2000 Toyota RAV4 Logo
a
abner gamozo Posted on Dec 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant find the timing mark after timing belt was cut, 1991 BMW 318i E36
_-__-___-_
Level 3:
  • Toyota Master 20,706 Answers
  • Posted on Dec 08, 2013
_-__-___-_
Toyota Master
Level 3:
Answers
20706
Questions
Helped
6792369
Points
57965
Is this an engine swap? a fraken Toyota?
roblem with 2000 Toyota RAV4 Cant find the timing mark after timing belt was cut, 1991 BMW 318i E36
1helpful
How do you set cam timing and crank timing with out a timing tool on a bmw e36 318i m42engine?and also what does tdc mean?
On any engine you should find timing marks on the end of camshaft which line up with Mark on the crankshaft. TDC is top dead center which is when the first most piston is on it's compression stroke. When you move the crank to TDC the firstmost or number one piston will be on the compression stroke. Turning the camshaft to align with the timing mark on crankshaft will put the engine in proper valve timing.
HOW TO REMOVE AND INSTALL SERPITINE BELT PULLYS ON A 1997 BMW 318i
Hi RObert:
I suggest visit this links with interesting information about this job:
- E36-Belt-Replacement/E36-Belt-Replacement
You have to find your belt tensioner, pop the cover off of it, hook a socket and ratchet to it and move it to release the tension off of the belt. While you are holding the belt tensioner, you can slip the belt off of one of the pulleys and then release the tensioner.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
2answers
Ownes manual for 1998 bmw 318i
BMW Owners manual. 1998 BMW 318i 4DR E36 BMW 318i CONV E36 BMW 318is 2DR E36 BMW 323i 4DR E36 BMW 323i CONV E36 BMW 323is 2DR E36 ... data.bmrparts.com/bmwparts/1610.html
have just checked this site out and the have a manual for yr bmw - hope this will help-
2helpful
Just want to find out...does bmw 318i e36 have a timing belt or timing chain?
There are 2 engines used on the 318i. One has a chain the other a belt. The M40B18(1990-1993) uses a cam belt and the M43B18(1993-1998) a chain.
How do i change the torque settings on my bmw e36 316i 1991 j reg its not a 318i but parts of a 318i would thay fit a 316i and work fine
Hi unsure what you mean by change the torque settings, if you mean on the head question is why? If yes for head, there is a tool for that & go to Download PDF search | PDFTown.com
for more info
318 tming chain setup
timing chain ? it is 8 vavles ,if both yeah
http://www.bimmerwerkz.com/forum/3-series-e36/m40-motor-timing-info-59059.html that is crankshaft marking and the camshaft marking ,u could see the line up (arrow)marking at the top ,after that turn the crank by hand few time then lines up ,if match then is all good
Security and alarm for e36 318i
You car should have a harnas already installed. Sigma and stellar alarms are easy to fit according to pro's. visit bmw e36 blog for more details.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
