Question about Frigidaire ATF6000ES Front Load Washer
RUBBER RING THR RUBBERING INSIDE THE WASHER CAME OFF
    Problem Solver:
  • 12 Answers
Assuming you are talking about the boot seal that attaches from the tub to the door of the unit.
There is an inner and outer spring that holds the boot into place.
There is no easy way to do this.
Best way to do this is to replace the boot on the inside of the of the body, (Tub first) This will snap into place around the outer ring of the tub. The spring will be really hard to get into place. suggest something that will not cut to use and istall the spring,
Out is the same effect with the smaller spring match arrows.
Hope this helps.
Posted on May 14, 2009
How to Replace rubber seal on front load washer
The rubber seal on your washer and similar front loading washers is a relatively easy repair. The seal is held onto the front washer panel and the fixed inside washer drum with separate spring-loaded rings that are reusable. So, don't throw them away! You need to remove the front ring from the front panel before you can remove the front panel. With the ring removed the gasket should be pushed into the washer; noting any drain holes, so that you can reinstall the new gasket in the same orientation. Once the outer ring is removed and the front panel is out of the way, you will have access to the ring holding the gasket to the drum. After the inside ring is removed, the gasket should pull off the fixed washer drum. You are now ready to install the new replacement gasket.
The amount of disassembly of the front of the washer is your option if it interferes with the installation. The door is usually heavy and it is useful to remove it from the front panel. Usually, a couple screws holds it in place. Removal of the front panel may also involve removal of the top of the washer and moving the control panel out of the way so that you can access the screws holding the front panel onto the frame of the washer. The locking latch may have to be temporarily removed but can be left in place if you simply push the front panel out of the way to have access to the inside gasket ring. It is useful to take pictures of each stage of the disassembly process to make sure your reinstall everything as it was.
Installation of the gasket starts with reattaching it to the fixed washer drum flange and then replacing the spring-loaded ring to hold it in place. Make sure the gasket orientation matches the original position. After the gasket is attached to the drum, you can now reinstall the front panel. If you unscrewed the latch mechanism when you took off the panel, now is the time to reinstall it as it can be manually held in place behind the gasket. The door can usually remain off the front panel until installation of the gasket onto the front panel is complete. Now bring the gasket forward and reinstall it on the flange of the front panel; secure it in place with the spring-loaded ring. Your gasket is now reinstalled. Simply reinstall the door and your repair is complete.
Tools needed include a blade screwdriver to help pry the rings off the gasket seal and one or two specialty screwdrivers (usually Torx or Philips) to remove the front panel.
Aug 05, 2014 | Frigidaire Washing Machines
Hi the large rubber section that joins fom the door t the drum inside on my Aqualtis AQ9L 29 I 9kg washing machine has come off????? Is there any way I can fix this back on myself? Any tips? The rubber...
there is usually a ring type clip with a spring on it that goes around the rubber section to hold it on...I am assuming this is a front load washer...you can remove the top of the washer by removing a couple screws..look inside for the clip..it may have fallen off inside....then you can put the rubber back in place and re-attach the clip
Jun 11, 2011 | Washing Machines
The rubber ring inside the washing machine came out and a metal ring was under it, i dont know how to fix it?
that rubber is called the bellow. snap the bellow back to the machine. place plastic ring over it into the grove and work it all the way around. that metal ring should have a spring on it. use a needle nose pliers and pull the spring so it stretches, metal ring should snap right in place.
Feb 05, 2011 | Whirlpool WFW9200S Front Load Washer
Inserting loose rubber seal on front load washer
you can try holdthe one side and use a screw driver on the other end try to put the rmetal ring in the gasket. is batter if you have to persons...
Apr 10, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Spinning is out of balance even when there are no clothes in the washer
Most has a balance ring built onto to the tub, make sure thr balance ring is not damaged, It is normal for the tub to shake in the spin cycle with nothing in washer
Dec 22, 2009 | Kenmore 22422 Top Load Washer
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
Mold in rubber ring front loader Fridgidare washer
Common problem. Clean the moulding as best you can, even scour with steel wool. Leave the door open so the machine will be dry when not in use or/and wipe the rubber after each use. You can try to cover up the odour by wiping with a rag moistened with vanilla essence. Otherwise fit a new rubber and keep it dry in future.
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
RUBBER RING INSIDE THE WASHER
if the washer is still leaking, take the outlet pipe and place it in a dish on the floor , the water is greater and should come out of the pipe, keep watching until empty . remember there can be a lot of water in a washing machine
May 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
255 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
