Question about Microsoft Windows Vista Home Premium Edition for PC
Error Code 1068 in Windows Vista 64
All of a sudden my WIFI stopped working. I set Windows Wireless Service to Automatic and it still did not work. I searched the web for a fix and tried it and got the following error code 1068. Can you please help me?
  • 77 Answers
1. Click Start, and then click Help and Support. 2. Under Pick a Task, click Use Tools to view your computer information and diagnose problems. 3. In the Tools area, click System Configuration Utility. 4. In the right pane, click Open System Configuration Utility. This opens the System Configuration Utility. 5. Click the Services tab. 6. Make sure all the following services are turned on. To turn on a service, click to select the check box.
� Application Layer Gateway Service
� Network Connections
� Network Location Awareness (NLA)
� Plug and Play
� Remote Access Auto Connection Manager
� Remote Access Connection Manager
� Remote Procedure Call (RPC)
� Telephony
� LexBce Server (if you have it) 7. Click OK, and then click Restart.
If this doesnt work please reinstall the os or do a sfc/scannow it will check all system file.and will ask for the XP cd.
Posted on May 12, 2009
Hi, I am using Webex Remote Accessing Service and I am trying to connect the remote computer using windows 64-bit OS,Getting error '' We have detected 64-bit OS, Not supported but it was working fine till...
I had the EXACT same error on the EXACT same date as you. Its is obviously a problem with Webex, and I emailed them right away. HERE is the response I got from them this morning:
We have detected you are using 64 bit Win
Hello Cathy,
Thank you for choosing WebEx.
I understand that QB remote access was working fine on your computer but now you receive a message saying WebEx does not work with 64-bit OS.
I accept your point that it was working fine on the same computer until now. QuickBooks Remote Access service does not officially support Windows 64-bit Edition as of now. The service may or may not work depending on what updates Microsoft makes and this is not something that WebEx can control and cannot confirm.
It would not be possible for us to investigate the issue or escalate it since official support is not available right now.
Therefore we suggest using Windows XP or Vista 32 bit edition if you would like to use our service.
I apologize for any inconvenience this may cause.
Thank you for your patience and understanding.
For immediate assistance, please call our Technical Support directly at 916-463-8207, so that a Technical Support engineer can assist you.
Regards,
Kathy,
WebEx Technical Support.
______________________________________________
In other words.... Too bad sucka!!!
Feb 11, 2010 | Microsoft Computers & Internet
Cannot access network resource error when trying to load from cd
Just Simple.. You can try System Restore in Vista.. Cause in Vista can't not read automatic like vista. if your dont have Nero Disk try restore in good Condition before Software Crash..
Oct 26, 2009 | Computers & Internet
I've tried to wireless adaptors in this machine
Are your drivers for XP 64? If not, they will not work.
Sep 28, 2009 | Broadcom (BCM94318MPG) 802.11g/b Wireless...
Wireless adapter has suddenly stopped working.
First unplug your adapter and boot your computer. It wouldn;t hurt to reboot it once as well. This should clear out any settings. When it has fully booted up only then insert the adapter into a different usb port. If it recognizes it and works it can indicate a usb problem.
If it finds it but doesn't connect a adapter problem. You can uninstall it and reinstall the drivers and it might work. If not replace. If it does nothing then its died on you and your adapter needs to be replaced.
Most adapters and home network units (wifi routers etc) only last for 1-2 years before they act up or die on you. Very annoying and can be expensive. I have a stack of wifi routers where the wifi isn;t reliable but the rest works. And a drawer full of various wifi adapter that are detected but not connected and a few just plain dead ones. All of them seem to fail at about the same time after purchase.
Jul 09, 2009 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
Hi i have aprob my computer say the printer spooler cannot running error 1068
Check for other Service Dependencies A 1068 is a service dependency error. Print Spooler can't start because it thinks a service it depends on is not running.
shortcut: start-run-"services.msc"
Go into services and check its dependencies, it should just be the RPC service, which you shouldn't be able to stop, check that RPC is running
Double click print spooler and click the dependencies tab. See if there are any other dependencies set besides rpc. If so you will want to find them in services and make sure they are set to automatic and are running (will probably need to start them).
Then try to start "Print Spooler" service, should work. May need to reinstall printer drivers then.
Apr 21, 2009 | Computers & Internet
Drivers for windows vista 64 bit
i want wireless senao engenius driver vista to HP laptop
Dec 10, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
"Error 1068 Could not start the Printer Spooler on local Computer"
HI,
right click on my computer -> select manage -> one should be services and something (or something like that) open that and go to services -> find the printer spool service and right click on it -> click on properties -> in the printer spool service properites click the "Start" button and also under a drop down menu change it from "Disabled" to "Automatic".... This is what you did right ?
Log in to Administrator account and try it there. If that doesn't work then install a fresh copy of Windows Xp. It should work now. Thank you.
Sep 07, 2008 | Office Equipment & Supplies
I have been using Netgear for approximately 6 months. Two weeks ago, all Internet Service was stopped for both my HP Windows Vista desktop and Acer Aspire 9300 Windows XP laptop. Think either Net Gear or...
Try to use your laptop in the other wifi connection if it's work the problem is your router wifi configuration. But if cannot work try to check in device manager if your wifi device is working properly. in the RUN type DEVMGMT.MSC and look for your wifi device there if there is a ? mark it's mean that there is a complex configuration in the wifi. remove the wifi device in restart your computer the windows automatic detect the device in install it. try to connect if it is work but if still not work check for the ip and gateway configuration in the wifi setup.
Apr 25, 2008 | Computers & Internet
HP print spooler problem and error 1068. Want my printer back!!!
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at dabesderis06@gmail.com
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
Print spool error 1068
click Start, then click run. Type in "services.msc" without the " " marks
Oct 19, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Microsoft Windows Vista Home Premium Edition for PC Logo
694 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
