tube with holes in sides and igniter with 2 wires from rear. Now try oven. See if igniter glows. If it does but doesn't light within 1 minute, replace igniter.
    If it doesn't glow, you need to check for power to igniter. Should be about 100 volts. If not may need ERC, "Electronic Range Control".
    Nov 19, 2007 | GE JGRP17 Gas Single Oven
    Hotpoint RGB745 Gas Kitchen Range Logo
    238 people viewed this question
    Top Hotpoint Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Justin Duby
    Justin Duby
    Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
