Question about Apex Digital GB55HD09W 55" Rear Projection Television
My 4 years old Apex GB51HD09 TV is not turning on. Pushing power switch only turns the green LED ON. No picture & No sound. All voltages from the power supply reads OK. Please help.
  • 6 more comments
  • Hirmiz Youkhana May 12, 2009
    Which transformer mean ?
    Need an answer from someone who knows what the hell I am asking for.
    Thanks.
    Read my question again please.
    I did say that all voltages from the power supply reads OK.
    None of the fuses is blown.
    I know all this.
    I been repairing consumer electronics for over 30 years.
    But first time with Apex projection TV.
    I believe one of the voltage protection sensors is drifted.
    Don't waste my time if you don't know the right answer please.
    Thanks.
    Still waiting for the right answer
    Need answer only from some one who have past experience with this Apex model please.
    I am getting sick & tired of your stupid answers.
    Need to refund my money ASAP please.
    Thanks.
    Not interested any more.
    Please refund my money.
    Thanks.
  • 4,472 Answers
I am sorry you feel that way. Being the expert that I am I know the frustration you are feeling from experts that don't know what they are talking about so rather then annoy you further you can contact premium.support@fixya.com about getting a refund. If you still need assistance or do not hear back from them after a few days please respond and I will contact them myself. I hope you reconsider and try fixya again as there are some experts that are not only here for the money but to actually solve peoples problems as well. Sorry again and good luck,
Lee
Posted on May 13, 2009
  • Apex Digital Master
  • 13,433 Answers
Contact premium.support@fixya.com to discuss that problem.
Posted on May 12, 2009
  • 3,267 Answers
Have you gone through this and adhered to it for proper grounding. Quote
"NOTE TO CABLE INSTALLER lN THE USA:
This reminder is provided to caIl your attention to
ArticIe 820 - 40 of the NEC that provides guide-
Iines for proper grounding and, in particular,
specifies that the cable ground shaII be connected
to the grounding system of the building, as
cIose to the point of cable entry as practicaI." unquote. Also the prliminary precautions are extremely imp. Power Sources - The TV set should be operated only from the type of power source indicated on the TV set or as indicated in the Operation Manual.
If you are not sure of the type of power supply in your home, consult your local power company. For TV sets designed to operate from battery power, or
other sources, refer to the operating instructions.
Alternate Warnings - This plug will only fit into a grounding-type power outlet. This is a safety feature.
If you are unable to insert the plug into the outlet, contact your electrician to have a suitable outlet installed. Do not defeat the safety purpose of the grounding
plug.
Water and Moisture Warnings - Do not use the TV set near water-for example, near a bath tub, wash bowl, kitchen sink, or laundry tub; in a wet basement;
or near a swimming pool; and the like. The TV set should not be exposed to dripping or splashing and no objects filled with liquids, such as vases,
should be placed on the TV set.
Ventilation - Slots and openings in the cabinet are provided for ventilation and to ensure reliable operation of the TV set and to protect it from overheating,
and these openings must not be blocked or covered. The openings should never be blocked by placing the TV set on a bed, sofa, rug,or other similar
surface. This TV set should not be placed in a built-in installation such as a bookcase or rack unless proper ventilation is provided or the manufacturer's
instructions have been adhered to.
Grounding or Polarization - Do not defeat the safety purpose of the polarized or grounding-type plug. A polarized plug has two blades with one wider
than the other. A grounding - type plug has two blades and a third grounding prong. The wide blade or the third prong is provided for your
safety. If the provided plug does not fit into your outlet, consult an electrician for replacement of the obsolete outlet.
Heat - Do not install near any heat sources such as radiators, heat registers, stoves, or other apparatus (including amplifiers) that produce heat.
A product and cart combination should be moved with care. Quick stops, excessive force, and uneven surfaces may cause the TV set and cart combination
to overturn.
Accessories - Do not place the TV set on an unstable cart, stand, tripod, bracket, or table. The TV set may fall, causing serious injury to a child or adult,
and serious damage to the TV set. Use only with a cart, stand, tripod, bracket, or table recommended by the manufacturer, or accessory recommended
by the manufacturer, or sold with the TV set, and should use a mounting accessory recommended by the manufacturer.
Power-Cord Protection - Protect the power cord from being walked on or pinched, particularly at plugs, convenience receptacles, and the point where
they exit from the TV.
Overloading - Do not overload wall outlets, extension cords or integral convenience receptacles as this can result in fire or electric shock.
Cleaning - Unplug the TV set from the wall outlet before cleaning or polishing it. Do not use liquid cleaners or aerosol cleaners. Use a dry cloth for
cleaning the exterior of the TV set.
Attachments - Do not use attachments not recommended by the product manufacturer as they may cause hazards or electric shock.
If a snapping or popping sound from a TV set is heard continuously or frequently while the TV set is operated, unplug the TV set and consult your dealer
or service technician. It is normal for some TV sets to make occasional snapping or popping sounds, particularly when being turned on or off.
Lightning - For added protection for this TV set during a lightning storm, or when it is left unattended and unused for long periods of time, unplug it from
the wall outlet and disconnect the antenna or cable system. This will prevent damage to the product due to lightning and power-line surges.
Object and Liquid Entry - Never push objects of any kind into the TV set through openings as they may touch dangerous voltage points or short-out
parts that could result in a fire or electric shock. Never spill liquid of any kind on the TV set.
You may find this interesting:
may find the foIlowing booklet prepared by the FederaI Communications Commission helpfuI:"How
to ldentify and ResoIve Radio -TV Interference Problems". This bookIet is available from the US Government
Printing Office. Washington, D. C 20402, Stock No. 004-000-00345-4..Please post the result as a comment if needed to dig deeper.........sodeepMy 4 years old Apex - moz-screenshot.jpg
  • 1,170 Answers
Your unit is turning itself off so as not to inflict further hazardous damaged. as long as it is not corrected and repaired properly it wont start the normal way. theres a possibility of power supply malfunction, might be producing a high output voltage or not producing at all. there is also probabllity on the horizontal deflection circuits maybe the flyback transformer is misbehaving or the horizontal output transistor is not working might be shorted or open.
Hope I helped with the repair of your problem.
An Accept from you is how I get paid.
And a positive feed back tells me how I did with the repair.
Arjun.
  • 3,230 Answers
You need to check the fuse first.... many times the fuse works only on a half way.
Try changing the fuse first.
Good Luck!!
  • Mukesh Kumar May 12, 2009
    well,
    The main power is 5V, normaly always ON.
    12v also but switched by a transistor (detected by the 24v)
    Power On should be biased via 2,2 KOhms with 5v.
    the simple mean -- some register had power loss.... you need to check all main board registers to find out the power loss.
    Ok Sir,
    Just take help with some other Expert.
    Regards all-guru
    Thanks
    Sergeant:
    Champion:
  • 219 Answers
Hi, I had the same problem yesterday. My uncle is a tv repairman for a major electronics chain. He came by last night and had a look at it. It turned out to be a very inexpensive transformer that went bad. The part itself is only a few bucks. Hope this helps and its not too late.
Thanks! Sandy
  • Sandeep Gupta May 12, 2009
    well there is a small transformer.I dont knw much abt that but it was a small transformer.U call a service person hw will fix it.
    Thanks!
    Sandy
My veon 32" has no picture but sound only
Hi my veon tv is 50inch LED turning on green then off red but no picture it had sound but not any more so no picture or sound can't find reset either and is 2 years old please help.thank you
Nov 24, 2013 | Televison & Video
I HAVE A 51 IN APEX TV WHEN I TURN ON THE TV IT HAS PROBLEMS WITH CONVERGENCE IT HAS RED LINES BLUE & GREEN WHEN I GO AND GET THE REMOTE AND GO TO CONVFRGENCE ON THE MENUAL I PUSH RIGHT ON THE REMOTE...
Tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must require replacing,to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Apex Digital GB51HD09 51" Rear Projection...
Apex GB51HD09 convergence
Please have it taken care of ASAP. It definitely sounds like Cold Solder joints on the convergence IC's. Cheap repair now, if you stop playing it. Every-time the convergence goes out, the ic's struggle to bring it back in and can't and therefor over heat. so please have it taken care of Pronto. Apex used a Samsung chassis which was a good chassis in that PTV.
Aug 19, 2009 | Apex Digital GB51HD09 51" Rear Projection...
Service menu
The volume on my tv just stopped working.
Apr 15, 2009 | Apex Digital GB51HD09 51" Rear Projection...
Insignia lcdtv32 poewr on but no picture
You need to check the 12 or 24v source coming from the power supply to the inverter board, that's the board usually to the left and rather tall. Get your meter set, then turn the set on and see what happens, if the voltage comes up and then shuts down, you'll need to pull the plug for the inverter and measure the voltage again. If it stays up you have a bad converter board, if not then it's in the power supply, that's good old fashion trouble shooting from there on.
Feb 26, 2009 | Televison & Video
Samsung TSL3293HF HDTV - TV in Stale State-No picture or audio
I HAD A REPAIR GUY OUT TODAY AND HE SAID IT WAS THE POWER MODULE. I HAVE NOT GOT A PRICE FOR THE PART OR REPAIR YET.
JASONCBFAN
Feb 01, 2008 | Samsung TSL3293HF 32" TV
Apex G51HD09
you can try and see if ptscorp.com will repair the board.
Jan 09, 2008 | Apex Digital GB51HD09 51" Rear Projection...
TV will not come on
How old is this TV?
Sounds like it has high voltage failure.
(If you hold your hand on the screen when you try and turn it on, do you feel the static? )
Unless the set is over 10 years old, I would overhaul the high voltage circuit. Should cost under $200 at a shop.
Jan 03, 2008 | RCA 32F531T 32" TV
Black screen with sound. Problem on every channel.
Sound no picture or shut down Power led starts green then a short amber then turns RED . If your power supply can be confirmed to be go you have a bad Inverter board. Per the manufacture this part comes only with the panel . Not cost effective . But if you go to
lcdparts.net you will locate an inverter for $ 169.99 . I had the same problem and the inverter repaired the set . Note there are similar error codes but from what I can see from all of your complaint I do be leave that your Inverter is bad . Good luk
Chongo
Aug 18, 2007 | Philips 30PF9946 30 in. HD-Ready Plasma...
Apex Digital GB55HD09W 55" Rear Projection Television Logo
183 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
