Question about Intel Motherboard
3 beeps from mother baoare
    Novelist:
  • 183 Answers
Please Try this :-
:- Perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and ()listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
Clean cooling components that have become clogged with dust. If beeping continues, continue to the next step.
Remove a memory module.
If the computer stops beeping, the memory module might be bad, is the wrong type of memory for the motherboard, or was not fully seated or connected. Reinsert the memory into the socket to see if a connection was the problem; otherwise replace the module.
Remove each memory module, replacing the one that was previously removed. If beeping continues after checking all the memory modules, continue to the next step.
If the computer has a graphics adapter, remove it.
If the beep code changes or continues with the same beep pattern after removing the graphics adapter, the adapter might still be good. Reseat the graphics adapter into its socket and continue to the next step.
If the beep code goes away, the graphics adapter might be bad. Try reseating the graphics adapter, making sure it is fully locked into the connector on the motherboard. If problems continue, replace the adapter.
Remove a PCI card.
If the beep code goes away, the card might be bad. Try reseating the card into its connector on the motherboard. If problems continue, replace the card.
Remove each PCI card, replacing the one that was previously removed. After checking all cards, if beeping continues, continue to the next step.
Disconnect hard drives and CD or DVD drive cables (IDE and ATA) from the motherboard socket.
If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems continue, the drive itself might be bad and might need replacing.
Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. After checking all connections, if beeping continues, continue to the next step.
At this point, the problem is probably the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case.
Posted on May 12, 2009
    President:
  • 1,383 Answers
First refix ram after dust from it.
Also recoonect processor and its fan.
Pull cmos for 15 minutes from bord so it reset defaults.
A beep noice error E01
If there are one or more short beeps without any error, then it is common.
If there is an error with one long or short beep sound, then it is regarding the System board (Mother board).
Sollution: Check to see that all adapters, memory modules and chips are seated firmly; check for proper power connections to the Mother Board.
May 28, 2011 | Computers & Internet
There is a continious beeping sound from mainboard; when on. sonds like from the bios or cmos. any ideas Thanks
most likely it is a sound from mother board
- try to reseat the mother board(take out and put it back in)
- then check if still getting a sound/beep
- if not good!
- if yes replacement mother board suggestion
TIP:
- try other mother board on your computer first to check if you can hear a wierd noise
Mar 31, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Not beep
NO beep its depends on the condition.
with out RAM it means mother board foulty...
with RAM no beep sound it means replace the RAM. ok if Same problem Accure means mother Foulty.
Mar 17, 2010 | ASUS P5VD2-MX SE Motherboard
When I power up my acer PC I get a beep beep beep
Open your cpu cabinet cover.
Then Refix RAM memory on mother board.
Remove pci cards from mother board if any.
Make sure motherboard is not ground with cabinet.
Reattach ATX power connector to motherboard.
Pull cmos cell from motherboard for 10 minutes then refix it .
Then it work again.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 06, 2009 | Acer (AST135-U-S3100) PC Desktop
Mother board crash will not start
If it is a continous beep .... beep .... beep, then the RAM is the problem. It might be loose or the slot might be dusty. Try taking it out and changing the slot. If still the same problem, then try replacing the RAM with a new or borrowed one. If that works, replace the RAM.
If it is one long beep and 4 - 5 small beeps, then the display card (which is mostly onboard on your motherboard) might be faulty.
HTH,
Regards,
Deboo
Feb 17, 2009 | Microsoft Windows XP Media Center Edition...
Dead motherborad
mkjameel
all mother board bios has a beep coad for successful post. looks at mother board manual which is provided with ur mother board. or vander web site. (some mother board one single beep for successful post).
thanks
Buddhadev
Jul 08, 2008 | HP (D7580-60003) Motherboard
Mother baord beep sounds
Which model? Are the beeps 1 long, 2 short, 1 short, or just continuously short? Continuously = RAM needs checked and/or replaced (you can download either Memtest or the Microsoft Memory Diagnostics CD's to check it) 1 long and 2 short or 1 long, 3 short = VGA card needs checked
May 29, 2008 | Intel Motherboard
IBM 8650 continuous long single beeps
check your power suply,smps,and also check your motherbord dont touch the cabinet.
also check your processor case and clean it.
Mar 31, 2008 | ASUS A8N-SLI Deluxe Motherboard
Intel 845 chipset mother board no reaction - expecting solution
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
Feb 22, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Intel Motherboard Logo
847 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
