Question about Nokia 6288 Cellular Phone
No noise when it rings
When i play a tone or someone tryes to phone me it just dont make any sounds
  • 490 Answers
Go to the main menu >setting >phone settings > restore phone settings  >code 12345 or dial *7370# then reinsrt sim & try (but before doing it take ur memory card out of the handset) ,if u still face any problem then dial *7780# but before doing it plz take back up of ur phone coz through it u may lose ur data of ur phone
gizmo 1
Posted on Oct 14, 2007
SOURCE:
How do I get the ring tone on my phone to work?
These smartphones controls all sounds with the volume rocker, the only problem is that it controls only what is currently being use. Just go to any ringtone and tap it in order to play it. While it's playing, use the volume rocker up to raise the sound.
Dec 13, 2014 | Samsung Cell Phones
Incoming caller ring
Here is the link to the user manual if you need it. http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/CA-EN/30277_E815EnglishUserGuide.pdf Unfortunately what callers hear is dependent on the phone they are calling from, not on your phone. You could concievably send them a mutimedia message when they call, but there is no way to automate this, and it would probably be too much trouble and expense to bother. Wait a year or two, and it may well be that manufacturers start including this feature - it would require a slight modification of the communications protocols on the cell networks, but it probably would be popular. Good idea. Hope this helps :)
Jul 10, 2007 | Motorola Mobility E815
My lg neon from at&t want play sounds it justs vibrates. Whats wrong with it
I dont know my sound is on voume 7 but if someone calls it doesnt ring or make the melody noise whenever i press a button it hasnt been doing that since the past 3 days
May 14, 2010 | LG Neon GT365 Cell Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
PERSONALIZE MY RING TONE
i m not geeting download any ring tone in my phone ????????????????
Nov 08, 2008 | Motorola Mobility W375 Cellular Phone
My phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 15, 2008 | Nokia 1600 Cellular Phone
Ring tone
1. to set mp3 ring tones...
copy any mp3 file to phone ( via cable or bluetooth )
go to multimedia = go to mp3 = now play the song you want as tone,
when song is playing, select options, and select = set as ring tone
DONE and smile......
2. to set Default sound ring tones...
go to menu = my stuff = sounds =
browse the sound files when you like one , select options, and set as ring tone.....
Done and smile again... hope this helped...
May 13, 2008 | LG KG800 Cellular Phone
I have a 6600 nokia phone..
1ST U FOMET UR MOBILE AND MMC AND THEN INSTALL MP3 SOFTWARE.
Feb 29, 2008 | Nokia 6600
Ringtones
hi, before applying tone, play it & listen, if it plays sound. Resent ur mobiles master setting & apply now. bye
Oct 01, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia 6288 Cellular Phone Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
