Question about Sharper Image Hybrid GP (SI724) Air Purifier
Hybrid GP will not operate consistently
When the Hybrid GP is turned on, it will run for about 15 minutes, and then stop (the little red light on top is blinking).  If it is turned off, and then turned back on, it will run, again, for about 15 minutes, and then turn off again.
 I have taken it apart and cleaned every component, so I know it is not due to too much dust accumulating.
  • 709 Answers
Hi Judy D,
I know you said you cleaned every component.  Did you turn it upside down after the Grids were removed and use a hair dryer to blow it out?  Did you remove the grill from the front and thoroughly clean and Blow everything out with with a hair dryer.  I am sure you cleaned it well, and used qa damp soapy cloth or sponge to wipe everything down, Did you allow the unit to dry overnight before starting it up?
If you have done these simple things, Then you must have a circuit problem.  This gets a little bit complicated. My first effort would be to access the circuitry and clean up all the wires and pieces around the circuits that have wires attached.  Carefully keep track of all the screws and only do one of the piecves at a time so that you do not overload your memory of what  goes where.  The Cleaning Required light turning on is a indication that you may have a circuit problem.  If it were amber, then it would only need cleaning.  Which you say you have done. I believe you.  Give the dismantling a try  and be sure to clean all the circuits with a Paint Brush, and do not get the circuit stuff wet.
Posted on Oct 13, 2007
  • 363 Answers
Hello Judy D.
As you might be aware the blinking LED indicates that a fault has been detected.
Check that the ionizing wires supports have not started to 'track' this will appear as a hair-like discolouration across the supports surface. The 'track' may be very thin and hard to spot.
This can be caused by dirt that has started to burn into the surface by arcing.
If you find any 'tracks' then try to clean them off with a mild solvent like pure alchohol.
Another thing to try is to run the unit in total darkness and look into the grills to see if there is any arcing or sparking happening.
Let us know the outcome.
SOURCE:
TRYING TO FIND REPLACEMENT PARTS FOR A SHARPER IMAGE HYBRID GP GERMICIDAL AIR PURIFIER MODEL SI724 NEED THE WIRES AND BEADS TO REPLACE SOME BROKEN ONES
I have 2 of these air purifiers and I love them. I came to this site looking for a resolution because 1 of them stopped working properly. After running for about 30 seconds, the red light would come on. I had cut out 1 wire that was broken and thought that was the problem. There were sparks when it was turned on. After reading a couple answers here, I took a closer look and noticed that a second wire was also broken at the bottom. I just cut the second broken wire off the top and removed it and the purifier works great now. No more sparks!
Aug 16, 2012 | Sharper Image Hybrid GP (SI724) Air...
My unit keeps turning off, attention required red ligth is blinking, I just clean te unit
make sure not to forget cleaning the corona wires. i used light grade sandpaper and gently cleaned the wires as well as scrubbed the metal grids with scotch brite pads. the unit has been running normally .
Aug 01, 2010 | Sharper Image Hybrid GP (SI724) Air...
I have a Sharper Image GP Hybrid model 1724. I cleaned the pull out blades and the inside of the unit. When I turn it on, the needs attention light comes on almost immediately. How can I get the machine...
i found a solution to the sparking problem in the ionic breeze. purchased scotch brite cleaning pads from home depot. using a long strip of pad scrub the plates back and forth especially in the areas that seem to be emitting sparks. i did this and the unit runs quiet as a whisper.
Jul 05, 2010 | Sharper Image Hybrid GP (SI724) Air...
Hybrid GP won't turn on. Tried different outlets. There is a green light thats hidden in the bottom of the unit that does stay on. I push the power button and the unit does not turn on.
The front and rear plastic grills of the Hybrid GP trigger a power cut-off safety mechanism if either of the grills is not entirely in place. The grills have a tendency to slide down ever so slightly if bumped. The tiniest amount of slippage is enough to engage the power cut-off and it's not generally noticeable unless you know what to look for. If the Hybrid GP has no power at all, you may need to slide one or both of the grills upward just a hair. You should hear and feel a slight click when the grills are properly locked into place.
Feb 28, 2010 | Sharper Image Hybrid GP (SI724) Air...
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
I purchased a Hybrid GP germicidal Air Purifier, Model # S1724 ((Electric Air Cleaner AC110v 20w 50/60Hz)). My unit is severly malfunctioning and i nee to either send it in for repair or be given detailed...
Locate the photo electric eye that picks up the need to clean and give it a thorought cleaning. Good Luck and I hope you get it repaired. That photo cell should be your problem It's probably a little black or ruby red dot in a fin or on the housing where yhe air passes.
Jul 06, 2009 | Sharper Image Hybrid GP (SI724) Air...
Gp sharper image hissing problem
1. Unplug the unit
2. Turn the unit upside down and listen for the beeds to move along the static wires from top to bottom. Turn it upside down again and again until you feel the static wires are cleaned of grime.
3. Plug it in again and see if the hissing is gone.
Jun 06, 2009 | Sharper Image Hybrid GP (SI724) Air...
Ionic Breeze Professional GP series.....question regarding lights
red light will not go off what do you do or is it still working or not and the red light is just on
Apr 04, 2009 | Sharper Image Professional Plus Ionic...
My Sharper Image ionizer after I cleaned the grid now makes popping noises and then the red light that says drying grid comes on most of the time. Sometimes the light that says attention required comes...
You are probably aware that the ionizer uses a very high voltage (at very low current) to function. If you have used a cleaner of some kind on it, you could have made the grid sensitive to moisture.
I would remove the grid again and wash it thoroughly in distilled water to remove any residue that stayed behind, then dry it in warm air before reinstalling it.
Oct 10, 2008 | Sharper Image Hybrid GP (SI724) Air...
Hybrid gp problem
You have to locate the "blade" that is causing a short (usually can see it sparking; if not, reset it (turn it off then on) in a dark room and locate the problem area (this is how I figured it out).  If you can locate the offending "blade", simply tear it out of the base where the spark is occurring, fold it back against itself so the metal does not contact anything other than itself (and is no longer contacting the base where the sparks occurred).
This fixed my unit (I was just about to throw it out when I tried this solution).
Jan 11, 2008 | Sharper Image Hybrid GP (SI724) Air...
Sharper Image Hybrid GP  (SI724) Air Purifier Logo
156 people viewed this question
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
