Question about Leadtek WinFast TV 2000 XP Expert (tv2000xp-ext) Video Capture
Audio I cannot get the audio to word and i do not have the cd/aux in connector on my motherboard.  I'm running 64 bit vista
  • 231 Answers
Hi, try logging onto the manufacturers website, click on download & support. Locate your mobo number and see if there is a Vista Driver. There may not be one available yet.
If there is not then purchace a PCI sound/audio card [realitively cheap] and install that. Just make sure that it is Vista compatable before buying it.
Regards mistyman
Posted on Oct 15, 2007
Can't detect XP discs in win 64 bit
Hello Joe, 64-bit processing is faster than 32-bit processing because the CPU is handling more bits at once, However, a 64-bit OS requires more resource than a 32-bit OS, A 64-bit OS requires that device drivers operating in kernel mode be a 64-bit drivers, These drivers must be available from the device manufacturer. An application is compiled to process 64-bit or 32-bits. A 64-bit OS can run either 64-bit applications or 32-bit applications, but 64-bit applications are faster also 64-bit applications cannot run on a 32-bit OS.
A 32-bit OS can only address up to 4 GB of memory, More than that might be on the motherboard, but the OS cannot use it, because it does not have enough memory addresses to assign to the physical memory. A 64-bit OS theoretically can address up to 1 terabyte of memory although in practice, most motherboards can only hold from 12 to 16 GB of memory.( A terabyte is roughly 1000 GB or 1 trillion bytes). If you open many applications at the same time and have high computing needs and enough hard drive space and memory, you can benefit from 64-bit computing. To get most out of it, the processor, motherboard, operating system, drivers and applications must all be 64-bit, and you should have installed the maximum amount of memory the motherboard supports.
Mar 16, 2013 | ASUS G74s Cd-rw Dvdrw Super Multi Drive...
I have asus p4s800d-x m/b with integrated soundmax audio. icant install sound driver on oc win7x86bit. all other drivers working properly with win 7.
The motherboard is too old for windows 7 audio drivers. You may want to try 64 bit Vista drivers. They may work, but I wouldn't hold your breath. P4 motherboards were only just around when Vista was released. and most of the time they wouldn't run with a 64 bit operating system. Or you could switch off the onboard audio and add a windows 7 capable audio card.
Mar 06, 2013 | Computers & Internet
G31 hi com motherboard audio drivers for windows 7
Realtek AC'97 audio driver package. The package includes: driver setup program, drivers for Vista/Windows 7 32-bit and 64-bit editions.
hope this helps you
Oct 19, 2011 | Computers & Internet
I installed Windows 7 in the Asus M2N-MX series motherboard but could not load audio drivers. Where can I dowload audio driver from?
The drivers for Vista should work just as well for Windows 7. This is true with almost everything about Windows 7; in fact, Windows 7 is actually NT kernel 6.1! (Vista is NT kernel 6.)
1) Go here: 2) Type M2N-MX into the search box on the left. 3) Select M2N-MX from the results. 4) For your OS choose Vista 32-bit if you installed the 32-bit version of Windows 7 or Vista 64-bit if you installed the 64-bit version. 5) Have fun.
Good luck.
Mar 01, 2011 | ASUS M2N-MX Motherboard
Specifications only
CPU º Socket 478 for latest Intel Pentium 4 / Celeron processor
º FSB 533/400 MHz
º Support Hyper-Threading Technology CPU
CHIPSET º VIA® P4M266A & VT8235
º North Bridge: VIA® P4M266A
º South Bridge: VIA® VT8235
GRAPHICS º Integrated S3 ProSavage8 2D/3D Graphics
º Share Memory : 8/16/32MB
MEMORY º 2 x 184-pin DDR DIMM socket support up to 2 GB
º Support DDR266/200 DDR SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
º 3 x PCI slots
º 1 x CNR slot
STORAGE º Support by VIA® VT8235
• 4 x Ultra DMA133/100/66 devices
AUDIO º Realtek ALC655 6-Channel audio CODEC
º Compliant with AC'97 2.3 specification
LAN º VIA® VT6103 10/100 Mbps Fast Ethernet PHY
REAR PANEL I/O º 1 x PS/2 keyboard & PS/2 mouse connectors
º 4 x USB ports
º 1 x RJ45 LAN connector
º 1 x VGA port
º 1 x Parallel port (LPT)
º 1 x Serial port (COM1)
º 1 x Audio port (Line-in, Line-out, Mic-in)
INTERNAL I/O CONNECTORS & HEADERS º 1 x 20-pin ATX Power Supply Connector & 4-pin 12V Connector
º 1 x FDD connector supports one 360K~2.88MB FDD
º 2 x IDE connectors
º 1 x IrDA for SIR header
º 1 x SPDIF out header
º 1 x USB 2.0 header support additional 2 USB ports
º 1 x Front panel switch/LED header
º 1 x Front panel audio header
º CD in/ AUX in headers
º CPUFAN/CASFAN connectors
SYSTEM BIOS º Award BIOS with 2Mb Flash ROM
º Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
º Supports ACPI revision 1.0 specification
FORM FACTOR & LAYERS º Micro-ATX Size (244mm*244mm), 4 Layers
for more detail look at this site
i hope this helpful
thank you for using fixya
Feb 06, 2011 | EliteGroup P4VMM2 V8.1 Motherboard
Where can i find audio drivers for vista 64-bit
"Cut and Paste to your search engine":
Feb 01, 2010 | ASUS P5PE-VM Motherboard
Audio Problem
Intel Desktop Board D945GCNL HD Audio Controller 5605 Windows Vista(32/64)/XP(32/64)/2000
Installs the Realtek audio driver version 5605 for Intel® Desktop Boards.
IMPORTANT: Audio drivers may fail to install in Windows* XP 64-Bit Edition. Symptoms may include error messages, such as "Error in installation" or "Unknown error". Microsoft's Update for Windows XP x64 Edition (KB901105) fixes this issue. After installing this update, the audio drivers for Windows XP 64-Bit Edition will successfully install.
Apr 23, 2009 | Intel D945GCL Motherboard
Get windows vista home premium
You can run a 32 bit technology OS on a 64 bit technology platform.
It will run pretty fast.
You just can't run a 64 bit technology OS on a 32 bit technology platform, though the 64 bit OS is recommended on a 64 bit platform.
Love your brother, he did you no wrong.
Mar 30, 2009 | Dell 24x CD±RW/DVD Serial ATA Internal...
No audio
i need to help.
my motheboad have audio problem,
i need audio device for install.
sis mother board, 5595 chip
Jan 30, 2008 | SIS741GX-MN Motherboard
Leadtek WinFast TV 2000 XP Expert (tv2000xp-ext) Video Capture Logo
139 people viewed this question
Top Leadtek Televison & Video Experts
Are you a Leadtek Televison and Video Expert? Answer questions, earn points and help others
