Question about Audiovox Radio Communications
How do i activate my bluetooth with my playstation 3
How do pair my bluetooth with my playstation 3
5 Suggested Answers
zohail
  • 1223 Answers
SOURCE: lost my instuctions...
it is universal procedure to pair up all devices like this
first if ur headset is switched on switch it OFF by long pressing the main button in the centre it will blink blue light twice or thrice and will switch OFF after that u can touch any button it will not respond with blinking lights
Now press again that centre main button long press for like 10 sec until that blue light comes on and become STABLE when it is stable it means it is ready to pair up with any bluetooth device now go to ur PS sony switch the bluetooth ON and select search u will find ur headset with its model like H710 just select and when asked for pairing code enter 0000 Zero four times or try 8888 if it doesnt work , now u will see that ur headset light will start blinking and u will see a headset sign on the screen of ur mobile phone it means now it is paired up
now u can try to talk thru headset make a test call any number for voulume control there are two buttons on headset on upper sie with arrows u can select them to increase headset sound
pls rate me well for help ! Fixya rating is encouraging !
Posted on May 03, 2009
  • 65 Answers
SOURCE: PAIRING MY MOTOROLLA H700C BLUETOOTH WITH
Close the headset. Go to the ps3 and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized. After this, it will ask for a passcode. The ps3 should recognize it fairly quickly.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Posted on Aug 06, 2009
  • 32 Answers
SOURCE: trying to pair my pantronics bluetooth headset
Ok if t's asking for the passkey you need to enter four zero.
Posted on Jan 06, 2010
bob_computer
  • 3153 Answers
SOURCE: I Would Like to pair
Ensure it is fully charged
make sure your PS is set to find devices
Press and hold in the large button untill the lights flash red and green then release
If it asks for a code enter 0000 or 1234 (default codes)
The PS should then attempt to connect and you should be almost finished at that point
Posted on Feb 26, 2011
Testimonial: "Hey, Thanks, had the exact!! same problem and thx 2 u i knew the pass key but t turns blue/red on mine and just stay's blue on other's ive herd of.ty"
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
What does error code 80010009 for the crysis bluetooth 2 mean
Incorrect passkey for Bluetooth device. Description: Entered wrong passkey for the Bluetooth device when trying to pair it with the Playstation 3.
Source: http://us.playstation.com/support/answer/index.htm?a_id=939
Aug 13, 2011 | Sony Playstation 3 (PS3) Console
Okay i have the mad catz 8806 mic it flashes red and blue and charges fine but i cant talk into it and cant hear anyone through it at all it beeps and i hear that.
If the headset you have is the Item No. 8860 in order to use it you have to pair it.
If you are using it on a PS3 then be sure that you have selected the headset in the PlayStation's settings.
Pairing is a process of associating Bluetooth devices with each other. It will establish a permanent security link between the devices and enable quick access to the services provided without the need to re-enter Pass Keys. You will only need to pair your PS3 and the Headset once.
Paired devices remain paired even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be 'paired' so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Manage Bluetooth® Devices."
4. Scroll down and press X on the icon labeled: "Register New Device."
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset's LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate "8860" from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register completed"
Troubleshooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Q. The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40 minutes. It is highly recommended to fully charge the battery before use.
Q. No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time, it may take some time for the Headset LED indicator to show charging status with a steady Red light. Make sure the PLAYSTATION 3 is turned on. The 8860 cannot charge without the console being turned on.
Q. No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters) of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
Hope it helps
Apr 06, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
How to use bluetooth
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
Installing mad catz ps3 bluetooth
In order to use it you have to pair it with the PS3.
Trouble Shooting
Feb 27, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Im trying to hook up my mad catz bluetooth to my ps3 and i got it pass the scan part but it keeps saying theres a problem...PLEASE HELP
Is your PS3 seeing the Headset?
Is the headset in pairing mode?
Complete details below on how to connect it:
Trouble Shooting
Feb 22, 2011 | Mad Catz Bluetooth Headset for PlayStation...
I cant find instructions to sync my Mad Catz PS3 Blu tooth headset
Hope it helps:
Trouble Shooting
Jan 30, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
I am unable to sync my Mad Catz bluetooth to my PS3 and I can't find my bluetooth manual. How do I sync up?
Please see the sync details below:
Trouble Shooting
Jan 28, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
How do you turn the bluetooth on on a ps3 cause i cant get my bluetooth headset to pair
Turn on your Playstation 3, and from the main menu go to Settings - Accessory Settings - Register Bluetooth Device
You will be presented with two options:
Register BD Remote Control
Register Headset/Microphone/Headphones
Select Register Headset... and put your Bluetooth headset into pairing mode. On your PS3 select Start Scanning
Select your device and enter your pairing code. In most cases for audio devices the default pairing code is "0000"
Now on your PS3, go to Audio Device Settings and change your "Input Device" and "Output Device" to your Bluetooth headset name. Try speaking and watch your "Mic Level" move!
This might help you as well:)
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=898874
Dec 22, 2009 | Sony PlayStation® 3 (80GB) Console
Bluetooth headset pairing problem?
hold the button on ya headset till it flash's blue then scan again that should fix it
Mar 20, 2009 | Video Game Consoles & Games
Radio Communications Logo
187 people viewed this question
Top Audiovox Radio Communications Experts
eradiostore
eradiostore
john milligan
Computer Repairing
Computer Repairing
Are you an Audiovox Radio Communication Expert? Answer questions, earn points and help others
