Question about Toshiba 26AV500U 26 in. LCD HDTV
My lcd screen in my toshiba 26av500u has been damaged and no longer works. It was made in Jan. 2008. I know replcements are expensive, but does anyone know where they even sell one? I have been searching the net for a long time with no results. Thank you for your help! Also Is getting the screen out of the plastic frame tricky or does it come right out after screw removal? I need to get at the part # on the screen. Thanks again!!
  • nelkota May 12, 2009
    Thank you for taking the time to answer!! Greatly appreciated!!!!!!!!
    President:
  • Toshiba Master
  • 1,779 Answers
Toshiba part # 75008418. It is available from Encompassparts.com
$ 883.28
- 432.95
$ 450.33 is your total after mailing back the old one for the 432.95 dud credit.
Posted on May 12, 2009
Toshiba 26av500u does not retain the input setting on power off
Main system control memory IC fault. Replace it. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 27, 2014 | Toshiba 26AV500U 26 in. LCD HDTV
Toshiba 26AV500U This is being used as a 2nd set connected to a DishNetwork receiver. The set must be tuned to channel 73 to receive the signal, and no matter what I try the TV will not recognize 73 as a...
Tries tv unplug,replug it back like about an hour later.For forcing the tv do a resetting itself back to the factory setting.The tv now should be recognizing channel 73.
Feb 26, 2011 | Toshiba 26AV500U 26 in. LCD HDTV
My Toshiba flat screen appears to have several dark shadows in the center of the screen. It almost appears as though there are tornados within the picture. A tech looked made the conclusion that the...
Exact same thing happened to my Toshiba. Purchased at Costco in Dec 2008. I haven't received any help either. Guess I will be buying a new tv. Not Toshiba ever again. Let me know if you found any way to repair.
Feb 09, 2011 | Toshiba REGZA 52RV530U LCD TV
Olevia 47 inch LCD TV - Model 247TFHD purchased in Jan 2008 - had a bunch of updating going on on the screen when I had to refresh Comcast - don't know if the messages were from Comcast or where; a few...
i a olevia 47inch flat screen lcd and a sony camcorder i'm trying to use the DV and AV ports and my problem is which cord do i need to use so i can watch tapes on my TV. model number for camcorder is sony DCR-TRV480.
Sep 16, 2009 | Televison & Video
How do I change the screen size on my Toshiba 26AV500U. Example: On CNN I can't see what is scrolling across the bottom on the screen.
The "PIC SIZE" button on the top of your remote will change the picture size. Keep pressing the button to find the screen size you like and works best.
May 13, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Lcd toshioba tv 42'' damaged screen could it be repaired
If you mean cracked or smashed when you say "damaged", the answer is yes, but it would be far less expensive to buy a new set!
We are an authorized service center for Toshiba. The replacement LCD panels are typically more expensive than the entire set was new! Go figure...
www.mcveyelectronics.com
May 03, 2009 | Toshiba 42HL167 42 in. LCD Television
Problem with TOSHIBA LCD 26AV500A
Only advice I have is use the Warranty. Take it back to the store.
Sorry I can't help more.
Good luck
Feb 04, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
DVD picture is in Black & White only.
Are you trying to play an NTSC disc in a PAL player, If so,your player has a switch or
on-screen setting to select the output format for NTSC discs,
Or maybe you have connected one of the component outputs (Y, R-Y, or B-Y) of
your DVD player to the composite input of your TV.
Please rate this solution
Jan 20, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Need InfraRed CCF codes for Toshiba 26AV502U
i know you posted a few months ago, but i recently found the code. its 0156.
Jan 04, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Toshiba 26AV500U 26 in. LCD HDTV Logo
177 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
