Good picutre and no sound or good sound with black screen. cant get both
My mitsubishi vs-60607 comes on without a picture but sound works fine. after playing with settings on remote the sound goes away but and the picture is fine.
  • 129 Answers
SOURCE: Picture goes out after a few hours.
coul'be overheat solder the cause of a loose connection , and or convergence ic 's almost ready to fail . the cost to repair will be around 250.00 to fix replacing the ic's depending of the tech. or 350.00 at repair shop if you may have more question , let me know Im here to help you. thanks
Posted on Jun 13, 2007
  • 87 Answers
SOURCE: Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Posted on Nov 05, 2007
Slinteriors
  • 8617 Answers
SOURCE: my mitsubishi vs 5071
You might have a bad PIP board, When you say NO picture. Is it totally blacked out or blacked out with "blue snow". The PIP has been alot of problems in this chassis and you will experience what your describing. Capacitors are the root of the PIP boards failure. Let me know if I can assist you further.
Posted on Jan 26, 2008
SOURCE: MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Posted on Nov 25, 2008
  • 7 Answers
SOURCE: Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Posted on Jan 14, 2009
Mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 22, 2011 | Mitsubishi VS-60607 TV
My picture is wavy, I have a mitubishi big screen model # vs-60607
sounds almost like bad caps okay this is where i would start is thier an option on the set to alighn convergence try that also okay may be bad module also okay its worth fixxing okay call tv shop
May 17, 2009 | Mitsubishi VS-60607 TV
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
I get sound but the sreen is black
Try a "hard restart" , which simply means unplugging the power cord of the TV, then replugging it after 4 hours have passed. This technique helps to reprogram the electronics of the TV.
Hope this suggestion works for you.
Jun 21, 2008 | Mitsubishi VS-60607 TV
No picture
Try a "hard restart"', which simply means unplugging the power cord of your TV, and replugging it after 4 hours have passed. This technique helps to reprogram the electronics of your TV.
Jun 05, 2008 | Mitsubishi VS-60607 TV
Jun 12, 2007 | Mitsubishi VS-60607 TV
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
