Question about JRC GPS
I have a JRC NWZ4550 GPS. I've only used it once, I entered 3 way points and the system worked fine. Satellites lock on, all ok. I did a soft start, cleared the system, then started entering my way points. When I'd finished I went back to the satellite status page and found I had no satellites. All stations showed zero. I tried again then did a master reset, re-entered all info required, but still cant bring up any satellites. On starting testing says ok. Can anyone help me or put me on to someone who can advise me further. Thankyou
If you are running a 4310 aerial with this unit the aerial ran out of date sometime in August 2008. You will have to buy a jrc 124 aerial. I had the same problem. Check with the agent TMQ International.You will find that the unit won't keep the date you have entered in it to set it up, it goes back to the year 1989 on the satellite page.
Posted on Sep 15, 2010
Okay I have been using my HP G61, for a while now. I bought it 3 months ago. And I used it for college everyday. I used it last night before I went to sleep. I've closed it and left it charging all...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 28, 2013 | Computers & Internet
Will not fire up a gps signal
Most GPS systems require a first time boot-up where they scan all registered satellites to determine where in the world they are and what satellites to concentrate their navigational efforts on. Try charging the GPS up entirely, and then doing a hard reset of the system (either by navigating to the hard reset in software or by pressing the tiny reset button usually located on GPS units), and then taking the system out under the open sky and letting it run for half an hour or so, making sure it is running in navigation mode (as opposed to setup or media mode). Once it locks properly onto a small subset of satellites, it should not have much difficulty.
If you continue having problems, check to be certain you are running the latest software on the device which can make a big difference. The latest software for the 520 is here:
http://www.navman.com/Navman/Templates/standardcontent____4407.aspx
Good luck...
Nov 21, 2007 | Fujitsu Siemens Pocket Loox N520 Pocket PC
Nuvi350 doesn't locate any satillites. What can I do?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Jul 11, 2009 | Garmin nuvi 260W GPS Receiver
Brought my NUVI from NY to San Francisco and it doesn't locate any satillites. What can I do?
Good Luck
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
Location is not shown correctly
everytime u turn the GPS device on it takes anywhere from 30secs to 4 mins to find and lock in the satellites . Once the satellites locked in it will be then start taking ur commands. In ur case u turned it off as u started driving and when u restarted it , it had a memory of where u turned it off and displayed u the location where u turned it off which was ur home, right, now if u would have waited till some satellites locked in , it would have then automatically displayed ur then current location. so next time when u start the unit (any GPS) wait till it locks in the satellites.
thank.
Apr 20, 2009 | Garmin Nuvi 370
Garmin 260w won't acquire satellites
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
GPS working intermittently
With ref to the downloaded files. There are 5 sets of files on the server.
2 Day
2 Day version 2
7 Day
7 Day Version 2
All of the above appear to be updated once per hour although none of them now seem to work for me with Global Locate's version 1.19 software. There is also a 10 day version which seems not to be updated any more. There are notes on the internet that explain how to edit the registry to make the software point to an appropriate area for the correct file. If you are pointing to the 10 day version it might be possible to point at the 2 or 7 day versions and recover the situation. There are only two lines to edit but bear in mind all the warnings about editing the registry
Mar 25, 2008 | HP iPAQ hw6515 Pocket PC
Garmin 60CSx - Cant find satellites
Try a re-load of the chipset driver. It is available from the Garmin website. I find that it occasionally becomes corrupt.
You can check by entering the "Main Menu" then "Setup" then "System" then press Menu and choose "Software Version".
If the "GPS SW Version" is 0.00 then a reload of the chipset driver will correct the problem.
Cheers.
Dec 29, 2007 | Garmin GPSMAP 60CSx
GO 910 not finding satellites
had same problem/reloaded thru computer/ok till today ,won't turn on now
Nov 03, 2007 | Tomtom GO 910 GPS Receiver
GPS Logo
170 people viewed this question
Top JRC GPS Experts
Shehu Pro
Shehu Pro
Are you a JRC GPS Expert? Answer questions, earn points and help others
